nigel,i also use this motor mount on the pkj and found the power is a bit much on the thin plastic the motors screws go through,just a suggestion if it gives you a problem is to epoxy a round ply disc in with the plastic.makes the mount real solid.
i had the plastic insides break once during the bench test since the thrust was so great. i'm sure flying lessions stress on the mounta lot. |
Put the Wattmeter on her ....
3S 2200 35C .... She hit 100A / 1.1KW ................... no way hosé ! I didn't try the 4S - the Wattmeter itself was getting warm cables just in those few secs. She needs different motors ... now looking at 2623 3000KV jobs to keep the amps down ... review here : (not mine !) But this little bastard really rocks on 3 cells! No warranty then of course, but so cheap it doesn't matter.. This setup is for WOT in short burst: 5x5 (electric, Not parkflyer type propeller) 3cells lipo 22,6 Amp 236,7 watt! Motor gets warm, but 20+ flights so far, all good ![]() Battery? I used Flightmax 3s1p 800 Mah (20-30C) The 2632 3800's will be used as single power jobs .... elsewhere. Nigel |
As posted earlier - the motors are too much ... will have to sort another set of motors ... Nigel |
power....we love overkill!!!.
i agree with leaving it for a go and at the end of run doppler that little demon![]() now i do have some great news,my wife just downloaded rcspeedo on my daughters ipad and it works!!!!!!!!! so awsome to be able to record passes one after the other. of coarse i still need to do outdoor test,but it worked perfectly on the neonbjb video. now i just have to get my tranmitter repaired or replaced and i'll be posting speeds all the time for these experimental trial builds.
The other trouble is - I live in Latvia and you cannot believe the price of so-called quality LiPo's here ... it's why I live with HK stuff ... The other thing is the ESC's are 50A ... so they are past their limits ... Let me think on this ... I've hit the buy button for a couple of 2623 3000kv motors .... so I need to consider ... Nigel |
http://www.hobbypartz.com/98p-60c-2200-3s1p-3333.html I may order a few for myself, and pickup in US. I wonder how much to send to Latvia from Canada. I'll buy you a new battery, you only pay shipping. Just have to promise to use those motors. Interested? |
United Kingdom, Leeds
Joined Aug 2011
As there seem to be a few chaps on this thread who know their onions, could someone judge whether they think the readings I'm getting from RCSpeedo are accurate?
I'm running a Typhoon 3550kv Heli motor at wing level, 4.5 x 4.5, 40A ESC, 1300 45-90c 3s and getting fairly consistent 180-190kph readings. Do those figures sound realistic? ![]() She may not be pretty but she goes like the clappers. ![]() ![]() http://www.rcgroups.com/forums/showa...5&d=1353620069 |
I'm looking at a mass order of various LiPo's as I need an upgrade for the Edge racer .... my EDF's are eating batts .... my F15 is similarly ... my big gasser biplane is still not finished repairs ... First I'm going to EPA the throttle back so I at least get her airborne - I can live with 50A total on the 2200's ... they'll get warm - but that'll be ok. Then I'll see about the two other motors on order or go for the higher battery rating ... Cheers Nigel |
I get about 210kph on my tired PKJ with 3700 Westor + 5x5 on a 1800 3S ... when I ran a 4.75x4.75 - I dropped to about 195kph. When I first got her going (she took so many failed launches - I nearly gave up) - she hit 222kph with the 3700kv + 5x5 + 1800 3S - that is the max she ever did. Batterys were having a hard time of it ! |
| Thread Tools | |
| Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF | smasher41 | Foamy EDFs | 615 | Feb 17, 2013 02:22 PM |
| Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s | stuart warne | Electric Warbirds | 12 | Jun 14, 2011 02:47 AM |
| For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly | WRXronald | Aircraft - Electric - Airplanes (FS/W) | 3 | Aug 04, 2010 10:03 PM |
| New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly | CrashingDutchman | Foamy EDFs | 13 | Jul 01, 2010 11:15 PM |
| Discussion HK's EPO F-16 | WRXronald | Foamy EDFs | 5 | Apr 11, 2010 02:47 PM |
