Old Nov 25, 2010, 08:39 AM
Anomalous is offline
Find More Posts by Anomalous
United Kingdom, Warks
Joined Oct 2010
Help!
TURNIGY Plush 6A esc won't go into program mode
hi. ive just finished my 2 cell parkzone ultra micro sukhoi brushless conversion, using an AP05 micro motor and the TURNIGY Plush 6A.
plugged it in today for first time and it runs well; so much power!!!!!!! on connection, it plays the correct beeps to indicate proper 2 cell count and arming.
but it will stubbornly refuse to enter programming mode following the instructions given. they are to switch on tx (dx6i), move throttle to max, then connect up the esc. it should play a special tune and then 7 tunes in order, each indicating a programming item that you can select by moving the throttle down at that point.
mine just gives the start-up and arming beeps instead, after which you can run the motor normally after you lower the stick. ive tried waiting. ive tried increasing subtrims, and increasing throttle setting in the dx6i menus. they dont work. even tried holding the throttle stick up hard against the stop with tape.
do you think its faulty, or wired up wrong ?
Anomalous is offline Find More Posts by Anomalous
Old Nov 25, 2010, 05:55 PM
meshyx is offline
Find More Posts by meshyx
meshyx's Avatar
Norway
Joined Feb 2010
You may need to calibrate the throttle range first.
To do this, have throttle at max then plug it in. Hear low-mid-high, mid-mid, then quickly move throttle to minimum. You should then get a long beep and it is armed. Unplug the ESC.
Now the ESC has learned your min and max throttle settings, and entering programming mode should work the way you describe it the next time you plug in the ESC.
If it still doesn't work, consider getting the programming card for the Turnigy Plush range of ESCs (and many others), it is excellent: http://hobbyking.com/hobbyking/store...idProduct=2169
You might find it in other stores as well, branded for Hobbywing Pentium or Exceed Volcano which I think are the same ESCs really (check this out before you buy.)
meshyx is offline Find More Posts by meshyx
Old Dec 04, 2010, 04:34 AM
Spadplanter is offline
Find More Posts by Spadplanter
I can TOO fly!
Spadplanter's Avatar
Southern Colorado
Joined Feb 2004
I have had issues with that card on a 2S setup. Plugging in a 3S battery makes it all work OK. Then you can fly with a 2S battery.
Spadplanter is offline Find More Posts by Spadplanter
Discussion Tmaxx .15 won't go into drive? RChelisrule Off-road Cars 2 Aug 30, 2010 04:47 PM
Sold NIP - TURNIGY Plush 6A /.8bec/6g ESC - $8 cutty01 Aircraft - Electric - Power Systems (FS/W) 8 May 07, 2010 10:30 AM
Discussion ANybody have a manual for Turnigy Plush 6A ESC? Little-Acorn Electric Plane Talk 6 Sep 09, 2009 04:50 PM
Sold Two Turnigy Plush 60 Esc's with Program Card Rudderman98 Aircraft - Electric - Power Systems (FS/W) 1 Jul 06, 2009 06:01 PM
Sold **NIB Turnigy Plush 60amp ESC with program card. Free shipping!!** ronrandle Aircraft - Electric - Power Systems (FS/W) 1 Jul 08, 2008 09:14 PM
