![]() "The 3548-09 is a 5.8 ounce, 900KV direct drive outrunner brushless motor capable of producing 70 oz of thrust from a 3 cell Lipo battery and a 13 inch prop. It will also provide very nice performance with a 4-cell Lipo battery when using the TP 11x5.5E prop. The 3548-09 is close in performance to a 40 size glow engine, and will power 40 class trainers very nicely. I installed the 3548-09 in a 40 size trainer, and I used the APC 13x6.5E prop and two Power Up 11.1v 2200 20C Lipos connected in parallel with a Parallel Battery Harness. This combination provided a very good rate of climb and I could fly for over 20 minutes doing touch and go landings". I have it on the plane using Flightmax 30c 3300 3s, Hyperion 60a ESC with the APC 13X8E. I did not hook up the wattmeter yet but ran it up to full had tons of power and nothing seemed to overheat or even be warm. Gonna wattmeter it when I get home. I have other big motors if the numbers don't look good. |
Thanks for the info. So do you think I can use AC/DC adapter that has 12v DC and 5Amp output to charge 3s 3300mah 11.1v 30c? please correct me if I am wrong |
So if you have a simple 50W charger, that will put out as much as the charger can handle. What charger do you have or did i miss that? I have a cheap Mystery 50W charger hooked up to a 12V 5a switching PS. I have a 15A 12V old CB radio power supply hooked up to my iCharger 106B and I use a big marine battery hooked up to my iCharger 3016B and a 1.5A slow charger hooked up to the Marine battery. Marine battery and 3016B often stays in my car. |
For this summer i'll be buying a marine battery. I'm using a modified computer power supply and when i get over 5amps it cannot supply the needed power.
I just finished ordering the final Parts for my L4. 13x8 and 13x10 prop, extensions and a watt meter to test the setup. I should start my build in a few weeks
And I just confirmed that it uses 12v DC 5.0 Apm |
Here is the charger I use http://www.hobbypartz.com/60p-dyc-1004.html |
| Thread Tools | |
| Discussion NitroPlanes Guanli 401 J3 Piper Cub | gp1200x | Beginner Training Area (Aircraft-Electric) | 3 | Oct 10, 2010 11:46 AM |
| My Piper cub L4 conversion........... | stuart warne | Scale Electric Planes | 19 | Dec 30, 2008 07:00 PM |
| Climate Models L4 Piper | Tailspin Ken | Parkflyers | 0 | Aug 26, 2005 01:43 AM |
| Piper L4 conversion | F1Tom | Scale Electric Planes | 1 | Jan 14, 2005 03:59 AM |
