Singapore, Singapore
Joined Nov 2011
They are newly setup with my 9x. Ailerons are on 65% expo, elevators are 20%. Here's a short flight with these settimgs today-
Finlande
Joined Dec 2007
Here a close look at my motor mount :
http://www.hobbyking.com/hobbycity/s...5pcs_bag_.html First attach the motor to the base plate with screws .Spacing is standard 16x19mm pattern . The motor axe enters inside the hollow base and to prevent the axe rubbing on the plastic, I had to add a bolt between base plate and motor Then, the base plate enters in the stick by force and is secured by the tiny screw on the stick . If you wanna change the motor, you just need to keep an access to that tiny screw , nothing more . A Don's wicked motor or the one I listed bolt right on the plate but with a Turnigy motor, you should first reverse the shaft and probably use a larger spacer between base plate and motor . Hopefully it helps |
Joined Nov 2011
I didn't use the supplied glue as I read that it isn't strong. Instead, I used this for gluing EPO foam and it has held up very well for all my repairs on this jet so far. For my stick mount, I used 30 min epoxy.
Finlande
Joined Dec 2007
I don't know about prop damages at landing cause I am flying on soft snow on an icy lake . That is for you to check but hopefully the plane is quite light and a bit of grass could be enough . Man if you want a good motor, get a Don's wicked 3000 KV if you plan to stay on 3 cells or even better a 2700 kV on 4 cells . http://www.donsrc.com/cart/index.php...d&productId=12 Otherwise, I would advise you the motor I listed before but that is in UK . They have a KEDA 59g 2700 kV that is a beast on 3 cells : 450 W with a 6x5.5 prop . The one I use which is the 71g 2700 has a lower Kv than advertised but is perfect for 4 cells . |
Joined Feb 2012
Hi is this the original motor? http://www.hobbyking.com/hobbyking/s...er_3000kv.html
Joined Jun 2011
I have only had 10-15 flights so I don't know if durability is that good, but its working great so far :-) Grtz, Thomas |
Joined Nov 2011
Flights with lowered motor
Lowered the motor to level with the stick mount using some leftover kapaline board.
Then some flights yesterday all launched Frisbee-style to avoid being cut by the lowered propeller blades. The nosedive problem at launch seemed to have disappeared and I didn't even have do any elevator trim upwards or angle the throws upwards much. Whether it was purely due to the lowered motor position or also due to the change in my throwing style I don't know (previously all my launches were made by holding on the grip holes).
But I'm surely sticking to the launching it this way even though I'm still not quite used to it yet. Occasionally, I would forget not to spin it like a frisbee while throwing and bloopers like this would happen. ![]()
More flying meant more crashes and once the canopy became too weak and shattered to provide any resistance against bending on a hard crash, the fuselage broke into 2 again. ![]() ![]() |
| Thread Tools | |
| Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF | smasher41 | Foamy EDFs | 615 | Feb 17, 2013 02:22 PM |
| Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s | stuart warne | Electric Warbirds | 12 | Jun 14, 2011 02:47 AM |
| For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly | WRXronald | Aircraft - Electric - Airplanes (FS/W) | 3 | Aug 04, 2010 10:03 PM |
| New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly | CrashingDutchman | Foamy EDFs | 13 | Jul 01, 2010 11:15 PM |
| Discussion HK's EPO F-16 | WRXronald | Foamy EDFs | 5 | Apr 11, 2010 02:47 PM |
