Old Nov 26, 2010, 05:23 PM
KeithLuneau is offline
Find More Posts by KeithLuneau
define("BEASTMODE", "1");
KeithLuneau's Avatar
United States, LA, Moreauville
Joined Jan 2002
Suggestions for charging 6-cell 5000mAh Lipos?
Having used a cheap Thunder AC-6 for everything up to this point, it's time to upgrade... I've used the AC-6 with all my smaller packs, 2 and 3 cell 700-2200mAh stuff and never had any issues, it's been a great charger so far!
I recently built an electric Four Star 120 and need a bigger charger to handle it's battery. I seriously doubt I'll ever go any larger than it, so I don't need a lot of room to expand beyond this.
I need to charge a 6-cell 22.2V 5000mAh pack. A rate of 1C is fine, I never charge more than that anyway. Balancing is a must, it's very rare that I'll do a regular charge and not balance. I like to keep my packs balanced... I need to power from A/C, can be built in or an external power supply.
For the charger/supply together, I'd like to stay around $150 or less if possible. Can it be done?
KeithLuneau is offline Find More Posts by KeithLuneau
Old Nov 26, 2010, 05:35 PM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
Take a look at the iChargers. If you can really stick with one battery at a time at 1C, then even their low end chargers will do.
Dave H. is offline Find More Posts by Dave H.
Old Nov 26, 2010, 05:39 PM
Druss is offline
Find More Posts by Druss
Canada, AB, Edmonton
Joined May 2008
Thunder power 610C AC/DC charger, $120-$130 at most hobby stores. up to 6S and 7amps.
Druss is offline Find More Posts by Druss
Old Nov 26, 2010, 06:48 PM
Dave H. is offline
Joined Feb 2008
This is an 80 watt charger. He needs at least 126 watts to do 1C.
Old Nov 26, 2010, 07:19 PM
Druss is offline
Joined May 2008
Sorry you're right... wasn't thinking about the voltage since I use my 1010C for 6S.
The Hyperion EOS 0720i is a nice charger but it's $180. There are some decent ichargers, never tried one but have a couple of friends who have and like them. Too bad hobbyking is always backordered on them...
Old Nov 26, 2010, 07:26 PM
Dave H. is offline
Joined Feb 2008
Progressive RC usually has them in stock.
http://www.progressiverc.com/index.p...d4eed15ecb113b
Some of the US prices are higher HK's but the shipping may be lower and it's much quicker.
Old Nov 26, 2010, 07:27 PM
PinkYakRC is offline
Find More Posts by PinkYakRC
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
I have been using these chargers from Electrifly for a while now, better than any other charger I have ever had. I perfer these over more expensive ones. Simplle and easy to use! http://www.google.com/products/catal...d=0CEAQ8wIwBA#
PinkYakRC is offline Find More Posts by PinkYakRC
Old Nov 26, 2010, 07:45 PM
Dave H. is offline
Joined Feb 2008
It looks like that one has enough watts to do about half a C or less.
Old Nov 26, 2010, 08:07 PM
Joined Jan 2002
Wow, lots of good info! Thanks!
I hadn't looked into the iChargers much, but I will for sure.
What about a Venom Pro Charger Plus? I just noticed it for the first time tonight... They claim up to 8 cells and 7 amps, 150W and includes an A/C supply. Sounds good in theory, but I'd like to hear from someone that's used it... http://www.venom-group.com/itemdesc.asp?ic=0660
Tower has those for $150.
Old Nov 26, 2010, 08:55 PM
Dave H. is offline
Joined Feb 2008
I don't see a spec on the PS, but just based on its appearance (small black plastic brick with apparently no vents or fans) I would guess it would only be good for about 60 watts.
Old Nov 26, 2010, 09:45 PM
Joined Jan 2002
Good point... I'd likely have to end up with an external supply big enough anyway... So far it's looking like a low end iCharger is my best bet! Would a 106B+ and a 150W 15V supply?
http://www.progressiverc.com/index.p...1d46585bb264aa
If those worked out now, and for some reason I did want more power later, the charger is good for 250W, so I could grab a larger supply and go, right?
Old Nov 27, 2010, 05:41 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Another goodie is the ECO 6-10 from HK. 200 watts. Been using it for a while and it works great.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Nov 27, 2010, 05:53 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
That Triton has a history of unresolved problems, issues,complaints. Do a Search hetre and there are many unhappy owners.
IMO any charger under 200 watts is only for a rank beginner. One's second charger should be 200 watts plus and the more watts the the better. I got my first 200 watts charger five years ago and thought that I would never need anything bigger. These days 1,000 watt chargers are becoming fairly common. Nice thing about these is they can charge a larger cell count,capacity 5C charge rated LiP0ly in short order.
Charles
Old Nov 27, 2010, 07:47 AM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
The iCharger 206B and PS350 supply is the perfect combo. Well worth the few dollars more!!
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Nov 27, 2010, 09:13 AM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
A guy at my local field has iChargers, he does charge 6s 5,000mAg betteries with 'em. I'll ask, but I think he likes them.
Found WTB Protos 500/Trex 500 6 cell lipos invert Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 25, 2010 01:39 AM
Sold 6S Turnigy 30C 5000mah Lipos, 2 for $125.00 shipped, NIB fltekdiver Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 20, 2010 08:12 PM
Discussion JST Single cell charging by a 2 to 6 cell charger xxD-Manxx Batteries and Chargers 0 Oct 14, 2010 04:11 PM
Sold parallel charge and balance cables for charging up to 6 lipos at once ff954 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 27, 2010 11:09 AM
Sold 3 cell lipos 5000mah 30C $65 for both! edu01jose Cars - Cars and Parts (FS/W) 1 Jan 14, 2010 07:44 AM
