Old Dec 09, 2012, 02:51 PM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
Originally Posted by bryansifsof44 View Post
+1
But unless you increase resolution like you are... I think it is highly possible you will experience blowback with the 7235s on high speed rolls.
well, yeah, getting bevel to bevel at 80% was kinda surprise... im just not sure if i will not be to lasy to redo aeleron links before tuesday...
but why would those 7235 servos be... bad? at 7.4v they are rated as 4.40kg-cm, the same as 5245... at a blistering 0.08sec...
but granted, i wouldnt put them at mxs or laser...
rimaarts is offline Find More Posts by rimaarts
Old Dec 09, 2012, 06:03 PM
m0dest is offline
Find More Posts by m0dest
aka ECAA3D
m0dest's Avatar
United States, WA, Olympia
Joined Apr 2012
Originally Posted by Aeroplayin View Post
I had three ExceedRC motors... the Monster series. Had a 46, 110, and 160. The 46 and the 110 are still in the airplanes even though we don't fly them anymore... a Sig we use as a camera platform, and a H9 Frenzy that was my first electric conversion from a Saito 125.
The 160 threw magnets from day-one. They were supposed to be the E-flite knock-offs, I guess. I think the Tucon or the Rockets are the second generation of the Monster. A 465Kv with a 16x8 on 6S is certainly a good power setup, so if the motor holds up, it may be an inexpensive option. If not, a second motor means you should have bought the Motrolfly or the Torque from the beginning. This is why I don't do cheap motors anymore. They are never cheap, and you never get over the trust thing. It's like you are always waiting for the time that they go bad. We have been pounding the Motrolfly 480 for a year now.
The rocket motors are solid compared to the old monster motors. The motor I learned to 3D on is still as solid as the day I got it. Been nosed in a few times
I would go with this motor on 5s 4000mah with a 16x8 prop.
http://www.hobbypartz.com/86mc451-4120-515kv.html
m0dest is offline Find More Posts by m0dest
Old Dec 09, 2012, 06:08 PM
m0dest is offline
aka ECAA3D
m0dest's Avatar
Joined Apr 2012
The 5245s are like 76oz or something like that on 6v. Apparently people are getting blowback on 4.8v at 60oz. This would only be for full speed walls and full speed downlines to blenders. Stay away from those and you should be fine.
Walls are overrated in my opinion anyways.
7245s are solid as a rock and are fast enough. You'll be impressed if you are coming from a 5245.
Old Dec 09, 2012, 08:12 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
I thought they were something like 61oz/in at 7.4volts compared to 76oz/in with the 5245 @ 6volts. Run them at 8volts with a BEC and they will really be fast and probably stronger then the 5245s.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 09, 2012, 08:21 PM
Liberty10 is offline
Find More Posts by Liberty10
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
The 5245 are rated 76 oz/in. on 6V
7235 are faster but are 61oz/in. on 7.2V
Liberty10 is offline Find More Posts by Liberty10
Old Dec 09, 2012, 10:29 PM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Not strong enough
Are they rated for HV? If so then they may work for you at 8 volts
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
Old Dec 09, 2012, 10:33 PM
Joined Oct 2011
Yes they at HV
Old Dec 09, 2012, 10:52 PM
m0dest is offline
aka ECAA3D
m0dest's Avatar
Joined Apr 2012
Yeah but why screw around with chancing it? The 7245s are a LOT faster than the 5245s. Forget the numbers you can see it physically even at 6v. The find their position faster even back to center and should be all you need in terms of speed and resolution without chancing being underpowered.
The Holmans were running 3421s and they are pretty slow.
Extreme Flight 60 Extra 300 EXP.m4v (7 min 31 sec)
Old Dec 09, 2012, 10:59 PM
Joined Oct 2011
I was replying to a gentleman... I use the 7245s all around at 8.2volts regulated and haven't looked back with we'll over 100 flights
Old Dec 10, 2012, 07:00 AM
Ohio AV8TOR is offline
Find More Posts by Ohio AV8TOR
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Is anyone using a separate 2S battery to power the 7245's if so what capacity pack are you using and how many flights do you get on a charge?
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Dec 10, 2012, 10:17 AM
mp.stumpy is offline
Find More Posts by mp.stumpy
mp.stumpy's Avatar
Germany
Joined Dec 2010
I run the 7245īs in my 60" extra on a 2S Gens Ace 450mAh. I usually put approx. 100mA back in after one flight (6,5 minutes).
Greetings from Germany
Marcel
mp.stumpy is offline Find More Posts by mp.stumpy
Old Dec 10, 2012, 10:20 AM
On loan to Texas
Joined Oct 2005
Marcel
Thanks Marcell. So do you change it out every flight or squeeze 2 flights with it? Is it un-regulated?
Old Dec 10, 2012, 11:34 AM
m0dest is offline
aka ECAA3D
m0dest's Avatar
Joined Apr 2012
I've used a BEC at the moment at but ran it up to 7v. Only about 8 flights so far though.
No issues but I'd feel better with a 750-1000mah pack in there and is what I plan on using as soon as the weather clears up here a bit.
Old Dec 10, 2012, 12:16 PM
mp.stumpy's Avatar
Germany
Joined Dec 2010
Hey,
since i didnīt knew what the consumption will be i started to swap them with the main batteries... i just stayed with that. I have the same amount of 2S and 6S so i change every flight, itīs not that much work
Yes i run them unregulated.
Marcel
www.stumpy3d.de
Old Dec 10, 2012, 12:53 PM
Aeroplayin is offline
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
On a bigger plane (50cc size) with higher torque JR servos (380 oz./in) we use an average of just under 30mAh/min on each of two redundant batteries to an AR9100 Rx. This means that one 450mAh battery has a safe capacity of 360mAh, and so I would feel safe flying it about 6 minutes. 360mAh divided by 60mAh per minute equals 6 minutes.
If Marcel is using 100mAh in 6.5 minutes, then he is using 15.4mAh per minute, so using 360mAh of the 450 battery will take about 23.4 minutes, or 3 safe 6.5 minute flights.
I am now using one 2100mAh 2S Lipo in the 78 with five SC-1268SG servos but have no data yet, but will soon. It's 3.51 oz.
Aeroplayin is offline Find More Posts by Aeroplayin
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12508 Jun 22, 2016 03:25 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
