Old Nov 29, 2010, 06:14 PM
Air Head is offline
Find More Posts by Air Head
United States, CA, Mission Viejo
Joined Jan 2005
High Alpha Flight
While all you guys are trying to break 200 miles per hour ( or is it up to 210 now).
What about something like this.....How about a high alpha slow speed ducted fan model.
What sort of thrust to weight would I need to do some slow speed high alpha flight maneuvers....????
Air Head is offline Find More Posts by Air Head
Old Nov 29, 2010, 06:38 PM
Richie Simpson is offline
Find More Posts by Richie Simpson
Pittsburgh,PA.,USA
Joined Mar 2006
If you have to ask....<g>
Without a variable exhaust nozzle it is not possible with a jet. No airflow over control surfaces.
That said delta wings are more forgiving, search for sapac Saab gripen for the best I have seen.
Richie Simpson is offline Find More Posts by Richie Simpson
Old Nov 29, 2010, 06:54 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Any modern jet is capable of high-alpha flight without TVN.
TVN is only required if you want to hover your jet at zero-airspeed, which is otherwise known as 3D flying.
DanSavage is offline Find More Posts by DanSavage
Old Nov 29, 2010, 09:12 PM
iron eagle is offline
Find More Posts by iron eagle
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
thrust to weight ratio would have to be 1 to 1.
iron eagle is offline Find More Posts by iron eagle
Old Nov 29, 2010, 10:14 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Not really 1 to 1 but it helps to maintain alt. if your too slow..My old Kyosho Mirage would high alfa but if you got to slow and low you could not recover to level flight easy
turbonut is online now Find More Posts by turbonut
Old Nov 29, 2010, 10:22 PM
Bob Reynolds is online now
Find More Posts by Bob Reynolds
Tucson, AZ, USA
Joined Nov 2000
Many, many years ago, My son, David, won the slow flying award at the Denver Jet rally at 16.4 mph. He was flying his own design "U-Who" with his own designed 4" fan. A picture of this plane appeared in RC Jet International, May 2001.
Bob Reynolds is online now Find More Posts by Bob Reynolds
Old Nov 29, 2010, 10:50 PM
crypto666 is offline
Find More Posts by crypto666
USA, NV, Caliente
Joined Mar 2009
crypto666 is offline Find More Posts by crypto666
Old Nov 30, 2010, 05:36 AM
Neil Guildford is offline
Find More Posts by Neil Guildford
Neil Jarvis
Neil Guildford's Avatar
Surrey U.K.
Joined Sep 2004
My Tamjets F-16 1:8 will do a slow high alpha pass at its current weight of 20.5lb.
Neil Guildford is offline Find More Posts by Neil Guildford
Old Nov 30, 2010, 12:55 PM
aero1960 is offline
Find More Posts by aero1960
Joined Sep 2010
It's been done. Here is my video of my own design.
360 Thrust vectoring with 64mm EDF RC F-22 Foamy (2 min 42 sec)
I modified it even more and am practicing on slow inverted high alphas.
aero1960 is offline Find More Posts by aero1960
Old Nov 30, 2010, 01:09 PM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
I have seen the Lubach F16 in 80 degrees high alpha. One needs vertical climbout to recover from this angle. Lightweight and critical CG is the only option. He used minifan,16/15/3 and 4s1800mAh.
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Nov 30, 2010, 01:14 PM
Joined Dec 2003
I think that is feasable A variable exhaust nozzle is a nogo IMO. The gain is in the intake design.
Old Nov 30, 2010, 01:34 PM
marcelo3d is offline
Find More Posts by marcelo3d
marcelo3d's Avatar
USA, CA, Santa Cruz
Joined Mar 2008
As said before, detla wings are the most forgiving. Jets with little taper (think L-39) may want to snap.
The main requirement is to have a rudder and use it to correct the trajectory as the nose starts to drop to the side. Ailerons cause adverse yaw: the wing that you are trying to lift gets more drag, so the plane yaws to that side.
You can do a nice high-alpha with not a lot of power. A pretty decent high-alpha will require lots more, but not 1:1. 1:1 (or a little more) is nice to get out of high-alpha: punch the throttle and release elevator. With less thrust, you have to let the nose drop and regain airspeed, losing some altitude in the process.
It is a fun manuver and very useful to know.
M.-
marcelo3d is offline Find More Posts by marcelo3d
Old Nov 30, 2010, 01:38 PM
Joined Dec 2003
What angle do you consider high alpha?
Old Nov 30, 2010, 02:15 PM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
My GWS J-10 with working canards is awesome at high alpha.
F16s are great for high alpha slow flight. Don't understand why though. Very tempting to catch rather than land. Doesn't always end well.
High Alpha Disaster (0 min 55 sec)
DominicM is offline Find More Posts by DominicM
Old Nov 30, 2010, 04:03 PM
George-Styria is offline
Find More Posts by George-Styria
Österreich, Stmk., Graz-Umgebung
Joined Aug 2008
Here is my build TWM J10B with TV from rc-lander.
Works fine!!
http://www.youtube.com/watch?feature...&v=69CdmOd5KGo
Regards
George
George-Styria is offline Find More Posts by George-Styria
Discussion Evolution Alpha engine not holding high throttle moisesh Fuel Plane Talk 7 Nov 22, 2010 06:32 PM
Cool Starfighter Super Jet High Alpha VIDEO littlephoenix Foamies (Scratchbuilt) 2 Nov 09, 2010 02:32 PM
Question High Alpha/Angle of attack aeronca52 3D Flying 23 Sep 16, 2010 08:46 PM
FSW vs delta for controlled high alpha ? vladn Modeling Science 4 Mar 09, 2005 08:09 PM
High alpha? davidleitch Sport Planes 2 Jun 11, 2003 08:44 PM
