Old Nov 28, 2010, 09:50 PM
Blitzkrieg65 is offline
Find More Posts by Blitzkrieg65
Blitzkrieg65's Avatar
Escondido, California
Joined Apr 2007
Build Log
Tiger 1 Winter, Recoil, EL MOD, New Smoker unit, pics & Video coming soon
Hello All,
Here is the latest custom build from RCTW. If you look closely at the pictures you can see how easy it is to install EL MOD. I have lengthen the HL dual 8 pin connector just for the customers convenience but not necessary! Notice it plugs right into the top hull and the other side plugs into the EL MOD board ECO or PRO version, you are done with your turret move, elevation, lights, cannon/airsoft/recoil. 3 connectors on the main board 2 for the motors, 1 for the power. Blaster IV comes with volume knob. Then you plug in the new speaker, 28 different complete tank sounds ready to go for you to choose from.
Here is the list of what this tank has, and then some!
Tiger 1 Asiatam metal hull
Tiger 1 complete top hull Recoil/flash, metal barrel, brass muzzle brake,
5 metal hatches, metal MG
EL MOD ECO Version drive board Easy install version, NO soldering or electrical background needed
EL MOD Blaster 4 sound board with Sony 70 watt speaker
CSI Tamiya compatible IR combat sensors
Asiatam gearbox with Max 400 motors
Asiatam late metal upgrade kit
Tiger 1 metal roadwheels
1 5000 mili-amp 7.2 volt NiMH batteries
RDS 8000 8 channel radio & receiver
Charge port and switch’s installed under the hatches
Custom paint job, decals with weathering & combat damage
Super Smoker coming to RCTW in 2011
Here are a few pictures of the build .
Video
Tiger 1 winter camo IR RC Tank, a beast.wmv (5 min 48 sec)
The Blitz
Blitzkrieg65 is offline Find More Posts by Blitzkrieg65
Old Nov 30, 2010, 04:17 PM
duca is offline
Find More Posts by duca
Joined Sep 2009
Awesome bro!!!!
duca is offline Find More Posts by duca
duca is offline
Joined Sep 2009
RCTankWars Rocks Man...........
Old Dec 06, 2010, 01:20 AM
Joined Apr 2007
Duca,,
What is up man, when are you going to get your Sherman IR ready so you can team up with Joe (Yellowshaker) and whoop some Tamiya butt at the next NEAD event??
OK check this out...
Before this tank shipped, I sprayed on my own decal, by adding the German cross, to the empty side.
I thought some guys might want to give it a try if they don' t have decals.
I did not worry too much about being exact or having all the edges smooth,
as this tank is suppose to have been in the field for a while. The numbers on the side are sprayed on as well,
using a stencil kit, just spray lightly!
The Blitz
Rave Mato Sherman, M4A1 (76) EL MOD F.O. Pics & Video Blitzkrieg65 RC Tanks 23 Dec 29, 2009 06:44 PM
Discussion New OS 55cc Gas Engine Coming SOON Check it out PICS INSIDE Aga1978 Fuel Plane Talk 12 Oct 09, 2009 06:54 AM
Yippee! finished my 72" JW. maiden coming soon +New Pics+ KingOfTheHill Dynamic Soaring 62 Nov 20, 2007 07:31 PM
New improved Tiger Moth kit by GWS coming soon! thomer Parkflyers 28 May 26, 2003 05:00 AM
