Old Nov 23, 2010, 09:05 AM
nippaero is offline
Find More Posts by nippaero
nippaero's Avatar
United States, ID, Nampa
Joined Oct 2009
Build Log
Peck Polymers Pietenpol RC Conversion
So here it is. I am using an AR6400 with a motor from a Parkzone Cessna. I am hoping to fly it this coming Sunday. I'll have some better pictures up soon.
Peck Polymers Pietenpol - http://www3.towerhobbies.com/cgi-bin...?&I=LXSBW6&P=M
Parkzone J-3 Cub Propellor - http://www.horizonhobby.com/Products...ProdID=PKZ3901
Parkzone Cessna 210 Motor - http://www.horizonhobby.com/Products...ProdID=PKZ3028
Spektrum AR6400 - http://www.horizonhobby.com/Products...odID=SPMAR6400
Video in post #18
nippaero is offline Find More Posts by nippaero
Old Nov 23, 2010, 12:37 PM
v2plus10 is offline
Find More Posts by v2plus10
Boise, Idaho
Joined Jan 2006
Bummer on the 6400/heat gun incident! I've done it. Heat shrink tubing works so well for making pushrods, but it does require planning!!
Randy
v2plus10 is offline Find More Posts by v2plus10
Old Nov 23, 2010, 01:35 PM
nippaero is offline
nippaero's Avatar
Joined Oct 2009
Luckily I had an extra AR6400. I was using my wife's little embossing gun from her craft stash. It gets pretty hot.
Old Nov 23, 2010, 07:13 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Originally Posted by v2plus10 View Post
Bummer on the 6400/heat gun incident! I've done it. Heat shrink tubing works so well for making pushrods, but it does require planning!! Randy
Here's what I do. Before you mount the pushrod/shrinktube/z-bend onto the Rx, shrink it so that you can barely, comfortably, adjust the length. Then after installing it, and adjusting, add just a tiny drop of medium CA on the point of a pin to one end of the shrink. If you need to readjust later, use a drop of debonder, wait a couple of minutes, then readjust.
356Jim is offline Find More Posts by 356Jim
Old Nov 23, 2010, 10:55 PM
nippaero is offline
nippaero's Avatar
Joined Oct 2009
Thanks for the tip. It was a pretty tight fit in there and I was having a hard time aligning the fittings before installation so I tried a shortcut and it got me. Oh well, I wont do it again.
Old Nov 24, 2010, 03:53 AM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Very cool! I built a peanut Pietenpol about 25 years ago for 2 strands of 1/8" rubber. I also had a Balsa USA (I think) one with an OS40 4 stroke. Believe me when I say it will fly a LOT better without the radiator there! Talk about the world's most effective airbrake. Is it rudder/elevator or have you gone crazy and added ailerons? What will the AUW be?
Stu.
stumax is offline Find More Posts by stumax
Old Nov 24, 2010, 08:59 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
I think mine should get the same treatment
MegaTesla is offline Find More Posts by MegaTesla
Old Nov 24, 2010, 01:43 PM
nippaero is offline
nippaero's Avatar
Joined Oct 2009
MegaTesla,
Love your Piet man. I really like your wheels. Did you make them yourself?
Old Nov 24, 2010, 01:45 PM
nippaero is offline
nippaero's Avatar
Joined Oct 2009
Stu,
No ailerons. Only rudder and elevator. I am not sure on the final AUW. My scale took a dump on me. I have been meaning to swing by harbor freight and pick up another one.
Old Nov 24, 2010, 03:19 PM
Team30 Micro EDF
MegaTesla's Avatar
Joined Apr 2004
Originally Posted by nippaero View Post
MegaTesla,
I got the wheels from a Nowlen Aero Bristol Scout kit that I bought from A2Z Corp. I built the Bristol Scout but soon afterwards the balsa in the wings became soft and because of all the wing flex it isn't flyable. Not sure what went wrong there
Old Nov 24, 2010, 03:57 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
If you want a less obtrusive engine you can always model the Pietenpol that is up at Old Warden:
http://www.flickr.com/photos/jamesbakerpics/5149974704/
epilot is offline Find More Posts by epilot
Old Nov 24, 2010, 05:16 PM
nippaero is offline
nippaero's Avatar
Joined Oct 2009
Yeah, it's pretty common for folks to use C-65's, 85's and Corvairs in their Piets instead of the old Ford motor.
Old Nov 26, 2010, 10:44 AM
nippaero is offline
nippaero's Avatar
Joined Oct 2009
Well. I am finished with this plane. I ended up having to put the battery way up front up in the cowl to get the plane to balance. I hope to fly it on Sunday. I will try to get a video posted. Final AUW is about 20 grams or .7 oz.
Old Nov 26, 2010, 10:54 AM
v2plus10 is offline
Boise, Idaho
Joined Jan 2006
Looks great..! Did you dope the tissue, or use something else....
Old Nov 26, 2010, 11:04 AM
nippaero is offline
nippaero's Avatar
Joined Oct 2009
I glued it on with purple UHU and put two coats of Aero Gloss thinned 50/50 over the top.
Build Log Peck Polymers Pietenpol Aircamper - Plantraco Conversion supercorgi Scratchbuilt Indoor and Micro Models 27 Dec 19, 2010 04:11 PM
Build Log Peck-Polymers/A2Z Baby Ace R/C Conversion v2plus10 Scratchbuilt Indoor and Micro Models 54 Jan 20, 2008 08:53 PM
Peck-Polymers Genesis Flying Wing DaleM Electric Sailplanes 5 Feb 19, 2007 04:06 PM
Peck Polymers "Mini Bell" conversion? CharleyRexom Electric Plane Talk 5 Dec 28, 2001 10:17 AM
