Old Nov 27, 2010, 11:08 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Originally Posted by hercdriver7777 View Post
No but Chris H seems to like it a lot. After watching those videos I posted I feel like I am already trying to force the plane into maneuvers using too much power. It is already way over powered and I don't think I will want to use the 6S setup. But you never know...
I am using APC 16/8e and Nanotech 5S 4000.
Double post. Something wrong with the network.
vienquach is offline Find More Posts by vienquach
Old Nov 27, 2010, 11:13 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
I assume a lower kv motor (420-480kv) on 6s-3000 might work too. Please correct me if I am wrong.
Old Nov 28, 2010, 01:31 PM
livinma1's Avatar
United States, GA, Lawrenceville
Joined Jun 2003
My plan is to run it on 6s 3000. What is a good hacker motor for this ?
livinma1 is offline Find More Posts by livinma1
Old Nov 28, 2010, 02:01 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
A40-12L with 16x8 prop, maybe
Old Nov 28, 2010, 03:31 PM
livinma1's Avatar
Joined Jun 2003
Okay.. Will keep that in mind. Thanks !
Old Nov 28, 2010, 03:44 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
I also have a Venom V50-410 kv (305g) purchased long time ago. A bit lighter than the Hacker A40-12L (345g). Pulling around 55A on 6s. That's about 1200w.
Vien
Old Nov 28, 2010, 04:32 PM
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
will there be a glow conversion kit option available similar to the 58" Extra?
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Nov 28, 2010, 04:40 PM
r/cdawg's Avatar
Grandville, MI
Joined Dec 2003
A40-14S/530kv might be another good choice. It's weight is 9.3 oz. compared to the recommended Torque 4016/500kv at 9.8 oz.
r/cdawg is offline Find More Posts by r/cdawg
Old Nov 28, 2010, 05:27 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
Then what size of prop on 6s ? Thought about going 6s on the 57" SC with that motor, but the kv seems to be a bit high.
Old Nov 29, 2010, 09:37 AM
bjohnson80's Avatar
Round Lake, IL
Joined Sep 2005
What do you guys think of the Motrofly 3625-800 on 4S for the Edge? Seems to be a very popular setup for the 3DHS 57" Extra. Looks like guys are getting 1150 watts pretty easy.
bjohnson80 is offline Find More Posts by bjohnson80
Old Nov 29, 2010, 11:13 AM
EXTREME FLIGHT's Avatar
Sugar Hill, Georgia
Joined Feb 2004
There will be no glow conversion kit for this model. I didn't want to compromise the lightweight construction in order to make the airframe capable of handling a glow engine.
It can be done but would require some work on the part of the buyer.
4S set-ups should work fine. Just understand that with 4S you are going to probably be pulling quite a bit more Amps and the size battery you might need to use to get acceptable flight times may negate any weight savings.
The 6S set-up I have been running uses a 15x6 XOAR and 3000 and 3300 mah packs. I get 6 minute flights with this set-up pulling 53 Amps. Most 4S set-ups are going to pull in excess of 70 Amps so I'd expect flight times with 3000-3300 4S set-ups to be considerably less. This of course depends on throttle usage, wind, batteries and other factors.
EXTREME FLIGHT is offline Find More Posts by EXTREME FLIGHT
Site Sponsor
Old Nov 29, 2010, 05:39 PM
vienquach's Avatar
Chicago, IL
Joined Nov 2009
I prefer 2 x 3s-3000 to lower the amp draw and good flight time.
Also have several 4s-2200 nano tech 25c that I use on the Slick 51". I could add 2s-2200 nano tech to make 6s-2200. Very light but quite short flight time.
That 6s setup is what I will use for Slick 59" / SC 57". Rimfire .55 (480 kv) with Xoar 15x7
Old Dec 02, 2010, 11:57 PM
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
extreme flight convert
Well I did it.. It wasn't intentional, but I sold every balsa plane I owen, except my EF 48" Edge, and 48" MXS.. Now I have my sights set on this beautiful Bird. I didn't plan it, but I'm hooked on EF. I really want a blue, and yellow 58" extra if they come back in stock?
Chris, Does it look like you'll be getting any Blue/yellow 58" Extra's, any time soon?
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Dec 03, 2010, 07:52 AM
Twisted Realm's Avatar
New Jersey
Joined Aug 2008
Oh boy, another one is hooked! Congrats on your love for EF Tim they truely are amazing balsa planes. Its good to support Chris and his team at EF I look forward to more amazing planes from them also.
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Old Dec 03, 2010, 08:25 AM
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
Tim
you have made the right choice...
fred
Flazo is offline Find More Posts by Flazo
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 8788 Today 04:19 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
