Old Nov 27, 2010, 03:42 AM
Boxhead is offline
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
HK EPO Parjet, ARF
A small review of this, what I think is a Great Little flyer. If you read the reviews on the HK Forums there is probably a 60/40 Balance of good and bad. I thought I'd give it a shot. It came in a small box and everything was there. Even came with glue .
So it was time to glue the wings to the main fuse and fins on. Instead of using the glue provided I used 5 min epoxy. The glue provided probably does a good job as well. I used a tooth pic to put some holes along the foam joins so the glue would bind a bit better. Since the servos where already fitted I checked them just to make sure they were in tight. No problem there. Next was the engine mount. Seemed fragile to me, so I opted to use only the round disc mount of the supplied engine mount and glue it to the rear of the wing as in the pics. I put in 2-3 degrees down thrust and supported it top and bottom with some 5mm cellfoam 88 for some strength ( not in the pics )and also the bottom one is used a a skid.
I used the prop provided and prop saver. The prop is not a perfect fit on the prop saver. Dont forget since its a pusher the prop faces forward ( eg Numbers on the prop facing towards the front. The grub screws are tiny on the metal engine mount and prop saver. Their around a 1mm allan key in size. A real PIA. I added some stickers and hooked up the electronics. I adjusted the elevons with a little bit up for the first flight. A little not to much. So it was time to give it ago.
I used the supplied esc and found it works well with 2 and 3 cell Batts. No problems as yet. It has an annoying beep every 10 -20 seconds when being used. Maybe to tell the pilot its ready to go.
I tried it with a 2 cell and Yeh it flew but not with sparkling performance. Mmmmmmm.... 3 cell time. I used a 3 cell 500mah batt first up and it really picked up its game. I now use 3 cell 800mah and get a 10 min flight with a bit to spare in juice.
For its size the combination of the supplied esc /motor and 3 cell Batt, I think it gives it good performance. As for the CG, I used the finger holes underneath the wing and went from there. After trimming during its maiden I find this little park jet a joy to fly. Others on the HK Forums maybe think differently but I suppose " What ever Rocks your Boat "
Here's a couple of pics and some flight video.
Bx
HK EPO Parkjet.wmv (2 min 15 sec)
Boxhead is offline Find More Posts by Boxhead
Old Nov 28, 2010, 01:37 AM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Thanks for the flight report, Boxhead. This plane scoots along fast and smooth.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Nov 28, 2010, 02:49 PM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Hi Rusty, good to hear from you . Are you back flying or just dropping into the forums occasionly. Hope all's well with the family up there in the frozen North.
Bx
Old Dec 04, 2010, 01:44 AM
rudes is offline
Find More Posts by rudes
Australia Sunshine Coast
Joined Sep 2007
Hi Box, been flying mine for a while. I used a slightly different motor and esc on 2's 800mah batteries and it gets along. Haven't been game to try it on a 3's battery. The little engine mount it came with kept comming apart on landing. My motor is mounted a lot lower than the original and it doesn't lift so much under full throttle. Might try mounting the motor the way you did yours. Hard to find little jets that are light enough to fly on 2's batteries. If you come across anything small and light enough please let me know.
Check out the weight and size of this http://www.hobbycity.com/hobbyking/s...dProduct=14553
Rudolf
rudes is offline Find More Posts by rudes
Old Dec 04, 2010, 06:32 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Hey Rudes, how they hang'in . Well I hope. Mate this EPO parkjet is a good little ship. Got to agree about the original engine mount. Definately not in the ball park. Took mine out yesterday for a fly. On 3 cell handled the wind with ease. Weather here at the moment sucks. Rain/Wind. You get the idea. I'll put up another picy of the engine mounting shortly. Just shows the mount support at the top. The original motor and esc that comes with the EPO Jet can handle 3 cell just fine.
That AT6 is a good looking aircraft. Weight looks good as well. It also has good write ups. Mmmmmmm...... thinking. I've got a HK DR1 Triplane coming my way from Santa. Bet Ya it will be a handful
Bx
Old Dec 05, 2010, 06:21 PM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Re-did the engine mount . Its the same but stronger ( Luv that Hot glue ). Also changed the prop fitment ( due to the prop letting go with the original prop holder ). bullet proof Now....
Bx
Old Dec 06, 2010, 12:17 AM
rudes is offline
Joined Sep 2007
Thanks for the pic's Box. Hate to be annoying but a while ago you sent me a link to where ya buy your 40mm EDF's any chance of it again. With a bit more experience in EDF's I wouldn't mind trying one on this little jet. The weight of this little jet comes in pretty close to try a 40mm on a 3's battery. I turned the servo throws down a bit more today and this little jet is a pleasure to fly.
I use this motor http://www.hobbycity.com/hobbyking/s...idProduct=5432
This esc http://www.hobbycity.com/hobbyking/s...idProduct=4204
With a GWS 5 x 4.3 huge flight time.
