This plane has caught my attention as well. I look forward to a flight report Joe. 2dogrc has the instruction manual online and the pics look pretty good if you need to resort to it.
USA, NY, Jamestown
Joined Jun 2000
Okay, the motor I have is a C10 - 2100. Here's a link to it on HK: http://www.hobbyking.com/hobbyking/s...idProduct=6585
I took a closer look at it and while I was removing the prop I noticed the bell was sliding on the shaft. I tightened up the bell and cranked it up. 2.2 amps on a 6x3 prop. better. It won't hover out of my hand in my basement though. Need more power! I have one of the silver 10g motors but it has a KV of only 1500. |
This is the motor I purchased and was recommended by wrugen
http://www.hobbycity.com/hobbyking/s...idproduct=5358 Mine is not even started yet but this motor has plenty of pull on a 6X3 prop as witnessed at a recent indoor event. Quote:
Mini Breeze completed
I finished mine tonight
I used an AR 6300, a 6 amp Thunderbird along with the 10 Gram motor, blue arrow servos and a 6X3 GWS. It will hover out of my hand a little over 1/2 throttle. 85 Grams with Hyperion 2S 240 maH. My only complaint with the kit is mine was missing almost 1/2 of the required CF bracing material. Will maiden tomorrow at our indoor fly. |
USA, NY, Jamestown
Joined Jun 2000
I finally flew mine indoors the other night. Flew well. Not much punch though. It barely climbs from hover. I need a better motor.
My setup: C10-2100kv motor with 7x3.5 prop CC Phoenix 10 Esc Hyperion UM160 cells with home made series connector 4-3.7 gram digital servos lightened Hitec Optima 7 receiver If I remember correctly, I'm at 3 oz. |
| Thread Tools | |
| Discussion need EPP indoor plane-advice please | Flyfan | Indoor and Micro Models | 22 | Jun 29, 2011 09:59 PM |
| Build Log Mini Ultimate Bipe 22.5" 3D 11.1v, 370 Brushless build in progress!, DIY Elmers foam! | papadidypop | Foamies (Scratchbuilt) | 2 | Dec 15, 2010 10:56 PM |
| For Sale EPP Indoor Plane | Murocflyer | Aircraft - Electric - Micro & Indoor Airplanes | 2 | Nov 14, 2010 05:48 PM |
| Discussion epp foam plane | dazzzer1 | Beginner Training Area (Aircraft-Electric) | 6 | Oct 05, 2010 07:06 PM |
| Wanted Dualsky Breeze ES | Ryan Nau | Aircraft - Electric - Airplanes (FS/W) | 1 | Sep 19, 2010 07:37 AM |
