Old Apr 01, 2011, 10:11 PM
powerlines is offline
Find More Posts by powerlines
I am ready for HHAEFI!!
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
On 4S.. Should be just enough I would GUess.. . Pulled my 55'' Edge Good!!
powerlines is offline Find More Posts by powerlines
Old Apr 02, 2011, 03:22 AM
Ducati Mechanic is offline
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
I don't think 4cell will 3D very well? Should be fine for sport, but who wants to fly sport? Not me..
I flew it on 6cell, and it was crazy!!! I fly my 58" extra on 5cell, and it's just enough power(1000w 16x8 Xoar). I plan on sticking with that gear for my Edge...
This thing is a monster!!! Compared to the 55"... EXP's don't run on coolaid..
Ducati Mechanic is offline Find More Posts by Ducati Mechanic
Old Apr 02, 2011, 04:46 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
4s should be fine, like a 4s4000 pack. it will just be pulling a ton of amps, which is probably why the 6s is preferred...it is way cool
rcbirk21 is offline Find More Posts by rcbirk21
Old Apr 02, 2011, 06:31 AM
Joined Oct 2008
5 pound 3D plane on 4cell??
I'm always careful about recommending a setup that hasn't been done yet.. It's fine if someone has the gear and wants to try it, but allot of new guys take ower advice, and order expensive gear...
IMHO..unless you've done it? I wouldnt recommend it..
Old Apr 02, 2011, 06:34 AM
cbriggs11 is offline
Find More Posts by cbriggs11
Team Twisted!
cbriggs11's Avatar
United States, SC, Greenville
Joined Nov 2009
"exp don't run on cool aid". That s awesome and so true. Great statement
cbriggs11 is offline Find More Posts by cbriggs11
Old Apr 02, 2011, 06:42 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I bought the 60 as a backup for my 55" Edge, the weight is about the same so I figure the 4s with my current setup should work good. I may not be able to wait and just might put all the gear in the 60 and make the 55 my backup, if I do I'll post my results. But you never know between now and then if I come up with some extra money maybe I'll set it up with the recommended equipment and not worry about it.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Apr 02, 2011, 06:57 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
I run my 57" Extra on 4S and it's a great setup. I have a GR-60, ZTW 85 amp ESC, and 4S 4000 mah 40C batteries (about 35-40 bucks a piece). At about 80 amps I'm getting 1200 watts on a 15x6 prop. Everything comes down cool because the components were selected and designed around 4S. It works quite well if the all of the components match properly, but if you are running a 500 KV motor like the Torque (and a lower amperage ESC) with a huge prop it's probably a bad idea and you should stick with 5S or 6S.
cwojcik is offline Find More Posts by cwojcik
Old Apr 02, 2011, 08:15 AM
powerlines's Avatar
Joined Apr 2004
EHHH ehhhhehhhheee HHEEeeee HHEEEEe...
That is a good one coach!!!!
Old Apr 02, 2011, 08:21 AM
powerlines's Avatar
Joined Apr 2004
AND I appologize.. I had the GR60.. It was insane power on the 55 Edge and then the 58 Extra... and that was on 4S..
Old Apr 02, 2011, 08:29 AM
Joined Oct 2008
OK... I'll be interested to see? I do like a light setup..
I thought you would like that..
I'm just haven a little fun guys... I sip the coolaid from time to time..
Old Apr 02, 2011, 08:39 AM
powerlines's Avatar
Joined Apr 2004
Tim.. the Edge flew heavy on the reaper 60.. We had to put 2 servos in the tail to help it ballance... I think I would have liked it better with a lighter setup.. I flew someones at seff.?? Maybe Mlt.. he had the 45.. It flew better than mine.. lower power but perfect.. HECK I had a reaper 45 on a SIG cadet on 4S It was AWEsome.. not enough power to hover.. BUT not far from it.. IT would slowly back down!!!!
Old Apr 02, 2011, 12:58 PM
powerlines's Avatar
Joined Apr 2004
Does anyone on here need a Castle link?? FREE!! I have a cupon for a free one..
Let me know if you do!!!
I have one.. don't need one..
Old Apr 02, 2011, 03:42 PM
nsg is offline
nsg
Find More Posts by nsg
nsg
Yardley, PA
Joined Sep 2006
Tim - A lot of people (incl. me) fly the 3DHS 57" Extra on a 4s setup. You need a 750-800kV motor capable of 70-80A, e.g. a Motrofly 3625-800. I fly mine with 14x6 for about 1000 wt total, most people go for 15x6, about 1200 wt. The nice part about it is, you can double these 4s batteries for an 8s setup on a 65-72 plane for about 2kwt total. I'm going to go 5s (or 6s.. not sure) with the EF Edge, though.
nsg is offline Find More Posts by nsg
Old Apr 02, 2011, 08:39 PM
livinma1 is online now
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
Tim --- I was across the street from your job earlier today with the kids. We were suppose to be there earlier in the day and I could of stop over and chatted with you real quick.
livinma1 is online now Find More Posts by livinma1
Old Apr 02, 2011, 09:37 PM
stevelmaa is online now
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Curious as to some opinions here since we are talking setups on 4s. I had in the box a new Hyperion ZS 3025 10-Turn motor that I just put on a 57" 3DH Extra. I should have weighed it while I had it out but the specs say 6.95 oz's, add another ounce or so for prop adaptor and backplate, so roughly 8 ounces. Spun it up using a 15x7 Vox wooden prop with Rhino 3700 25c 4s battery and a Reaper 85 amp ESC and came out at 1150 watts at just around 85 amps. Thats after it settles down from initial peak. Could be an alternative for a real lightweight setup. I read that this ship flies best at around 1200 watts but maybe the weight being less would even that out. AUW is 4.5 Ilbs. My 2 concerns are:
1. The motor did get a little warm, 115 degrees after a couple minutes of running it at various throttle settings. Inflight airflow, maybe wind baffles may help this.
2. Would it be able to balance the big 60" Edge without adding noseweight. No sense in adding deadweight.
Haven't really made a decision yet on the powerplant but I'm not going to buy a new set of 5-6 cell batts when I have all these 4 cells. Just thinking out loud and curious as to any thoughts.
Steve
stevelmaa is online now Find More Posts by stevelmaa
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12563 Aug 31, 2016 02:48 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
