Old Jan 16, 2013, 01:10 PM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
Great info guys- thanks for clarifying. I now recall hearing that info about 12" before. I glad none of my setups exceed that.
I will also look at the CC cap pack- good suggestion LW! Thanks.
Luv3d is offline Find More Posts by Luv3d
Old Jan 16, 2013, 09:27 PM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Well I did extend my ESC wires tonight and it made a world of difference. I had to snip back some from the tinned area so I guess I added a 2" 12g wire so now my overall ESC and battery length is just under 9" where it was 7-1/2" before. Hopefully no issues.
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Jan 18, 2013, 12:05 PM
Blucross is offline
Find More Posts by Blucross
Gravity is a cruel mistress...
Blucross's Avatar
United States, FL, Orlando
Joined Mar 2011
I am picking up a like new model from a fellow RCG'er tomorrow. I am stoked to add this one to my fleet. This plane and my 48 MXS are the only two I plan to take to the field for the next few weeks here.
I'm stoked, never had anything as big as 60" before. It's a RWB model with a Motrofly 4315-480 and ice lite 75 esc, hitec 5245's all around.
Blucross is offline Find More Posts by Blucross
Old Jan 18, 2013, 12:20 PM
On loan to Texas
Joined Oct 2005
Anyone use a metal screw with a bonded washer for their wing bolts? I use this on my 87" gas plane and the neoprene on the bonded washer prevents it from loosening. It is so much faster to install with a ball driver than the thumb screw.
Old Jan 18, 2013, 12:23 PM
On loan to Texas
Joined Oct 2005
Anyone have a picture on where they route their 2-wire antenna on a Futaba receiver. Great blessing for strength with all of the carbon, I just get worried with the antenna so close to it all though.
Old Jan 18, 2013, 01:15 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
I do that on the 64" MXS...good idea. I don't like thumb screws, mostly because I have forgotten to put them on once...
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jan 18, 2013, 01:27 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
How does using a metal screw instead help with that?
Lardog is offline Find More Posts by Lardog
Old Jan 18, 2013, 01:31 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Less of a pain, I guess. Get them in faster, don't have the issue of people talking with you.
Old Jan 18, 2013, 04:56 PM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
Generally there is a bonded washer with the bolt. Easy to install and the washer keeps the bolt from backing out. I have this on my AeroWorks 260; works like a champ.
Old Jan 18, 2013, 05:04 PM
Lardog is offline
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
You missed my point. I understand how they work and the benefit of their use over the awkward, sometimes hard to screw in plastic thumbscrews. I was questioning on how the use of the screw/lockwasher would help with regards to him forgetting to install the thumbscrew. I was just trying to get a little dig in, but I guess I just missed.. Oh well.
Old Jan 18, 2013, 05:11 PM
Luv3d is offline
Luv3d's Avatar
Joined May 2010
Lol! Got it now....sorry.
Old Jan 18, 2013, 08:19 PM
gabrielisrael is offline
Find More Posts by gabrielisrael
Got the Slickness
gabrielisrael's Avatar
Seattle, WA
Joined Jul 2010
If anyone has an airframe they are looking to part with (NIB or built), please let me know.
gabrielisrael is offline Find More Posts by gabrielisrael
Old Jan 19, 2013, 01:59 PM
On loan to Texas
Joined Oct 2005
Originally Posted by bryansifsof44 View Post
Posted this in the Owners thread... thought I ask here too.
About to program my 7245 servo deadband... is the best number 1 when running on 8.4 volt. BTW, these servos are a beast running HV fast, precise and powerful. I was getting a jitter on the rudder with no load on it, nothing a little piece of the fuzzy velcro didn't fix. I am running them at 8.2volts regulated through a CC 10amp BEC. Thanks
Edit: Also, do you guys use the overload protection? If so, what is a good setting.
So would someone please explain servo deadband. My Edge is ready to fly now but I did not maiden it today because I notice on one of my 7245's (elevator) that in the neutral position I can take the control surface and move it up and down and it looks like it has some play like gear lash but you can hear slight changes in the servo sound. Move the servo off of center and hold the stick there and there is no play what so every. So would programming the servo deadband help this? I have never programmed a servo before.
Old Jan 19, 2013, 04:31 PM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Programming servo deadband will help if they are not set consistently. I've never had this problem, but many others here at RCG have reported that the deadband isn't always set at a minimum, and is not consistent, on new servos. So, pick up or borrow a servo programmer. They are less than $30...I think I got mine for $22.
Old Jan 19, 2013, 05:43 PM
T Koffler is offline
Find More Posts by T Koffler
T Koffler's Avatar
USA, NY, Cayuga
Joined Feb 2008
Is anyone running the stock power combo? Just looking for some feedback.
TK
T Koffler is offline Find More Posts by T Koffler
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12483 May 26, 2016 09:07 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