Rudolf
Old Dec 06, 2010, 04:53 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Rudes, this is where I got my original 40mm EDF but they have no motor.
http://shop.eflypower.com/shop/sort.asp?sort_id=94
HK have them with motor for about $20. http://www.hobbyking.com/hobbyking/s...dProduct=10574
If your going to EDF the EPO Parkjet watch your weight. Good luck with it.
Bx
Old Jan 11, 2011, 10:41 AM
mike_m2 is offline
Find More Posts by mike_m2
mmerry2 on Youtube
mike_m2's Avatar
United States, MD
Joined Nov 2010
Thanks for the review Boxhead! I decided to buy one and it should be here sometime this week. I ordered another motor, ESC and prop with it just in case the stock setup was insufficient. From what you guys are saying, sounds like I will have to redo or reinforce the motor mount also.
Regarding this comment below, with EDFs, don't expect the plane to float as well. EDFs require you keep up your speed.
-Mike
mike_m2 is offline Find More Posts by mike_m2
Old Jan 11, 2011, 11:47 AM
mike_m2 is offline
mmerry2 on Youtube
mike_m2's Avatar
United States, MD
Joined Nov 2010
Review of HK EPO ParkJet
Flite Test did a nice video review of the jet here. They included a cool upgrade option too, only problem with the motor upgrade they suggest is that it's an inrunner and will probably be harder to mount directly to the back of plane than an outrunner. I ordered the inrunner they suggested (Turnigy HXT2835 2700kV Inrunner), but I wish now I had ordered an outrunner.
-Mike
Old Jan 11, 2011, 12:05 PM
mike_m2 is offline
mmerry2 on Youtube
mike_m2's Avatar
United States, MD
Joined Nov 2010
Upgrade options for HK EPO ParkJet
Here are the upgrade options I'm going to try with the HK EPO ParkJet:
Motor: HXT 2835 (380S) 2700kv Brushless Inrunner $18.31
ESC: H-KING 35A Fixed Wing Brushless Speed Controller $11.95
Extra Props: TGS Sport 4.75x4.75E Precision propeller $1.43 and TGS Sport 5x5E Precision propeller $1.43
Receiver: DSM2 Compatible Parkflyer 2.4Ghz Receiver $7.95
Old May 12, 2011, 05:21 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Awsome little plane.I changed the servo's to Corona 1.8 kg metal gear,added 1mm carbon rod on the control surfaces to avois flex in high speed turns and hooked her up with a 4.75x4.75 apc prop.chucked the 10A esc and added a 25A.running on 1300mah 3s lipo.lots of fun,but can surely catch you out if you don't pay attention
this is sooooo much fun and the quality isn't bad at all. here's a pic of what she looks like
chop stiX is offline Find More Posts by chop stiX
Old May 17, 2011, 05:19 PM
dhdsracer is offline
Find More Posts by dhdsracer
RC Man Child!
United States, CA, San Mateo
Joined Mar 2010
Hey guys,
Keep this plane in mind. I'm in the process of setting up a competition for this plane with hobbyking. I'd really like to see what people are doing with this platform. Stay tuned on the YouTube channel "hobbykinglive" and our twitter for more details. Expect some serious prizes too!
dhdsracer is offline Find More Posts by dhdsracer
Old May 18, 2011, 05:51 AM
antihero138 is offline
Find More Posts by antihero138
antihero138's Avatar
United States, NH, Dover
Joined Aug 2009
so I've got a bunch of 3s 1300 ,and I've been eying this plane. how does it fly with a 1300s? it seems like like it would be a bit heavy.
antihero138 is offline Find More Posts by antihero138
Old May 18, 2011, 09:37 AM
chop stiX's Avatar
Joined May 2011
Antihero.I fly mine with 1300mah 3s.and it goes!mine is quicker than most of the edf foam jets at my club.we clocked her at 120km/h..... I'm running with the motor provided and upgraded the esc to 25A.she flies awsome.very stable an lands like a gentel lady glider.she glides really well.look its not a beginners plane at all,but so much fun.my verticle is really good aswell.I bail way before she runs out of legs,but that's only because I cvant see anymorereally I would advise to get one.if u do,do not use the epoxy provided.its yellow an looks crap.I inserted 3mm carbon rod about 1/3 behind the leading edge aswell for some extra strenth in the wings.I also added 1.5mm carbon rods an the controle surfaces to prevent flex during high speed turns.GET YOURSELF one if u do oost it so we can see what it lloks like.I will post some more upclose pics. Of the changes I made
Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF smasher41 Foamy EDFs 1048 May 01, 2016 10:25 AM
Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s Stuart Warne Electric Warbirds 12 Jun 14, 2011 02:47 AM
For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly WRXronald Aircraft - Electric - Airplanes (FS/W) 3 Aug 04, 2010 10:03 PM
New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly CrashingDutchman Foamy EDFs 13 Jul 01, 2010 11:15 PM
Discussion HK's EPO F-16 WRXronald Foamy EDFs 5 Apr 11, 2010 02:47 PM
