Old Nov 29, 2010, 02:59 PM
jptonks is offline
Find More Posts by jptonks
Joined Apr 2008
Reaming vs. Drilling Propellers
Hello all,
Can someone explain to me why reaming R/C propellers is preferable as compared to drilling them?
I have a Saito 220 glow that has a prop shaft size of 8mm x 1.25mm. 8 mm shaft diameter is fairly close to 5/16 inch, and I have a set of made-for-wood drill bits and a drill press. I do not have a reamer in this size and I would have to go buy one.
I am curious as to the differences in the cutting edges of these two different tools and why the hobby shop owner keeps telling me to "only ream propellers to the correct size"?
Thanks for your help.
John T.
jptonks is offline Find More Posts by jptonks
Old Nov 29, 2010, 03:05 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
A drill will "walk" to one side due to the twist effect and any change in density of the material being drilled, especially wood. A reamer will keep your prop hole centered and not lose the balance..
Fokker DII is offline Find More Posts by Fokker DII
Old Nov 29, 2010, 03:11 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Drills rarely make a really straight and circular hole. The drill bit will walk some causing the hole to be more oblong in shape. Plus it is difficult to get the hole to be an exact size. Say you need a 1/4 inch hole for the prop to fit the shaft of the engine. if you used a 1/4 inch drill bit the hole will wind up oversize and offcenter.
Now using a reamer, makes for extremely accurate hole sizes and shapes.
I have both a special 8mm drill bit for drilling prop shafts and a 8mm reamer, and the reamer always wins when you want the hole to be 8mm in size. it really sucks to ruin a nice large prop because the hole winds up being off center slightly or a little too large in size. So I much prefer the reamer.
of course you can give it a try and see what happens. Some people tend to get lucky and wind up with usable props anyway.
earlwb is offline Find More Posts by earlwb
Old Nov 29, 2010, 03:17 PM
Broken Wings is offline
Find More Posts by Broken Wings
Broken Wings's Avatar
United States, FL, Cocoa
Joined Jan 2006
The propeller reamers are "piloted" or stepped. This allows you to follow the original location of the hole put there by the manufacturer.
I've drilled smaller less exspensive $$$ propellers using a drill press. I've never tried it using a spade or brad point drill.
The trick is to try and maintain the original hole "location". If you drill the oversize hole off center its going to run-out and vibrate real bad. If it was me I think I'd just buy the correct reamer. Saito 220 propellers can't be cheap....
Broken Wings is offline Find More Posts by Broken Wings
Old Nov 29, 2010, 03:20 PM
706jim is online now
Find More Posts by 706jim
Canada, ON, Thunder Bay
Twist drills designed for general drilling are far too aggressive for the soft materials propellers are made from. I had to enlarge the diameter of 18" props for my big O.S. and used a 12mm drill. The drill cutting edges had to have a "flat" ground onto them to prevent them from diving into the prop. (Remember there is an existing hole that just makes this worse).
My end recommendation? Use a reamer if possible for the roundest hole and best results.
706jim is online now Find More Posts by 706jim
Old Nov 29, 2010, 03:33 PM
jptonks is offline
Joined Apr 2008
Thank you
To all who replied, thank you. I will be buying an 8 mm reamer.
John T.
Old Dec 28, 2010, 04:43 PM
Waterbug is offline
Find More Posts by Waterbug
Boring holes in sky & runway
Waterbug's Avatar
Michigan
Joined Jun 2004
Ream it!
Good discussion. Sorry I'm late.
First and foremost, the OP said he'll get an 8mm reamer..,. you actually want a Stepped propellor reamer for the piloting of each size with the next smaller size ahead of it, John T... just to be clear. If you got an 8mm "one size" reamer you'd have no piloting.
And now for the unnecessary details....
Most drills that we purchase have 2 cutting flutes, and they are not at the same height axially, i.e. nothing's perfect. This makes one tooth invariably hit first, bite in an dkick the drill in a direction 90 degrees from that tooth- where there is no support from the cylindrical OD margins or even a cutting tooth. The prop reamers that I have seen are all 4 fluted- which helps this problem a lot. This is probably at least as important as the piloting reamer effect listed above. There are actually 4 flute "core drills" used in industry to open holes up but they are not priced/available for hobbyists- but they are hard to distinguish from reamers! All of this discussion is predicated on the assumption that the mfr. put the hole in the right place... which I understand APC does particularly well, based on the actual balance of each prop after moulding... i.e. follow their hole and balancing required will be minimal if any. Good reason to invest in a reamer right there!
Also, if you have an APC with a hole that looks like it is not centered, just close your eyes and follow it (or return it)!
