Old Jan 28, 2013, 09:39 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Hey now.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jan 28, 2013, 09:07 PM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
Originally Posted by Luv3d View Post
Nice job Wingbreaker! I saw some nice rolling harrier practice- kept it going for a while too- great! The harrier is coming along nicely, as is the elevator. I haven't had a 51" slick, but had a 42", and it wing rocked until I got the wing fully stalled- you might be able to get a deeper harrier to make your wings more steady. It really makes harrier landings easier and will give you a better sense of control (at least it did for me). For the record, none of my EXP's wing rock in the transition...they are smooooooth....
Thanks for sharing, even if it isn't an EXP!
My harriers and elevators are hit or miss. sometimes they are perfect others it seems like I just can't get it locked. I'll try your suggestion. Thanks.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Jan 31, 2013, 07:46 AM
powerlines is offline
Find More Posts by powerlines
I am ready for HHAEFI!!
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
Try to not correct with ail and more with rudder!! Correcting with ail will cause wing rock.
powerlines is offline Find More Posts by powerlines
Old Jan 31, 2013, 08:04 AM
Video Juggernaut
Joined Nov 2003
makes sense, thanks.
Old Jan 31, 2013, 08:58 AM
gabrielisrael is offline
Find More Posts by gabrielisrael
Got the Slickness
gabrielisrael's Avatar
Seattle, WA
Joined Jul 2010
Find what angle of harrier position your plane likes the best. I have seen alot of people struggle with too much angle in the beginning. If you experience any wing rock, and EF airframes should have little if no wing rock, a slight touch on the rudder helps.
When turning, make sure you inside wing is slightly lower. If it is higher than the outside wing, it will not turn for you.
Lastly, CG can make a big difference. This is true for many 3D manuevers. You should experiment alittle with slightly nose heavy, neutral and slighty tail heavy.
gabrielisrael is offline Find More Posts by gabrielisrael
Old Jan 31, 2013, 09:16 AM
Video Juggernaut
Joined Nov 2003
I finally got my CG where I think it needs to be. All rock issues are me now. If I use little to no input besides throttle the thing is stable as heck in elevator or harrier. I'm just heavy on the thumbs so I'm sure it is just me needing to lighten up on the controls. I was using ailerons though so this was probably my biggest issue.
Old Jan 31, 2013, 10:58 AM
Aeroplayin is online now
Find More Posts by Aeroplayin
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I had trouble with this too until I finally asked Tom what I was doing wrong. He understand it so well and communicates the process so well that I felt like an azz waiting so long to ask him. Correcting with rubber, like powerlines said, is the main thing because it seems so natural to correct the wing rock with ailerons. But what's really happening is that the wings are 'swimming' more than they are simply going up and down.
As one wing stalls first, it experiences more drag, which makes it slower than the other wing, which speeds up from the plane yawing in the direction of the stalled wing. As with a full scale plane, if you use aileron to lift a stalled wing, the down aileron only creates more drag, which can make things worse.
The Rudder applied in one direction will yaw the plane in that direction, speeding up the stalled wing. Over compensation will slow the flying wing and cause it to stall if you're behind in the correction.
So the yawing from side to side speeds up or slows down a wing and causes the faster wing to fly and the slower wing to stall. This is what I mean by swimming as opposed to rocking -- there is forward motion involved, along with the up and down motion.
As far as angle of attack, pulsing the throttle with the elevator back will help increase the AOA and stall both wings. If both wings are stalled at the same time, the rocking goes away.
Forward motion tends to try to level out the plane again and one will will usually start flying first. Using vectored thrust from the prop over the up elevator will keep the tail down so that both wings remain in stall. Good throttle control and a nice big prop disk will help.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Jan 31, 2013, 11:39 AM
Video Juggernaut
Joined Nov 2003
throttle management is the hardest part of 3d IMO.
Old Jan 31, 2013, 11:42 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
For me I think it's inverted rudder managment.
Old Jan 31, 2013, 11:50 AM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Just remember coming towards you... You point the rudder stick the way you want the nose to go. Then the rest will come. After enough time you don't even have to think what stick movements to do, it just does what you want it to.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Jan 31, 2013, 01:50 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
And this is where time on the Sim comes into play. I spend all my time on the Sim getting to the point where I don't have to think about thumb input for inverted and KE flight anymore. When I have to think what my thumbs are doing, I get behind the plane and the only thing that saves me is that I'm still flying at least a mistake high. I have the addiction of two pilots to support, you know.
Old Jan 31, 2013, 02:01 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I agree. I got the KE's instinctive, and get the inverted down if I just do it for a bit of time. But sim did and continues to help.
We both have two pilots to support. And, like you, my son gives me tips now--good ones.
Old Jan 31, 2013, 03:11 PM
Got the Slickness
Seattle, WA
Joined Jul 2010
+1 on the use of the sim.
It just takes alot of practice..
Eventually you will want to do figure 8's for turning and control.
Old Jan 31, 2013, 05:09 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
What models do you fly in your sim sessions?
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Jan 31, 2013, 05:14 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
It also helps to use a pretty fair amount of expo to keep rudder movement minimal around center stick. This keeps you from over controlling in harrier as well, you have to use very little rudder usually.
jetinteriorguy is offline Find More Posts by jetinteriorguy
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12563 Aug 31, 2016 02:48 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
