Old Jan 03, 2011, 08:59 PM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
was onboard recorded then? i dont find it that impressive to be honest
wallaguest1 is offline Find More Posts by wallaguest1
Old Jan 03, 2011, 09:01 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
I just recieved my FoxTech AOI goggles.
am impressed with the quality but I have not used
them yet. feels sturdy and a bit heavier than FatSharks Base
that I have. Also the FoxTech feels better made.
The "soft Rubber" seems to come apart from the goggles
real easy. Is that how yours are ?
rclab1 is offline Find More Posts by rclab1
Old Jan 03, 2011, 10:00 PM
Guizmo12 is offline
Find More Posts by Guizmo12
Guizmo12's Avatar
Montreal, quebec, canada
Joined Jun 2007
rclab1 yes this is why i've change it with foam.
walla, the cam is only a ccd killer.
will make an other vid with 480 tvl from foxtech in few weeks
Guizmo12 is offline Find More Posts by Guizmo12
Old Jan 03, 2011, 10:20 PM
rclab1 is offline
USA
Joined May 2010
I like this vid
http://exposureroom.com/members/glas...03afa3242aa48/
Old Jan 03, 2011, 10:29 PM
Joined Nov 2006
rclab1 you are trying to the rubber don't holds very tight ? they drop easily from goggles?
Old Jan 03, 2011, 11:41 PM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
Repost my question from last page...
Originally Posted by twinturbostang View Post
Pretty cool video! What are the parameters that specify to return the camera back to center? In other words, is there a certain central viewing angle where the servos are commanded back to center? Oh also, do you have to face a certain direction when flying? Some earlier versions of magnetometer headtrackers required you to face in a certain direction because they used 1 or 2 axis magnetometers. Is that the case here or are you guys using more advanced sensors (3 axis magnetometer)?
twinturbostang is offline Find More Posts by twinturbostang
Old Jan 04, 2011, 12:45 AM
spitfire_Doug is offline
Find More Posts by spitfire_Doug
spitfire_Doug's Avatar
Australia, WA, Carlisle North
Joined Jul 2008
You Dont have to face in a particular direction for the HT to work. As for the camera realignment, Im not sure what the go is, generally you can move your head around and have a good look, than when you return your head to the front and stay still for a few seconds it re-centers the camera. It only re-centers the camera if it is very near the centers already.
Regards
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug
Old Jan 04, 2011, 12:58 AM
tty044 is offline
Find More Posts by tty044
tty044's Avatar
Joined Aug 2008
So it doesnt have a button for recentering? And if you turn your head a little left and down and want this to be 'centered' position? What should be done if you want goggles to remember this position as center?
Regards
Michal
tty044 is offline Find More Posts by tty044
Old Jan 04, 2011, 01:03 AM
Joined Mar 2006
tty044: I *think* you just do a short-press on the power button. That's the reset. Long-press turns the goggles on/off. At least I think so. Someone who has them could confirm that.
spitfire Doug: I'm assuming you have these goggles. If so, next time flying can you do a test please? Do some normal pan/tilt, and then pan to the side a bit and hold your head position. See if it "adjusts" the camera angle to your position. I found some additional information (can't find it now to link to of course, lol) that states the magnetometer will do correction for gyro drift when your head is stationary. So maybe it doesn't need to be centered also for this to happen. Anyway, would like you to confirm this if you could. Thanks!
Old Jan 04, 2011, 04:20 AM
Joined Jul 2008
Yes short press on power button recenters.
Will give it a go in the morning .
Regards
Doug
Old Jan 06, 2011, 11:37 PM
SPG is offline
SPG
Find More Posts by SPG
SPG
Sydney, Australia
SPG's Avatar
Australia, NSW, Sydney
Joined Jan 2010
Hi All,
I'm using the AIO goggles with the DOSD+ and the goggles are cutting off a small part of the bottom of the display. Normally I wouldn't care but the DOSD displays the total current and LOS on the bottom so I obviously can't see it. The attached picture has a red line showing what has been cut off.
Any Ideas?
SPG is offline Find More Posts by SPG
Old Jan 07, 2011, 12:06 AM
tty044 is offline
tty044's Avatar
Joined Aug 2008
You can add borders to your DOSD+ layout. You can do it via PC or input channels.
Regards
Michal
EDIT: This can be done by SAFEZONEX, SAFEZONEY commands. All is described here.
Old Jan 07, 2011, 01:23 AM
Joined Nov 2006
solutions aside.
why goggles show a cropped image? even if its just a few pixels, they should not
Old Jan 07, 2011, 07:37 AM
SPG is offline
SPG
SPG
Sydney, Australia
SPG's Avatar
Joined Jan 2010
Regards
Michal
Cool. Thanks
Originally Posted by wallaguest1 View Post
solutions aside.
Good, Question.
Old Jan 08, 2011, 06:27 PM
rclab1 is offline
USA
Joined May 2010
"touchy" connection between Futaba Trainer Port and Connector?
....hey guys, Just wanted to know,
How sensitive is the connection between the
Futaba Trainer Plug and the
Trainer Port on the back of the RC Transmitter
if you wiggle the connection just a bit,
will the Goggles turn OFF ?
mine shuts the Goggles off?
Question Foxtech/BEV 2.4G, 5.8G Vtx reviews and queries aa78 FPV Talk 64 Oct 01, 2014 01:17 PM
For Sale Zurich Glasses Old style BLUE and GOLD NICE!!!!! Artsloper Aircraft - General - Miscellaneous (FS/W) 5 Dec 10, 2010 06:47 AM
Discussion camera signal causes "zoom in" effect on FOxtech CE OSD 1.2 AV OUT signal raschemmel FPV Talk 1 Oct 27, 2010 02:24 AM
Discussion Y6 from Foxtech - any more details? trappy FPV Talk 8 Jun 28, 2010 05:23 PM
