Old Mar 27, 2012, 07:54 AM
morris.hans is offline
Find More Posts by morris.hans
United States, LA, Shreveport
Joined Jun 2011
got the metal motor mount mounted, bungee launch stud glued, and bottom fiberglassed. motor is a 3550kv heli motor, i pulled 836watts with this motor on my heli and it only weighs 63grams so it should take anything this light jet can dish out
morris.hans is offline Find More Posts by morris.hans
Old Mar 27, 2012, 08:16 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
geeeezuz this thing will be able to withstand a crash into a bridge at mach 1
must way a ton? 836W on a PJ that's just mental
looks cool though.hope to see some vid
chop stiX is offline Find More Posts by chop stiX
Old Mar 27, 2012, 08:38 AM
Joined Jun 2011
its probably not gonna pull 836 watts since it doesent weigh that much, i will get a final weight when done, but i promise it will be atleast 50grams lighter than my night flyer parkjet which has 80grams of lights hahahaha
Old Mar 27, 2012, 08:45 AM
shauntot is online now
Find More Posts by shauntot
shauntot's Avatar
Joined Aug 2005
Can someone recommend a motor and esc combo thats specifically available from hobbyking that will work with 800mah 3s batts since I already have a bunch of those. My stock mk2 pj is getting smoked by the radjets and funjets in my local club!
shauntot is online now Find More Posts by shauntot
Old Mar 27, 2012, 08:53 AM
chop stiX's Avatar
Joined May 2011
lets hope for this to happen soon
http://www.pcmag.com/article2/0,2817,2396398,00.asp
Old Mar 27, 2012, 12:00 PM
Brian Courtice is offline
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
Morris what power system is going into that little beast? That's a seriously heavy duty build! I assume you have plans for the elevons? I wouldn't fly it with just those flimsy, flexy, foam surfaces.
I considered adding some extra carbon during my build, but opted for just some strategically positioned strapping tape. So far the plane is rock solid at 100 mph, so the extra carbon wasn't needed.
Morris's plane should be strong enough go at mach speed!
Brian Courtice is offline Find More Posts by Brian Courtice
Old Mar 27, 2012, 12:02 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
You need a heli motor spec'd for a Trex 250 ... get your KV up over the 3500 ... 3800 mark ... some of those small heli motors can get 4500 + kv
ESC needs to be at least 30A ... with some 50A ... but above 250 heli motor ? I'd plump for a 50A and be done with it .. as you may go bonkers like me and put a 450 heli motor in !! But your 800 3S is a limitation and why I say a 250 heli motor to try and still get a run-time.
Most parkjet flyers in the speed freak world are running larger lipo's and even 4S ... not small 800's, especially if only 20C ...
solentlife is offline Find More Posts by solentlife
Old Mar 27, 2012, 12:34 PM
Joined Jun 2011
haha, my setup is
3550kv
Motor: http://www.hobbyking.com/hobbyking/s...idProduct=9021
45A esc
Esc: http://www.hobbyking.com/hobbyking/s...dProduct=12191
4s 1300 45-90C (i have good luck with these and they last alot of cycles cause its nothing to put out 40+amps)
Battery: http://www.hobbyking.com/hobbyking/s...arehouse_.html
shauntot,
I cant get any speed out of my 800mah's
Old Mar 27, 2012, 12:37 PM
Free as a bird now.
Joined May 2002
If you are ordering new gear from hobby king anyway, do it right, and invest in some 1300's. I like the Nano 25-50c's. Your PJ will thank you for it! Get a 2836-3200 motor while you are at it, and you may find yourself leaving those pesky radjets and funjets flying in your wake.
Old Mar 27, 2012, 02:14 PM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Originally Posted by Jpette View Post
I am still experimenting on my CG that was too much forward at the top end of the fingers holes.
funny mine is it the same area and I am trying to move it back a little because I seem to run out of elevator on landing.
aeromaniac is offline Find More Posts by aeromaniac
Old Mar 27, 2012, 02:21 PM
solentlife's Avatar
Joined Jan 2010
If you really want to melt the foam ........
5000kv EDF motor
50A ESC
decent 3S of 1300 - 1800mAh 25C or better
But remember that prop selection becomes more important as you up the anti ... I run a 5x5 on the 3700kv, 450 Heli motor ... and torque is unbelievable ...
I've reduced prop to 4.6 x 5 but haven't been able to test yet.
Remember that : Pitch = speed, Diameter = Thrust / torque ..... so keep pitch high and diameter down.
Also be careful to pick props that are stiff ... I often cut back larger props to give me stiffer, better prop to not flex when large power loads are going through them.
Example : My gasser bipe has 14 x 7 props cut back to 11.5 x 7 .... which then gives a prop that can withstand tremendous loads and still give me flywheel effect of nearly the 14" prop. The 4.6 x 5 is a 5 x 5 cut back. I will also in my quest for MORE speed cut back 7 x 6 prop to 4.? x 6 ......
Not saying leave RC Groups ... but on Wattflyer - there is a thread running ... HK Parkjet Need for Speed - dedicated to pushing the Parkjet to limits ..... people are catching up with my 222 kph ... soon to be passed by someone !
Old Mar 27, 2012, 02:28 PM
Glow 😡 no no no
Joined Mar 2010
I am using this heli motor http://www.hobbyking.com/hobbyking/s...i%5FMotor.html and it pulls 25 amps static on a 4.1x4.1 prop. Currently run 1800 3s to get CofG.
Old Mar 27, 2012, 02:34 PM
Joined Jun 2011
solentlife,
ive been looking for a 5000kv @ your claimed 50amps motor that isnt too long and heavy, can u post a link?
I want to melt the foam
Old Mar 27, 2012, 04:14 PM
Glow 😡 no no no
Joined Mar 2010
Here we go into the old pitch speed debate, while pitch is very important it is useless without diameter.
Old Mar 27, 2012, 04:18 PM
Glow 😡 no no no
Joined Mar 2010
Remembering to increase speed by double drag goes up by 4, so if you can have as much pitch speed as you like but with diameter it won't get there.
Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF smasher41 Foamy EDFs 1048 May 01, 2016 10:25 AM
Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s Stuart Warne Electric Warbirds 12 Jun 14, 2011 02:47 AM
For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly WRXronald Aircraft - Electric - Airplanes (FS/W) 3 Aug 04, 2010 10:03 PM
New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly CrashingDutchman Foamy EDFs 13 Jul 01, 2010 11:15 PM
Discussion HK's EPO F-16 WRXronald Foamy EDFs 5 Apr 11, 2010 02:47 PM
