This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Nov 24, 2010, 07:43 PM
Sandancer is offline
Find More Posts by Sandancer
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Build Log
F4U Corsair: The Landing Gear & "GOODYEARS" by Robart!
Corsair-Robart Goodyears.m4v (1 min 44 sec)
With the combination of the 90º rotating struts and the split bay doors, the Landing Gear on the Corsair is quite unique for a model of this size.
The nifty little sequencer makes everything work in unison, and FMS has made it really easy to hook into the electrical system including the Y-harnesses that are included.
The only improvement I could find on the main LG was changing out the stock wheels and tires. I chose the Robart 2 3/4" Goodyear ribbed tires w/spoked scale wheels. I was hoping to use the 3" Goodyear's, but the tire was to big to fit in the wheel well, so I settled for the 2 3/4".
To get them to fit properly so the spoked caps would fit on the wheels, I had to cut 3/16" off the axle. I tried several different collar combination's, but none would allow enough clearance for the hub cap. I finally came up with a simple way to hold the wheels on the shaft with the use of an O-ring. First I took a 10-32 die and threaded it on the shaft as far as it would go just to get some kind of bite to retain the O-ring. I then installed 2 nylon spacers both on the inside and outside the axle hubs to center the wheel where I wanted it. Once done, I slipped the O-ring on, adjusted it so the wheels would spin freely (I spun 'em a lot to make sure the O-ring stayed in place)! After being assured it was going to work, I installed the 8-spoked hub cap, checked the air pressure, and I'm good to go!
After all the pre-fab was done, I took the wheels apart and sprayed them with Krylon Metallic Bright Silver.
UP-DATE 11/29/2010: I change out the O-ring I was using to hold the wheel assembly on the axle with a 5/32" push nut.
Sandancer is offline Find More Posts by Sandancer
Old Nov 25, 2010, 07:03 AM
mudman1959 is offline
Find More Posts by mudman1959
Live to fly... Fly to live
mudman1959's Avatar
The Mitt
Joined Oct 2007
Retracts...
Sandancer... Quick question, what brand of retracts are you using? And do they make ones that do not rotate? Looking at some for my scratch built 60" wingspan P51 I am building. Thanks for your help and Nice Corsair!
Mudman1959
mudman1959 is offline Find More Posts by mudman1959
Old Nov 25, 2010, 11:21 AM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Mudman1959
The up-graded version of these 90º rotation PZ 312's are the PZ 514's. They are none 90º rotating E-Tracts. I have a set on the P-47 and they work great, not to mention inexpensive compared to the DSR's I have on my FMS P-51.
Old Nov 29, 2010, 09:28 AM
dgfinch is offline
Find More Posts by dgfinch
Stone Mountain, GA
Joined May 2007
Where did the sequencer come from?
dgfinch is offline Find More Posts by dgfinch
Old Nov 29, 2010, 02:31 PM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
The sequencer comes with the plane. You can purchase one separately at PW-RC.
Old Dec 02, 2010, 12:31 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
man, looks 100% better with the robarts....very nice!
corsair nut is offline Find More Posts by corsair nut
Discussion Cute Little Corsair <<< "Cartoon Corsair">>> Slow flying model of the F4u Corsair D DaDesign Foamies (Scratchbuilt) 37 Jan 03, 2015 01:27 PM
Discussion Landing gear slips on landing Camm Electric Plane Talk 3 Nov 04, 2010 10:46 AM
Video Full Scale F4U Corsair takeoff rolls strafing runs and landing GregG Electric Plane Talk 17 Feb 29, 2008 08:07 PM
Question F4U Alfa Model Corsair landing gear blueangelII Electric Warbirds 10 Mar 24, 2007 07:38 PM
Sold GWS F4U Corsair with retractable landing gear shschon Aircraft - Electric - Airplanes (FS/W) 2 Mar 07, 2007 09:05 PM
