Old Nov 28, 2010, 09:19 PM
Mauricio2346 is offline
Find More Posts by Mauricio2346
Mauricio2346's Avatar
Medellín, Colombia
Joined Jan 2010
Front wheel wire attached to engine mount
Hi folks.
i'm working on my Koala RC plane (maybe you've never heard about this model, because was designed in argentina long time ago). the original design uses an engine mount with front landing gear. i have only a dave brown 1519 engine mount. i'll make a hole and use it (the mount) as a front landing gear support.
do you think is a god idea?
Regards;
Mauricio
Mauricio2346 is offline Find More Posts by Mauricio2346
Old Nov 29, 2010, 12:30 AM
ZEROSKIN76 is offline
Find More Posts by ZEROSKIN76
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
better idea is to take a small peice of hardwood and drill whole in that and strategically position it where it will work and not effect engine
just an opinion make sure firewall is strong
ZEROSKIN76 is offline Find More Posts by ZEROSKIN76
Old Nov 29, 2010, 11:32 PM
TLyttle is offline
Find More Posts by TLyttle
TLyttle's Avatar
Keremeos, BC Canada
Joined Mar 2004
Back when I had hair, we used to just bend the gear wire into an "L", and insert it between the firewall and the engine mount. That always worked...
TLyttle is offline Find More Posts by TLyttle
Old Nov 30, 2010, 12:17 AM
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
that works better if you have a dual fire wall and you thread it and epoxy it between the two but he want to steer his i believe
Old Nov 30, 2010, 04:57 PM
Medellín, Colombia
Joined Jan 2010
you're right! i want this wheel to be steereable.
i saw this modified engine mount
http://www.rcgroups.com/articles/ezo...n_firewall.jpg
and i thought that a tiny hole below the mount can support the landing gear wire. even in a hard landing or crash, the engine-mount-front wheel could stay together and protect the propeller or the engine itself.
http://www.marionvillemodels.com/rc-...ngineMount.jpg
above you can see what i want to do. this one is made on aluminum. mine is made of glass nylon.
here's another example:
http://www.selectdigitals.com/images/fix/6.jpg
Regards;
Mauricio
Old Nov 30, 2010, 07:58 PM
kill your idols
ZEROSKIN76's Avatar
utica new york
Joined May 2009
have you considered taking a block of hardwood about 1/3 inch thick drill hole in that for wire and ad a color to top and bottom and mount that between the mount and a firewall
ill be able to show you in photo tomorrow
works well and allows you to deal with rough landings without issue
worst case scenario you just replace wood
For Sale Dave Platt Waco YMF-3 Engine Cowl & Wheel Pants EJWash1 Aircraft - Fuel - Airplanes (FS/W) 0 Nov 27, 2010 11:45 AM
Sold Bind-n-Fly Trex 600 Front Mount AP Ship gill4321 Aircraft - Electric - Helis (FS/W) 0 Oct 16, 2010 05:51 PM
Found Front Wheel Axle for Thunder Tiger or Nuova Faor reddyrightnow Cars - Motorcycles (FS/W) 0 Sep 13, 2010 10:49 PM
Help!! Need a Shockflyer wheel and wheel pant mount! rcgreaves Aircraft - Electric - Airplanes (FS/W) 7 Feb 25, 2004 11:45 PM
Attached Wire Landing Gear Struts to Wood Fuse Stick bmizes Foamies (Kits) 2 Feb 10, 2003 03:31 PM
