Espritmodel.com Heli Air
Old Jan 12, 2013, 03:55 PM
Santi
DaaBears's Avatar
United States, TN, Nashville
Joined Nov 2003
Originally Posted by bigroger View Post
I don't want to get into radio wars but at my club, especially on Sundays when it's busy there's always several planes smashed into the ground from altitude related to brown outs of lost signal.
It's always spectrum, jr, hitec radios every time.
Don't know why, but then again the Imac guys at my club run jr 2.4 but have never had issues except occasional loss if bind on setup of the plane in the morning.
Not sure what that's about... I've seen a a few signal drops in my days, equally among brands. But I will say I see about 10x more spektrum rx's and tx's out there on a daily basis, so it would make sense in theory to see a few more errors.
Similarly when people say they've read more hitec servo problems than other brands, usually it's because you'll see 100x more hitec servos out there than say savox or solar, but when 1 of 20 solar servos fail it's still way better than when 12 out of 2000 hitecs fail! (Disclaimer-no numbers are accurate)
The only radios I've ever been told to shy away from by the few dudes who have competed for years and always give me their honest unbiased opinions are the turnigy radios and hitec radios... They always tell me JR, Futaba, and Spektrum are the way to go with TX's... I used to have futaba, but damn they can get expensive and there weren't as many items available in the classifieds when I needed them!
My only guess for why you haven't seen a futaba fail at your club is there probably aren't as many futaba users, and the one's who do dish out the cash for futaba, probably set their planes up correctly. Lots of beginners use spektrum radios so you'll see more failures with them accordingly!
DaaBears is online now Find More Posts by DaaBears
Old Jan 12, 2013, 03:57 PM
ΜΟΛΩΝ ΛΑΒΕ
ecaa3d's Avatar
United States, WA, Olympia
Joined Apr 2012
We sort of have the opposite. Not a lot of brown outs, but the glider guys...one in particular, usually gets lost in the clouds.
His glider came spiraling down a little ways off and he was looking up locked into someone elses glider thinking he was still flying. For some reason ALES is really big at our club.
ecaa3d is offline Find More Posts by ecaa3d
Old Jan 12, 2013, 04:08 PM
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Most 2.4ghz radio issues, IMO are setup problems. ie. brownouts (inadequate power and unreliable BECs). I've flown mostly futaba, but almost have as much time with Hitec and only issues were user related mostly on the futaba in my early electric days. Hitec with the SPC virtually eliminates the chance for a brownout... Nice feature. Also have flown with guys with spektrum and if on the newer technology and setup right went without issues too. So I believe if you setup a system right all will be well, and I fly around a area with bad interference.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Jan 12, 2013, 04:10 PM
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
We have an unlimited ceiling... Tom has a funny story of the day he found the vertical range of the DX7 with a AR7000 Rx. Probably not that funny in writing so I'll spare you the details...
We've used Spektrum from day-one and have now accumulated no fewer than 15 receivers from the 6200 to the 9100. We actually had a brand new Futaba 8FG Super, but it just didn't feel right to either of us. Sold it, new in box, to a fellow club member. To be fair, we lost a very nice 25% Extra 300 that flew almost incomparable for 53 seconds before a signal failure caused its demise. It was a tough pill to swallow because it took a long time to assemble that plane. It turned out to be the Tx (DX7), and it took a while to figure it out since we never considered it. A fellow member is a Futaba fanatic, but he watched a 50cc plane disappear over the horizon (no pun intended) while shrugging his shoulders and throwing sticks in desperation. They all do it for one reason or another.
But, four years later, and the one major Tx failure, we still have original 2.4 DX7's and 9303's and still no plans for another Tx brand. The only other one we would consider, Futaba, flew one plane twice, and then found another home.
Aeroplayin is offline Find More Posts by Aeroplayin
Old Jan 12, 2013, 04:19 PM
Santi
DaaBears's Avatar
Joined Nov 2003
Correct--- almost all the issues I've seen with brownouts happen to people whom I know half-ass their setups... Not saying that's always the issue, but most of the time I believe it to be... Not too long ago a guy at my field had a plane fall out of the sky on him and I asked him what his timer was set at, he had none... Well, you could blame your radio, or you could blame the fact that you just flew your plane for almost 10 minutes without a timer!
