The 1110/1Y/6.7 flies this model very well on 3S... I tried it. The 4S is what is in the video, and as you can see it give decent results. ![]() Best, Bob |
Another Orion build
I'm just finishing up an Orion build. It's a very nice model but there were a few glitches along the way to watch out for.
The stock aileron and flap horns sit much higher above the wing than I'd like. Flap horn (measuring to the center of the clevis hole) was 5mm above the wing skin, aileron horn about 7mm above the wing skin. It looks like it may be difficult to get adequate flap travel with these horns. My preference is to have the flap clevis pin located very slightly above the wing skin and slightly forward of the hinge line. The aileron horn is less critical, but I prefer the clevis pin to be slightly above the wing skin and right over the hinge line. I decided to modify the brass horns to bring the linkage closer to my preferred setup. In the picture below, you can see the metamorphosis of the horns -- I ground away the shoulder portion, redrilled a new clevis hole, and cut off the top of the horn. The resulting flap linkage is not quite what I'd like, but it's pretty close. As the pictures below show, I can get plenty of down flap travel and up travel (for mixing with ailerons) reaches the airframe's limits. The resulting location for the aileron clevis pin is a bit further back then I'd like, but that's not too critical. It just give a little "built in" differential. The new MKS 6125 wing servos were installed for flaps and ailerons. The aileron servo wells are VERY shallow, but with the servos slid up against the spar the covers do fit. You'll need to use a very short aileron servo arm and be careful aligning the servo covers to make it all fit. If Hyperion DS-09's were used instead, the fit would be less critical. Also, these servos are really nice -- strong, fast, smooth, slop-free, but be aware that they have less range of travel than other servos. This could be an issue for flaps, where you really need lots of servo travel. I was able to overcome this with some transmitter trickery, and was able to get just over 90 degrees of servo travel. I did have a small issue with stab alignment. Sighting from in front of the model, it was apparent that the wing and stab were not quite parallel. It wasn't off by much, and would likely make no difference in flight, but it still bothered me. I spent about an hour massaging it back to straight, with the application of a tiny bit of CA and some careful filing. Power setup is a NEU 1110/1Y/6.7, ICE Lite 100, and TP 4S-2250 battery. Ready to fly weight is 61 ounces. I've flown similar models that were over a pound heavier than this that thermalled great, so this one should be an awesome flier! Lenny
Thanks Bob. I suspect that this will be a popular model.
It seems like a very nice balance between thermal soarer and warmliner in a convenient sized package. ![]() Scot, This one runs on a BEC, but that's personal choice. A receiver pack could easily be added under the wing. There have been varying reports of CG location for this model. It will start out at 90mm and be moved back from there as needed. The battery pack can easily be moved to adjust the CG. Lenny |
Valdosta, GA
Joined May 2006
I am about halfway through my build. Should I plan on putting the receiver behind the servo tray? With whiskers? I thoughtlessly put the tray in the middle of the hatch opening. Consequently, I might have to move the tray to get enough room to access the fuselage.
| Thread Tools | |
| Yippee! Orion- the newest generation | dougmontgomery | Hand Launch | 34 | Dec 08, 2010 02:43 PM |
| For Sale **Traxxas Rustler xl5/Orion Combo/Jaco's** | StrangeFlightz | Cars - Cars and Parts (FS/W) | 2 | Nov 10, 2010 10:56 AM |
