Old Dec 31, 2012, 03:10 PM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
LZ
are you running the stock motor and 20 amp esc? I guarantee it won't be long before you slap in a 3s pack and a 4.5 x 4.5 prop on her. A 800-1000 mah 3s should work out just fine.
headlessagain is offline Find More Posts by headlessagain
Old Dec 31, 2012, 03:38 PM
ledzep76 is offline
Find More Posts by ledzep76
ledzep76's Avatar
United Kingdom, England, Bisley
Joined Oct 2010
Running stock to start. Could be tempted to crank it up a notch in the future though.
ledzep76 is offline Find More Posts by ledzep76
Old Jan 01, 2013, 01:04 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Nice job on your plane. it's a lot like my 2nd one. Nice and tame but it's a blast to fly. I'm running 3s 800's.
If you have some carbon strips I highly recommend the mod I made inside the canopy and on the floor.
Re: the pic with the 2 strips would now show a 3rd strip in the center and running a bit further back than the other 2.
If you have any nose ins, this will save the plane from serious distortion. Well... you know, it will help save it.
http://www.rcgroups.com/forums/showp...postcount=1053
IFlyRCs is offline Find More Posts by IFlyRCs
Old Jan 01, 2013, 03:09 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
I added the carbon after crashing and bending the nose. The old very hot water treatment got it back into shape but it would have saved the hassle if I'd done the mod before stuffing her in.
Just need a FB to launch her for me or perhaps build a launch ramp. I wonder if a longer ramp would work without a bungee. Now I think of it, I remember seeing something similar over on the F27 Stryker thread. Time to do some searching.
Found it http://www.rcgroups.com/forums/showp...postcount=5031
Parkzone F 27Q Launch Platform (2 min 47 sec)
Andy
Old Jan 01, 2013, 03:37 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I'm of the school that thinks beefing up too much - results in greater more difficult damage. I am not a CF user ... I prefer balsa and bamboo. They are much more forgiving ... can be glued back / scarfed easily.... and light.
My underbody has two balsa 1/4 sq beams set in ... my elevons have 1/16th balsa sheet epoxied to underside ... Those two mods create a stiff but easily repaired model.
The weakest part of the is model is first - the fuselage just where the cockpit line dips to run aft. The foam not only is thin, but has that air-hole underneath weakening it. Next is between the fins where the central section is moulded to take the beam. That needs to be fitted in my opinion with epoxy and plenty of keying in to tie those two sides together. Take the model and hold by one wing tip and see that area flex when nothing there !
Nigel
solentlife is offline Find More Posts by solentlife
Old Jan 01, 2013, 06:53 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Originally Posted by solentlife View Post
Beefed up a bit ?
Seriously anyone going down similar road to Stu and myself with high power - you reallly need a better mount.
Nigel
happy new year guys.Nigel on the 1st page I think,is the pic of my motormount.I have the mk1,with the tiny 2700kv motor.so it's all good.I'm going to make a proper ply mount for the new one.and since I'm going to use an inrunner,it will be fairly easy and strong enough
chop stiX is offline Find More Posts by chop stiX
Old Jan 01, 2013, 07:53 AM
solentlife's Avatar
Joined Jan 2010
HAPPY NEW YEAR
To all ....
Nigel
Old Jan 01, 2013, 02:46 PM
ledzep76 is offline
ledzep76's Avatar
Joined Oct 2010
I took Nigels advice and looked at beefing up the flex in the wing between the fins above the central beam. The lightest way I found was to chop the rear section of the canopy off and glue it in place with plenty of glue where it touches the sides and on top of the beam. This has made the whole wing really stiff now. Just got to work on stiffening the cockpit floor now
Old Jan 02, 2013, 02:58 AM
solentlife's Avatar
Joined Jan 2010
I never thought to glue that piece in !
I've just made sure the beam is well epoxied in ...
I did consider a balsa sheet across the underside but never did. That was when I was considering the 'discus' style launch ... hold one wing tip and launch.
Nigel
Old Jan 09, 2013, 04:34 PM
ledzep76 is offline
ledzep76's Avatar
Joined Oct 2010
Flite Test - ROCKET PLANE (7 min 47 sec)
This shows there is a limit. It's interesting to see where it breaks.
Old Jan 10, 2013, 06:58 AM
mice1m is offline
Find More Posts by mice1m
Joined Aug 2012
HOME MADE MOTORS.first 5 were duds
Hobbyking Rocket powered EPO parkjet (4 min 27 sec)
so last year.
HK parkjet rocket planes (2 min 42 sec)
mice1m is offline Find More Posts by mice1m
Old Jan 20, 2013, 12:24 AM
solentlife's Avatar
Joined Jan 2010
Very Very quiet here ?
Cannot believe all those PKJ's are hangar'd and not flying ?
Me - I'm away wiorking - so have excuse ... but believe me when I say - whenn I get home I'll be stomping to get PKJ(twin) in the air ...
C'mon ... where's the flights ?
Nigel
Old Jan 20, 2013, 06:09 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Ok, just to keep you happy Nigel, here's an edited video of my Cameo Parkjet. Motor is now a Mystery D2632 3000kv heli motor,4.5 x 4.5 TGS prop,Turnigy AE-30A esc and 1500 3S pack. Happy with the way it flew and RC Speedo recorded a speed just shy of 80 mph.
HobbyKing Parkjet on Mystery 3000kv heli motor (1 min 43 sec)
Andy
Old Jan 21, 2013, 01:42 AM
chop stiX's Avatar
Joined May 2011
Nigel
PJ2 is still under construction,lol as this year has started off crazy I haven't had time to finish her
But I will.
I reckon I'll be close on 200km/h with the new setup.
My PJ1 is stioll flying,but shame she is seriously beat up and battered
Old Jan 21, 2013, 06:52 AM
solentlife's Avatar
Joined Jan 2010
Andy
My doppler gave max clear speed of 159kph on that ... there were higher, but they were not clear as when you edited the vid - you clipped what may have been faster speed ... but time span for the doppler is not enough.
159kph = 98mph
So I reckon you were over 100mph at times. But of course you have the full original video ...
Welcome to the club !!
Nigel
Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF smasher41 Foamy EDFs 1045 Jan 02, 2016 11:19 AM
Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s stuart warne Electric Warbirds 12 Jun 14, 2011 03:47 AM
For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly WRXronald Aircraft - Electric - Airplanes (FS/W) 3 Aug 04, 2010 11:03 PM
New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly CrashingDutchman Foamy EDFs 13 Jul 02, 2010 12:15 AM
Discussion HK's EPO F-16 WRXronald Foamy EDFs 5 Apr 11, 2010 03:47 PM