That being said, If you MUST use a drill, (and I often do for those plastic GWS props on electrics) use a drill press or other squaring device and go lightly on feed- almost holding it back sometimes as a sharp drill will tend to bite and try to screw itself in. When this happens, stop, and unscrew it, pull out the chips, run the drill backwards a few revs while feeding to knock down the bite marks left when it screwed in. Then you can proceed,even lighter feed than last time or it will just bite in again!
I also like to drill an oversize hole (1/64" bigger) from the back for some length, depending on where the pilot section of the cranshaft ends. You still want some (~1/8" min) of that pilot to hit the proper size (front-drilled) hole if possible. Thread OD doesn't pilot the prop as well as the solid part of the crank. The key here is that the hole has to be dead square to the back of the prop, or oversize, or back-bored. I choose backboring 1/64" oversize because nothing is perfectly square.
This backbore (predrilling from the back) also eliminates splintering on the back at break-thru.
Waterbug is offline Find More Posts by Waterbug
Old Dec 29, 2010, 09:27 AM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I use these stepped drills for props. Won't grab like a twist drill. Makes nice round holes self centred. Great for thin stuff too, like thin ply,fibreglass and thin aluminum without leaving a ragged hole.
http://www.harborfreight.com/3-piece...lls-91616.html.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Dec 29, 2010, 09:51 AM
Red Raider is offline
Find More Posts by Red Raider
USA, IL, Benton
Joined Jan 2005
No one has mentioned a tapered reamer. I have two 100 year old multi-flute reamers that I use. They are a little dull but I work slow anyway. When reaming out a prop I cut a couple of turns and try it, cut a few more turns and try it, until the prop will just screw on the crankshaft with out any play. These reamers are long with very little taper.
I also use the stepped reamers but if I remember right the standard reamer works better for the metric sizes than the metric one does.
Fred
Red Raider is offline Find More Posts by Red Raider
Old Dec 29, 2010, 12:11 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Hi Gord,
Thanks for posting that link, I think I'll treat myself to a set
I bet they're great for cutting round holes in fiberglass cowls!
For an 8mm prop hole, do you just go the next SAE size down, then ream?
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Dec 29, 2010, 01:23 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
The 5/16 is only a couple of thou. smaller than 8 mm so a little rotating may do it. Next size up will be to big.
Google may show where to find metric ones.
Gord.
Old Dec 30, 2010, 07:42 AM
landeck is offline
Find More Posts by landeck
United States, GA, Sandy Springs
Joined Jul 2008
You can get the ASE and Metric step reamers from Fox Manufacturing:
http://www.foxmanufacturing.com/inde...ort=20a&page=2
I have used them for many years.
Bruce
landeck is offline Find More Posts by landeck
Old Dec 30, 2010, 08:59 AM
Mike1484 is online now
Find More Posts by Mike1484
Elyria, Ohio
Joined Sep 2004
Why not center the prop up then clamp it then use a end mill to inlarge the hole . If you use a lot of the same size props a fixture could be made to speed things up.
Mike 1484
Mike1484 is online now Find More Posts by Mike1484
Old Jan 07, 2011, 03:23 PM
Waterbug is offline
Waterbug's Avatar
Michigan
Joined Jun 2004
I wish!
Because not all of us have acess to a good spindle and table (Drill press spindles are so-so for such work. I would LOVE to have a nice Bridgeport in my basement... but it would never fit because of all the plane stuff!
Old Jan 07, 2011, 07:27 PM
oskartek is offline
Find More Posts by oskartek
Curmudgeon at large
oskartek's Avatar
Cedar City, Ut.
Joined Dec 2009
Waterbug, Having an expensive piece of machinery will not make your problems go away if you can't use it properly.
Using a motor driven cutting tool to size a hole in a prop is simply overkill in my opinion.
I hand ream all my props with a stepped prop reamer.
If the hole is off center, I put the prop in a home made fixture made to fit on a DuBro prop balancer and center it, then hand cut the re-centered hole using an end mill in a drill bushing then hand reaming to final size.
This comes from experience and a trash can full of props.
By the way I am a toolmaker with over forty five years experience and obtained my tool and die certification in 1978.
"It ain't what you can make it's what you can save."
Happy flying, Oscar
oskartek is offline Find More Posts by oskartek
Help! Drilling steel,need some help...what rpm should i be at? ridgewalker The Builders Workshop 24 Oct 05, 2010 12:51 PM
Question Ducted Fan vs Propellers pyronaught Electric Plane Talk 46 Apr 02, 2010 01:21 AM
Discussion Drilling Or Reaming Wheels Darth_Z The Builders Workshop 9 Apr 25, 2006 01:42 AM
3 blade vs 2 blade propellers motoadve Electric Plane Talk 55 May 28, 2005 02:24 AM
Electric VS IC Propellers SkynetAir Modeling Science 14 Nov 27, 2002 08:40 PM
