http://www.hobbyking.com/hobbyking/s...r_55_64mm.html Only 50 odd grams and has a 3.0mm shaft not the 2.3mm shaft of 250 size motors. At 4200kv should be good on 2 cells if you can source the current. I've chopped a couple of props to get the specs i want such as a 7x6 down to a 4x6 just to get the pitch speed and take the load of the motor for higher rpm. Where did i put that 8x9! Jamie |
I have a Spread sheet that I enter calculated, theoretical based on average of real vs calculated ... etc. In the lower kv / power bands the real vs calculated is pretty constant - but as soon as you get into extremes - the rules fall apart. 2200kv 4S 145W 32560kv/volts 19200rpm actual 5 pitch 154 pitch speed MPH 248 pitch speed KPH 93 theoretical speed MPH 149 theoretical speed KPH 84 actual speed recorded MPH 135 actual speed recorded KPH 54% calculated speed vs actual. My record breaking 222kph results :- 3700KV 3S 520W 41070kv/volts 32000 actual rpm 5 pitch 194 pitch speed MPH 313 pitch speed KPH 117 theoretical speed MPH 188 theoretical speed KPH 138 actual speed MPH 222 actual speed KPH 71% calculated vs real See my point ? I'm truly waiting to see what my twin results will be ... this is the theory results :- 3000kv x 2 4S over 700W combined 44400kv/volts 38000 rpm 4.75 pitch 300 pitch speed MPH 482 pitch speed KPH 180 theoretical speed MPH 289 theoretical speed KPH Actual unknown at present ............ but I reckon she will hit about 275kph ... Nigel |
Yes i agree Nigel. Its pie in the sky stuff. Same with most planes. But its was a base line for a 4200kv motor compared to the 2850kv for 2 cell. Starting from a better place so to speak. Of course other factors such as drag and prop efficiency come into it. And drag goes up exponentially with speed. Just actually bought that motor to try out. It cheap enough to try a fastish 2s plane.
Jamie |
Interesting motor, I guess I could try it. I got one flight in at lunchtime today and found that after I raved about gorilla glue my launching handle under my parkjet came adrift on landing. I had even cleaned all the epo parts of my parkjet with surgical spirit to get rid of any mold release agent. Anyway I did a video today. Its a bit long but does show some passes in both directions ( although most are into wind the wind speed was only 5 mph). I fly from a small park about the size of a rugby pitch, for the passes I was diving toward the trees at the end and flying at about 20ft off the deck for the length of the field. Video is a bit poor as it was done on my phone. Can anyone Doppler this please and maybe we can pool our results. Personally I think I have made my parkjet a little slower than a stock one. . |
Ledzep
One of the things i do with foam and gorilla glue (Love the stuff) is using a skewer, poke holes in all directions in the foam for the glue to expand into. She grabs good them. Tip i picked up on here somewhere. What prop are you using on the 2850kv? I have the emax version of this motor which unlike the rctimer version has poor windings but a good basis for rewinding. I have the stock amount of turns but using 24awg 'real' copper. Rewinding is a tedious job but you can get the kv you want by altering the turn count. These are wound dLRK. This may also be an option for you. Are you wanting the plane to be fast but still be light and floaty or as fast as possible regardless of weight? |
Ok guys, finally finished my parkjet. 9 months after i bought the kits. Intention was too keep this one close to stock and make the 2nd kit the speed machine, but not sure now that the machine is nla. Scratch built clone for a speed machine maybe.
Pics Little changes are rewound stock motor, 30a esc, xtra carbon, big old hard drive magnets and carbon pin for canopy holding, servos on top, stick mount to keep motor as sleek as possible. will be running 850 3s |
One format that you would have a field day with ... Keychain cam at an angle ... I attached one to my Cessna wing strut for an onboard .... Only did it one time !!
Catch that one !! Nigel |
I didn't really understand Movie Maker then and thought I could trim the window to square it up !! No - all it could do was to rotate so horizon was level !
I now mount the keycam on top of wing to one side by tie-wrap through the wing. It only needs two very small inconspicuous holes for tie to pass through. When not carried - you don't notice the holes at all. Nigel |
| Thread Tools | |
| Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF | smasher41 | Foamy EDFs | 615 | Feb 17, 2013 02:22 PM |
| Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s | stuart warne | Electric Warbirds | 12 | Jun 14, 2011 02:47 AM |
| For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly | WRXronald | Aircraft - Electric - Airplanes (FS/W) | 3 | Aug 04, 2010 10:03 PM |
| New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly | CrashingDutchman | Foamy EDFs | 13 | Jul 01, 2010 11:15 PM |
| Discussion HK's EPO F-16 | WRXronald | Foamy EDFs | 5 | Apr 11, 2010 02:47 PM |
