Old Nov 26, 2010, 04:16 PM
npowell28 is offline
Find More Posts by npowell28
Joined Nov 2010
red/red-black/black-red/black or black/red????
Simple question for a newbie. When i connect by 2s lipo to my esc do i connect teh wires red to red and black to black? Cheers dudes
npowell28 is offline Find More Posts by npowell28
Old Nov 26, 2010, 07:36 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Yep, red to red
bartricky is offline Find More Posts by bartricky
Old Nov 26, 2010, 09:19 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Go ahead and try red to black, but don't blame me when it fries itself
Xpress.. is offline Find More Posts by Xpress..
Old Nov 27, 2010, 12:17 AM
benski is offline
Find More Posts by benski
USA, WA, Port Angeles
Joined Nov 2009
Yes indeed, red to red, black to black.
benski is offline Find More Posts by benski
Old Nov 27, 2010, 03:15 AM
Joined Nov 2010
Thanks guys. Most helpful as usual. Right must go out and clean the white stuff off the drive.
Old Nov 27, 2010, 04:44 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Just to reiterate: Red is ALWAYS positive, black is ALWAYS negative.
EXCEPT in the case of brushless motors or brushless ESC MOTOR leads ONLY. These are constantly switching between positive and negative. Sometimes you HAVE to cross the colors to get the motor running correctly and sometimes they're all the same color.
Other than that......
Always. Universal standard. DO NOT EVER confuse or cross them; even if it's a nonpolar setup (like an incandescent light bulb) it's still good to keep them straight.
Balance taps are another animal entirely but you don't have to worry about that.
Ain't it fun to get way more info than you asked for?
Piece is offline Find More Posts by Piece
Old Nov 27, 2010, 05:45 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Just to clear the confusion: The colors on brushless systems mean nothing, and only on brushless systems. Put red to green, blue to red, green to blue, and you will be fine.
Old Nov 27, 2010, 05:54 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Personally I like to go red to yellow, black to white and red to black.
Or in the case of HK ESCs, black to red, black to black, black to yellow. Or black to black, black to black, black to black IN THAT ORDER.
Edit:
This is ONLY on the motor leads. The wires going to the battery STILL have to follow the red/red, black/black rule. That is VERY important.
Old Nov 27, 2010, 06:44 PM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
I know this is a little bit of a side track, but....
I had a bit of a debacle with some HiTec receiver wiring instructions just the other day. The wiring diagram was black and white and no "+ -" were anywhere on the page. I assumed that black on the diagram indicated the black (-) wires, BUT I WAS WRONG... Black on the diagram actually indicated "hot"(+) which in the case of our RC gear, is red.
This was quite confusing and the receiver was damaged because of it....Hitec is taking care of me, but a simple "+ -" somewhere in the instructions would have been too easy and saved everyone a lot of hassle.
It's always something in this hobby
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Nov 27, 2010, 10:10 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
Let's hope Hitec never starts making lipos....
Old Nov 28, 2010, 12:55 AM
E-reevo is offline
Find More Posts by E-reevo
E-reevo's Avatar
Joined Aug 2010
red red, black black
E-reevo is offline Find More Posts by E-reevo
Old Nov 28, 2010, 12:16 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
which receiver?
Old Nov 28, 2010, 05:10 PM
Joined Apr 2007
Twaz an Optima 7.....the SPC port wiring diagram.
Old Nov 29, 2010, 08:26 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Yes, red is usually positive and black usually negative or ground BUT DON'T COUNT ON IT. I have occasionally found items improperly color coded so I always check polarity before using any newly purchased equipment, especially batteries and ESC or BEC's. Remember, in the USA, for house wiring , black is usually the hot lead but, again, check to make sure.
Rodney is offline Find More Posts by Rodney
Discussion what Is black with white wire? red or black? HeliStyle Batteries and Chargers 7 Mar 16, 2009 02:02 PM
Black or Red SS Stand davelab Aerial Photography 8 Apr 20, 2004 02:33 PM
HB PDP 40 Red or Black vinican Engines 1 Mar 06, 2004 04:39 PM
Short, fat & yellow/black or red/white? Dereck Scale Kit/Scratch Built 7 Nov 13, 2003 09:57 PM