Old Jan 12, 2013, 04:20 PM
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Yeah. Just for clarification, the vertical range of the DX7/AR7000 mentioned is very VERY high up. The plane, almost directly overhead, was a stick as I saw the trailing edge of the wings with a little thicker blob in the middle representing the fuselage. I wagged the wings back and forth to maintain a bit of orientation before eventually the smart-safe kicked in and the ailerons held last position for a second or two resulting in a few rolls when my stick was centered. It came back and I killed the throttle and let it stall and fall back into range before simply waiting for it to descend nose down for quite some time at idle (probably 45+ seconds). I remember it was all at full throttle, and after over 10 or 20 seconds of vertical climbing I could no longer hear the motor, which I found a really cool representation of how high the plane was because I can ALWAYS hear that motor when it's at full throttle. After that happened I continued climbing at full throttle for probably another 15 or 25 seconds... so it was waaaay up there. We don't have an altitude restriction at our field because we're not within 3 miles of an airport, so as long as we yield right of way to full scale when they do appear, we're all good!
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Latest blog entry: New Stuff!
Old Jan 12, 2013, 04:25 PM
Joined Oct 2011
But if you want all out range there was some testing using FPV and Hitec went about a third as far as the nearest competition. But unless you fly FPV all systems tested (with full range RXs) went further then the naked eye could make out.
Old Jan 12, 2013, 04:29 PM
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
This is a friend of mine a few years ago. He was a great guy and really bright, but kinda fell of the map about two years ago. 9303 and spectrum receiver. He was way out there:
FPV out past the end of the "Rope" (6 min 32 sec)
--Tom K.
Old Jan 12, 2013, 04:45 PM
Joined Oct 2011
Couldn't find the link I seen before with the results but anyways.
In RC Sport Flyer magazine December issue... Hitec came out way ahead in range. They ran out of line of site road way at 6.3 miles. Next closest system was Jeti at 4.7 miles. Spektrum lost contact at 3.95 miles. Not that most of us need that range.
Old Jan 12, 2013, 04:46 PM
Support your LHS b4 its gone.
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Isn't 3D about keeping it close. If your 3d plane is out farther than you can see, you are doing it wrong.
_OZ_ is offline Find More Posts by _OZ_
Old Jan 12, 2013, 04:52 PM
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Originally Posted by _OZ_ View Post
...you are doing it wrong.
--Tom K.
Old Jan 12, 2013, 04:54 PM
Santi
DaaBears's Avatar
Joined Nov 2003
Isn't 3D about keeping it close. If your 3d plane is out farther than out can see, you are doing it wrong.
+1, lol!
Old Jan 12, 2013, 04:56 PM
Joined Oct 2011
Ya probably not important to most of us but we were just discussing range and I thought it interesting.
Still couldn't find link but here is a little discussion on it.
http://www.rcgroups.com/forums/showthread.php?t=1803355
Old Jan 12, 2013, 06:57 PM
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Now this is funny, and usually the most common line I throw around at my club with guys complaining about their colour scheme and not being able to see the orientation of the plane.
"fly lower" I always tell them.
I'm amazed how high some of the guys fly. Circle flyers that get themselves a mid wing aerobatic plane because they want to get into aerobatics.
They see me do all that crazy shizzle, and because they can do a single role of their glow powered Ugly stick they think they are ready for a 50cc scale extra, or sbach etc.
They are so frightened of the things that they fly further away and higher then I can see clearly then complain about the poor colours of their planes.
LOL.......
I suspect the radio discussion about pure numbers is probably right. But would also flight frequency also come into it? I fly futaba 8FGS, had the 6EX before that and never had a glitch. Only fly electric setups, but compared to the average club flyers I would do 6-20 flights every time I go out, whether its to the club or the park or the backyard. the average club guys at my club will do 1 maybe 2 flights in a day and they are happy.
The number of trainee pilots of high wing glow powered things on buddy boxes that have the planes brown out and go in is very high in occurrence. Maybe its a setup thing, poor connections, dirty power, etc.......
I even heard the club President explain to a new pilot that you never let your Rx power get above 4.8V as extra volts will fry your Rx?
Maybe in the old days buddy but we is talking about 2.4GHz systems right?
bigroger is offline Find More Posts by bigroger
Latest blog entry: full scale
Old Jan 12, 2013, 07:22 PM
Fly for fun
LoneWolfRC's Avatar
Joined Nov 2011
Brownout is not a radio issue, but a BEC, battery pack, and/or servo issue.
LoneWolfRC is offline Find More Posts by LoneWolfRC
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 8693 May 18, 2013 12:35 PM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
