Old Jan 21, 2011, 10:30 AM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
resolder?
rclab1 is offline Find More Posts by rclab1
Old Jan 21, 2011, 11:35 AM
nexstarselect is offline
Find More Posts by nexstarselect
Azerbaijan FPV
nexstarselect's Avatar
Joined Nov 2009
Hello glassfox
You can do built in 900mhz and 1.3ghz reciver i can pay extra for this ?
nexstarselect is offline Find More Posts by nexstarselect
Old Jan 21, 2011, 12:10 PM
Derek_S is online now
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
I dont mean to answer for him or put words in his mouth, but Fu has already said he wont earlier in the thread. The idea is that your 1.2/900 groundstation will send the video through a 2.4 or 5.8 repeater and your goggles with receive that signal. You will be wireless still, and the groundstation can be anything you want
Derek_S is online now Find More Posts by Derek_S
Old Jan 21, 2011, 01:48 PM
Capy-Norway is offline
Find More Posts by Capy-Norway
Capy-Norway's Avatar
Norge
Joined Feb 2009
I just received the goggles from the mail man. They had finger prints all over them, even on the lenses.. I tried powering them on through the trainer port from my Futaba 10C but no success. After some cutting, ironing and re-soldering the connector, the glasses can be turned on but jiggling the plug cuts the power again. I can't thrust the glasses and they are therefore useless when powered from my Futaba.
Fu, I think it would be good for your business if you would send out new cables with new, better plugs for free to the needed ones.
Capy-Norway is offline Find More Posts by Capy-Norway
Old Jan 21, 2011, 03:32 PM
rclab1 is offline
USA
Joined May 2010
Capy-Norway
I agree with you on that statement..... I tried everything and
its still a "loose" connection between the [I]Foxtech connector[/I] and
the [I]Futaba trainer Port plug socket[/I].....
I need new connectors!
Fu, GlassFox please help us :-)
Old Jan 21, 2011, 07:05 PM
Videopilot
Derek_S's Avatar
Joined May 2009
Got mine today. I have to say so far I am liking them. My connector seems very solid. I can wiggle and pull, and it keeps a good connection. The picture is good, FOV is apparently better and wider than my trimersions. So maybe quality control is the issue. They receive my lawmate signal real nice from my 2.5 tx.
I can do a more detailed review later.
Old Jan 21, 2011, 08:47 PM
Guizmo12 is offline
Find More Posts by Guizmo12
Guizmo12's Avatar
Montreal, quebec, canada
Joined Jun 2007
Derek,
Be careful with the lawmate there is only 3 or 4 channels Exatly the same, the 7 is the best in my opinion... I didn't told you that...
Guizmo12 is offline Find More Posts by Guizmo12
Old Jan 21, 2011, 08:57 PM
Videopilot
Derek_S's Avatar
Joined May 2009
Well, a little more playing with these and I am liking them. They have only been on the bench, so that is far as I have tested. First let me say I got the black version, and have a futaba 9c and home-made pan tilt.
Pros so far:
1. Easy setup. Doesnt need lots of wires, and if you relay your GS signal or direct receive 5.8 or 2.4, it is great. It also includes proper cables for powering with a battery or AV in.
2. Simple menus. I found them surprisingly intuitive. No learning curve, counting lights, beeps, or whatever. EASY.
3. Compact. Beats Trimersions hands down.
4. Overall quality is nice. Not cheap looking, just somewhat plain, which I like.
5. Headtracker works well. Now this is a jewel. I have a DT3k which I just got and it works perfect, except it must face N or S. THis does not. Best I can tell, when it installizes, it 'remembers' the compass direction you are facing. Then, as you move your head, it follows. At a pause, it tries to calculate any error in the preceeding movement, and corrects it. It DOES NOT re-center to dead center (as already said and demonstrated). It centers to it's best approximation of where your head is currently facing. It does a pretty good job from what I can tell. If all else fails, it has a manual re-center as well.
Cons
1. Rubber is not really comfortable. Foam would be nice.
2. Strap is not great. Velcro style would be 100x better.
3. Color separation in some cases. This is an odd one, as it seems to mostly happen when looking at a black object. I can see a separation of blue and red on either side of a white OSD display object. This is not apparently a camera problem, as the menues of the goggles also have this. It seems to be a refraction/lense issue since I can move the goggles around my eyes and it disappears and varies at times. It is not too bad from what I can tell when looking at normally lit objects, just BLACk ones I think. I will have to test outdoors to verify.
Old Jan 21, 2011, 09:00 PM
Videopilot
Derek_S's Avatar
Joined May 2009
Originally Posted by Guizmo12 View Post
Derek,
Thanks, I will look back and make sure.
Old Jan 22, 2011, 07:11 AM
rclab1 is offline
USA
Joined May 2010
Fu, GlassFox,
can you give me a Link where I can purchase new connectors?
Mine has been iron pressed, cut and modified too just like
you mentioned, and it still is a Loose connection.....
my goggles keeps powering OFF automatically with a slight touch
of the connector and the futaba trainer port socket.
it must be a batch problem or Quality control issue
on those connectors only.
I don't trust mine to use for FPV....
Old Jan 22, 2011, 07:29 PM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
They should take care of this for you. You shouldn't have to purchase anything extra to get them working ok. Well, that's my opinion anyways.
twinturbostang is offline Find More Posts by twinturbostang
Old Jan 22, 2011, 08:02 PM
rclab1 is offline
USA
Joined May 2010
I need new connectors....
I just spent $450.00+ and I wont/cant' use these FoxTech Goggles
until I get the proper working 100% trust worthy connectors.
I cannot risk losing a plane worth over $1000.00
can anyone give me a LINK to buy new OEM connectors?
I cannot find a LINK anywhere.....
I tried contacting Fu/ GlassFox, but I didn't get an answer.
I'm sure this is just bad Luck batch for me
Old Jan 22, 2011, 08:51 PM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
rclab1
http://flytron.com/22-futaba-mini-square-plug.html
Guys, days ago i tested a Headplay goggles and there was something strange when you move the head,
the pixels become "visible" when i moved it,
is this effect something normal? it happends too with AIO goggles¿?
wallaguest1 is offline Find More Posts by wallaguest1
Old Jan 22, 2011, 09:41 PM
Guizmo12 is offline
Guizmo12's Avatar
Joined Jun 2007
What do you mean ''visible'' ?
Old Jan 22, 2011, 09:57 PM
Videopilot
Derek_S's Avatar
Joined May 2009
I flew with mine today. It was a somewhat bad day as I was getting bad interference and it was cold for poor me, but the goggles performed pretty well. I was happy!
Question Foxtech/BEV 2.4G, 5.8G Vtx reviews and queries aa78 FPV Talk 64 Oct 01, 2014 02:17 PM
For Sale Zurich Glasses Old style BLUE and GOLD NICE!!!!! Artsloper Aircraft - General - Miscellaneous (FS/W) 5 Dec 10, 2010 07:47 AM
Discussion camera signal causes "zoom in" effect on FOxtech CE OSD 1.2 AV OUT signal raschemmel FPV Talk 1 Oct 27, 2010 03:24 AM
Discussion Y6 from Foxtech - any more details? trappy FPV Talk 8 Jun 28, 2010 06:23 PM
