I think I'll stick to electrics at least up to the 60" size.
Ok. Rounding my gear up and getting ready to start the build.
I've ran into some VERY interesting numbers! With the recommended gear of motor/esc lipo and servos that EF recommends their total weight (not including the airframe) would be 1317grams BUT the weight of my Saito 91, 4 6965hb servos and throttle servo would be .... Ready for it..... 765grams!!! Over 500 grams lighter than the recommended E setup! I didn't include the fuel tank or nitro weight but its deffinatly under 500grams. So.... My nitro should, even after extra ca and maybe some bracing in key stress areas, and motor mount, fuel tank, and life battery it should be lighter than the E powered version!!! Wow! I might even go for a Saito 82 and save almost 100grams there too with little of any power loss! |
Burke, VA
Joined Sep 2009
Burke, VA
Joined Sep 2009
Now this you have to do some vids on. I know what you'll do with this plane and can't wait to see it. On mine I'm using 25gm servo's in the ailerons and rudder, and a 47gm servo on the elevator. The extra weight on the tail doesn't bother at all.
I wasn't going for oober light. I actually thaught it would be too heavy on e I held the 91 to the nose but I'm very suprized its so light.
I want glow. I don't like electric and don't have the money to get the setup, lipos and chargers. I hate waiting on lipos to charge and love fuel and fly. I live the sound and tuning. Baught this Saito 91 for $10 but I can get ahold of a nice hunnert as well. Ill get a big 6v 4200mah rx pack and that should make up the difference a bit. I can always add ballast. Even at 6lbs I think the 91 will rip it close to what a 5-6s setup would with a smaller dia prop. |
Its not ideal, sure. A little extra vibration and a larger prop ... But I chose 4 stroke because I have ALL 2 strokes and occasionally I like hearing a 4 stroke and I love how a 4 stroke rips a 4 pitch prop.
This is also my nice bird so I don't want a big sloppy muffler or big round head sticking out of its pretty cowling. |
That's parcially true. Yes 4s make more low end torque and give you a little more instant oomph but there is basically no top end. 2/3 and full are about the same. A 2s with a macs or CCP/mcp pipe will do the same but have way more top end that jut keeps giving and giving. Both are fine for slow floaty 3D hovering and harriering but when you put your big boy pants on and start doing the higher end maneuvers and high energy stuff a 4s haut doesn't make the power and shear amount of fast airflow over the tail and Ron's to make some maneuvers happen.
I like the performance of any 2s over any 4s but this is not my go-to 3D bird. Any one of my 6 profiles take that spot. This is my persicion plane. I want to practice my persicion stuff and not just throttle and stick bang my way around the sky. So the 4s it is sense I won't need the above 2s type performance. That's for the flatties with this one on 4s I can swing a 15/4 and rip that prop at wot and not fear over speed or flutter while carving some lines!
| Thread Tools | |
| New Product Extreme Flight 48" Edge 540T EXP! | hemituda | 3D Flying | 8693 | May 18, 2013 12:35 PM |
| Wanted Extreme Flight 48" Edge 540T EXP | FD Pilot | Aircraft - Electric - Airplanes (FS/W) | 7 | Jul 02, 2010 11:52 AM |
| Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! | EXTREME FLIGHT | 3D Flying | 21 | May 30, 2010 01:17 AM |
| Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP | LeeJ | 3D Flying | 13 | Mar 26, 2010 08:26 PM |
