Nigel |
Finally, found a good Parkjet thread! Question....I have seen a lot of really nice paint jobs here. How do you get the paint to stay on your birds? I went with a basic high-visibility scheme on mine but the paint is not wanting to stay put. I was thinking of clear coating it with epoxy enamel. Suggestions?
![]() you could use polyurethane varnish.will make it more sleek aswell and slippery through the air.even add some strength |
United States, TN, Memphis
Joined Jun 2011
Before painting do a alcohol wipedown.
Polycrylic to seal paint - It's water based. i prefer Gloss http://www.lowes.com/pd_164668-24-35...lic&facetInfo= |
-Damn ur PJ looks wicked.awsome scheme!
you could use polyurethane varnish.will make it more sleek aswell and slippery through the air.even add some strength.- Thanks. I wasn't going for detail, I just need to be able see it at high speed. -Before painting do a alcohol wipedown. Polycrylic to seal paint - Gloss, is water based- That's where I think I messed up. I thought the paint (Plastic Fusion) would adhere better but........ So that Polycrylic is pretty tough stuff? |
Joined Jun 2011
I wouldn't call it tough no. You can tell it's there.
But it will seal the paint to help stop the chipping. You should try it. It's worth a test run. Put 3 or 4 coats on it. Recoat every 20 minutes. Also, a lot of people basecoat with Polycrylic before painting. Paint adheres well to it. |
it runs super smooth at this dilution, whereas undiluted it clogged immediatly. its still drying after an hour. i probably wont put on other coats right now - no time. i'll wait to see it that one coat is enough. |
Joined Jun 2011
Aerosol can is the way to go from my experience. Hanging outside, totally dry in 30 minutes. I tried airbrushing Polycrylic and didn't really like it. Others have had good luck though.
Turbovector, do you like the clear? To me the PJ is twitchy as heck. I like lower rates. Maybe start around 60 and 40 expo? It's easy and free to step up after a test spin/trimming flight, you know. Without looking I think I'm around 75 and 30 now. |
United States, KS, Potwin
Joined Mar 2012
Actually, I found a spray can of polyurethane clear wheel paint hidden in the garage. VERY tough stuff, it kept my truck rims shiny for years. Feels even more slippery than it was out of the box. Sounds good on the expo settings, how about throws? |
![]() I have 4mm eacway on low rates and 6 mm on high rates.with 30/40% expo |
| Thread Tools | |
| Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF | smasher41 | Foamy EDFs | 615 | Feb 17, 2013 02:22 PM |
| Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s | stuart warne | Electric Warbirds | 12 | Jun 14, 2011 02:47 AM |
| For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly | WRXronald | Aircraft - Electric - Airplanes (FS/W) | 3 | Aug 04, 2010 10:03 PM |
| New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly | CrashingDutchman | Foamy EDFs | 13 | Jul 01, 2010 11:15 PM |
| Discussion HK's EPO F-16 | WRXronald | Foamy EDFs | 5 | Apr 11, 2010 02:47 PM |
