Old Mar 25, 2012, 01:49 PM
Jpette is offline
Find More Posts by Jpette
Finlande
Joined Dec 2007
max a Parkjet can suffer is about 140gr in LiPo
You can go even higher in weight . I am using successfully this pack :
http://www.hobbyking.com/hobbycity/s...dProduct=18208
Actually, the plane flys even better with this heavier battery than with a 100 g pack at least when it's windy .
Honestly, I can fly whatever from a 100g 3S Rhino pack to this 1300-4S -155g pack and the plane is always as easy to launch and feels very light no matter the battery weight.
I believe that this plane could carry even more weight if we can find room for it.
I registered today 166 km/h and 177 km/h in a dive with my 70g-2700-motor with a Rhino-3S-1050-30C pack on a 4,75x4,75 prop .
Unfortunately, the canopy popped off when I changed battery for a 4 cells pack and the pitot tube was damaged for the second time . Again I couldn't register the speed but man, that was really fast .
Finally I tried my best pack, the nano-tech-4S-1300-45C and it became quite "brutal" and a bit scary !! What a blast !!!!
Hopefully I"ll manage to repair that speed recorder and I"ll finally get a speed reading on 4 cells .
Jpette is offline Find More Posts by Jpette
Old Mar 25, 2012, 02:34 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Note I did say - 140gr depending on motor etc.
I have a really heavy 450 helicopter motor in mine ... so that causes real bad tail weight. I cannot balance it with the 920 4S as the pack is too long and I cannot get it fwd enough. My 1800 3S is ok thouigh as it's shorter, heavier and I can get weight more fwd.
Once I fit the 5000kv or the 3800kv I have ordered - they are much lighter motors and I will then have greater variation in packs and of course then I can look at more than 140gr.
177 kph .... not bad ... we just need to pitch you up on prop .. maybe a few extra rpm and you'll be screaming past me !
I sincerely believe less than 5" pitch will hold you guys back. Once I get a reliable launch ramp in place - i shall be going up again in pitch ........ probably cutting back a 7 x 6 prop to 4.5 x 6 or similar ... have to test and see what amps draw vs thrust is ... maybe less diameter ..
Glad you hit insane speed though jpette ............. I know I had to let my heart settle after !! it is INTENSE !
solentlife is online now Find More Posts by solentlife
Old Mar 25, 2012, 02:45 PM
solentlife's Avatar
Joined Jan 2010
As already said - this is my intended once I re-motor the PKJ :
http://www.hobbyking.com/hobbycity/s...dproduct=21341
1500mAh 4S 25C ............. its more compact than the nano-tech and to be honest - I have a couple friends who have given up on nano's after both of them found not long after starting to use them power ouput was no better than a standard LiPo, in fact some of them were worse. 25C is more than enough I reckon..... 25C x 1.5A = 37.5A .... burst at 35C x 1.5A = 52.5A .... I can live with that ............
Old Mar 25, 2012, 02:53 PM
morris.hans is offline
Find More Posts by morris.hans
United States, LA, Shreveport
Joined Jun 2011
rc foamfighters style hk parkjet
here is the slow progress on my rc foamfighters style hk parkjet, sooo stiff already, next is the fiberglass weave
morris.hans is offline Find More Posts by morris.hans
Old Mar 25, 2012, 06:04 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Anyone considered strakes on this plane?
Might not be feasible, just a thought.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Mar 25, 2012, 10:55 PM
The Don is offline
Find More Posts by The Don
Park Pilot Mag. Jets Columnist
Willoughby, Ohio
Joined Jan 2002
Finished mine today. AUW is 11.7 ounces with a 3S1320 lipo. 230 watts per pound should make it fly rather well. Running a 3200 KV Wicked JR motor.
The Don is offline Find More Posts by The Don
Old Mar 26, 2012, 12:13 AM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Looks very nice Don.
aeromaniac is offline Find More Posts by aeromaniac
Old Mar 26, 2012, 07:35 AM
Joined Jun 2011
don, paint looks slick!!! what kind of paint is that?
solentlife's Avatar
Joined Jan 2010
They all look fabulous till the first few launches !!
My next ones will not have paint jobs at all .... too much hassle to touch up. I shall use shrink covering film - only trouble then is that any stress cracks etc. will be hard to see.
I reckon my next will be so outlandish in colour scheme, no-one will want to launch it !!
Old Mar 26, 2012, 10:55 AM
Jpette is offline
Finlande
Joined Dec 2007
168 km/h today on 3 cells
186 km/h on 4 cells .
It was so windy today that I couldn't make any nice straight pass and didn't dare to let it go far enough to max out the speed .
This is my new favorite plane . What a blast to fly .
Don
You could try with one of your wicked 2700 on 4 cells or the 3000 on 3 cells .
They should be perfect motors for this beast
Old Mar 26, 2012, 11:52 AM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
The blue is Testors Model Master "Blue Angel Blue" and the yellow is just a can of enamel from the local hardware store I had.
Don
Old Mar 26, 2012, 12:39 PM
Joined Jun 2011
very nice, im going with colored packaging tape: easy to apply, easy to fix, light, bright, shrinks in heat, cheap
Old Mar 26, 2012, 03:38 PM
The Don is offline
Willoughby, Ohio
Joined Jan 2002
Originally Posted by Jpette View Post
Don
Yes it would be a rocket. I think the next one will have that setup as the airframes are sure cheap enough!
Don
Old Mar 27, 2012, 01:01 AM
solentlife's Avatar
Joined Jan 2010
Don
C'mon guys .......... UP that pitch !! You know you want to !! Nice 4.5 x 5 .. get her motoring !! But there yer go ... 186kph ... getting there ... SLOWLY !!
Old Mar 27, 2012, 01:44 AM
Jpette is offline
Finlande
Joined Dec 2007
It's true that I am going up in speed slowly .
That's my character to enjoy as long as possible any speed increase before I move on.
I am still experimenting on my CG that was too much forward at the top end of the fingers hole.
I managed to fix my pitot tube but still had problems with it and when it finally started to work , I had only two batteries left .
When I am sure about the actual speed by repeated measures, then I'll prop up for a 4,75x5,5 to get a little bit more pitch .
If that's not enough , there is still the 5,25 x 6,25 to try but that could be pushing a bit on the motor .
186 km/h was with a 15 mph tail wind so I believe that the ground speed was far above 200 km/h and it felt insanely fast for such a small airframe .
The plane was holding fine at thoses speed without any reinforcement but I could see my wing shaking !! It would be wise of me to add some spar in it before it desintegrates in flight .
Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF smasher41 Foamy EDFs 1056 Aug 18, 2016 12:00 PM
Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s Stuart Warne Electric Warbirds 12 Jun 14, 2011 02:47 AM
For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly WRXronald Aircraft - Electric - Airplanes (FS/W) 3 Aug 04, 2010 10:03 PM
New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly CrashingDutchman Foamy EDFs 13 Jul 01, 2010 11:15 PM
Discussion HK's EPO F-16 WRXronald Foamy EDFs 5 Apr 11, 2010 02:47 PM
