Old May 20, 2012, 01:12 PM
MonsterBFC is offline
Find More Posts by MonsterBFC
Still a mile high when I land
MonsterBFC's Avatar
United States, CO, Arvada
Joined Mar 2011
Originally Posted by Doug913 View Post
I keep knocking the motor mount loose on mine. Part of thinks this isn't so bad since I'm not breaking the fuse. Maybe a little thicker mount wouldnt be so bad though. Aluminum mount might not be the greatest if you dont have that silky smooth landing grass.
Did you try using epoxy like I show on my build thread? I hit a rock right on the spinner on landing in the grass and broke a prop, but the mount held. I have some photo's of a motor mount done on the large motor as I have been shown. I could post them if you like. I just didn't understand why it's spaced back like that. I'll get a better understanding when I see it next week. It looks like the bearings stick out where there is none with the smaller setup.
Question: Couldn't I change out the prop and make this a kind of hotliner if I wanted? I thought that would be fun once in a while.
MonsterBFC is offline Find More Posts by MonsterBFC
Old May 20, 2012, 01:29 PM
320pilot is offline
Find More Posts by 320pilot
320pilot's Avatar
Joined Mar 2009
Lenny wrote,
....If you don't want to bother making your own, the aluminum motor mounts usually used for the Enigma will fit the Orion also.
Good luck,
Lenny
Do you mean this motor mount? Shown with an 1110/1y/6.7 motor. I can't remember if the holes in the mount line up properly with the gear box. Fuse on my Typhoon was too small, so I went with a plywood mount.
320pilot is offline Find More Posts by 320pilot
Old May 20, 2012, 06:03 PM
Lenny970 is offline
Find More Posts by Lenny970
Lenny970's Avatar
Greeley, Colorado, USA
Joined Feb 2000
Originally Posted by 320pilot View Post
Lenny wrote,
Yes, that looks like the one. It's made to fit the current NEU 6.7 gearbox.
The older NEU gearboxes, had a slightly different bolt pattern.
Lenny
Lenny970 is offline Find More Posts by Lenny970
Old May 20, 2012, 07:56 PM
Doug913 is offline
Find More Posts by Doug913
Closed Account
Joined Dec 2011
Off hand I don't rember who suggested some type of epoxy filler. I had not tried that material because it seemed like it was kind of expensive for how I needed. I suspect a little thicker mount as well as some type support for the back end of the motor would help. I guess it's better than breaking the fuse.
Doug913 is offline Find More Posts by Doug913
Old May 21, 2012, 09:40 AM
MonsterBFC's Avatar
Joined Mar 2011
Large motor mount
Take a quick look at my build thread. The filler is called West System 406 Coloidal Silica adhesive filler. It's easy to work with and is very strong. Here are a couple shots of the lager motor setup with a plywood motor mount. The mount is installed using the same methods. The second shot is a cutaway showing a mount that survived a nose-in crash. The rest of the fuse was destroyed.
Old May 21, 2012, 10:21 AM
nicoyenny is online now
Find More Posts by nicoyenny
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
I think with the motor/esc setup you have it will be a little more than warm, just keep in mind that you have ~ 2.5 meter of wingspan ....
I have sent mine in a nice dive, and it is FUN ... and mine is barely lukewarm :|
nicoyenny is online now Find More Posts by nicoyenny
Old May 21, 2012, 10:25 AM
Doug913 is offline
Closed Account
Joined Dec 2011
What do you think of a mounting plate on both the front side and back side of that lip and trap it between tne mounts. Not sure if that would be to much on the fuse. A little red paint and all good. Just a thought.
What's the green in front of your motor?
Old May 21, 2012, 11:14 AM
MonsterBFC's Avatar
Joined Mar 2011
If you look on my thread you'll see it's what I call a "fudge gap". It's just tape wrapped around the gear box and then you smear just a little grease on the tape to prevent epoxy from bonding to the motor. It gives you a little space so you can remove the motor if needed, and some room to move the motor around if you need to center it a little better.
Old May 21, 2012, 12:15 PM
Blanco Loc is online now
Find More Posts by Blanco Loc
France, Midi-Pyrnes, Toulouse
Joined Sep 2005
Some guys playing with Orion in Europe
Orion - Airtech-rc (3 min 35 sec)
Blanco Loc is online now Find More Posts by Blanco Loc
Old May 21, 2012, 12:53 PM
MonsterBFC's Avatar
Joined Mar 2011
That was the kind of fun I was having until I nearly cut a wing in half on a power line.
Old May 21, 2012, 08:21 PM
320pilot is offline
320pilot's Avatar
Joined Mar 2009
nice flying , but I didn't like the very low passes aimed directly at the spectators...seemed stupid
my 2c worth
Old May 21, 2012, 10:05 PM
MonsterBFC's Avatar
Joined Mar 2011
I don't
Old May 31, 2012, 07:48 PM
MonsterBFC's Avatar
Joined Mar 2011
Thermals and the Orion
Maiden'd Orion 2 today far, far away from power lines, trees or fences. My flight was 67 min. and I used half the lipo power I had. I got into a nice thermal that pushed me to nearly 1000 ft., and I got a nice escort from a Buzzard and some Sparrow's. I have a couple questions on working thermals:
Am I better off circling using ailerons or rudder when I'm in a thermal? Or both?
Is it best to mix in camber using both ailerons and flaps?, or one or the other depending on the situation?
Fun question: WHAT IS YOUR LONGEST FLIGHT WITH THE ORION? Thanks guys.
Old Jun 01, 2012, 10:12 AM
Just flyy is offline
Find More Posts by Just flyy
Yep it's Phil!
Just flyy's Avatar
United States, CA, San Diego
Joined Apr 2007
Sloping the Orion!
CG at 113. No power used in this video until the last clip. There are a couple of climbs that look like the motor is on but it is just pumps/energy from sloping. What a great all rounder. So good I have 2 of them! They are great for early in the day when the lift is spotty and risking a pure Glider is not cool!
http://www.rcgroups.com/forums/showt...2#post21771423
Phil
Just flyy is offline Find More Posts by Just flyy
Old Jun 03, 2012, 01:25 AM
airtimeasto is offline
Find More Posts by airtimeasto
There is only DS
airtimeasto's Avatar
Australia, WA, Baldivis
Joined Aug 2008
Hi all,
I thought I'd join the electro club, so I ordered a Orion from Bob last night.
Although I've been sending them emails to try and choose a colour and haven't heard a reply yet.
It will be good to have a sailplane that I can fly when theirs no wind for dsing, which there hasn't
been any. So buying this may bring it on.
I've gone with Bobs setup. Any tips on how to keep this puppy a light build?
Cheers Asto
airtimeasto is offline Find More Posts by airtimeasto
Yippee! Orion- the newest generation dougmontgomery Hand Launch 34 Dec 08, 2010 02:43 PM
For Sale **Traxxas Rustler xl5/Orion Combo/Jaco's** StrangeFlightz Cars - Cars and Parts (FS/W) 2 Nov 10, 2010 10:56 AM
