Old Dec 02, 2012, 10:32 AM
On loan to Texas
Ohio AV8TOR's Avatar
United States, TX, Benbrook
Joined Oct 2005
Originally Posted by generem View Post
Hi all. I got me a used blue n yellow edge about 2 months ago. It has the motrolfly 4315-714. Running on 4s 4000 GenAce packs. I was swinging a 15x7 xoar prop but Ken from Motrolfly said that as long as I keep my amp draw in check, the motor shouldnt have a problem with the 16x7 prop. At full throttle, I was pulling 102 amps so I dialed the Throttle EPA to 85% and it flies great. Static Amp Draw is about 93 amps but after 6 mins of flight times, the motor and esc are barely warm and I'm only putting back 2500 to 2700 mah back on each pack. I'm almost tempted to go up on my epa but I dont want to push my luck. I could use a bit more top end.. What do you guys think
What ESC are you using with this combo?
Ohio AV8TOR is offline Find More Posts by Ohio AV8TOR
Old Dec 02, 2012, 11:09 AM
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
Different Mfg. weight on similar rated batteries
I got some new 6S 3300mha batteries for my MXS. I've been using the Haiyins from the beginning and they work great. I don't recommend it but I have been very bad and not heeded the 2C rate but they still work like new. I just received 2 sky and 2 GForce lipos. I won't have a chance to use them for probably 2 more weeks but thought people might like to see the size and weight difference. I think it's interesting that a 3300mah 30C battery from 3 different mfg. are so variable in weight. 121g is allot of weight on a 60" airframe. That's over a 1/4 pound. (1/4lb = 114g)
Liberty10 is offline Find More Posts by Liberty10
Old Dec 02, 2012, 11:44 AM
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Great info... Thanks!
Aeroplayin is offline Find More Posts by Aeroplayin
Old Dec 02, 2012, 01:37 PM
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Woops
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 02, 2012, 01:42 PM
Joined Oct 2011
I'll add a couple for reference. Glacier 518g and GensAce 535g. Both with Velcro and Deans.Name: ImageUploadedByTapatalk1354477263.471056.jpg
Description: Name: ImageUploadedByTapatalk1354477279.121819.jpg
Description: Name: ImageUploadedByTapatalk1354477296.988990.jpg
Description:
Liberty10, what C rating are the sky's?
Old Dec 02, 2012, 01:50 PM
Joined Oct 2011
Liberty10 reason I asked us because I have some sky 3000 30C batts that weigh 497gName: ImageUploadedByTapatalk1354477802.204693.jpg
Description:
Old Dec 02, 2012, 02:18 PM
Yin & Yang
Liberty10's Avatar
Joined Jul 2011
All 3 battery's posted are 3300 30C, No velcro on the GForce or Sky's yet so add maybe 2g. to those. The GForce comes with Deans so I can use them straight up. The Skys come with polarized bullets and will get switched to power poles. I have a ton and the crimp tool for them. I left the deans on my airboss ESCs and use an adapter to connect power poles.
Old Dec 02, 2012, 02:37 PM
Yin & Yang
Liberty10's Avatar
Joined Jul 2011
Originally Posted by bryansifsof44 View Post
Liberty10 reason I asked us because I have some sky 3000 30C batts that weigh 497gAttachment 5344751
Now isn't that interesting.. Hobby partz list the 3300 at 519g and the 3000 at 502g
but a you can see...
Old Dec 02, 2012, 07:42 PM
Santi
DaaBears's Avatar
United States, TN, Nashville
Joined Nov 2003
Battery weights are almost always WRONG! I always ask someone who has one before I buy!
DaaBears is offline Find More Posts by DaaBears
Old Dec 02, 2012, 08:04 PM
Joined Oct 2011
I could see them being off weight but the smaller batt weighing more then the bigger that's weird.
Old Dec 03, 2012, 02:03 PM
United Kingdom, London
Joined Jul 2011
sooo! finally unpacked my 60 edge! yellow-blue)
a bit dissapointed in covering.. i was hoping to replace yellow on the bottom wings with white and (if i manage to source red bull vinyl) remove yellow top of the wings...
but meeeh, its beautiful the way it is so im still happy!! anyway covering was done much better than on my mxs! !
landing gear seems to be similar strength to my 57", so i should be happy!
only unpleasant surprise was... where is all carbon on landing gear plate???
yeah, i know, carbon is expensive, etc, etc, etc... but any of my 3dhs planes has simply bulletproof landing gear block!! in edge, well, i will fly it and see! (should i only ca it? or epoxy-fibreglass-gorilla glue whatever with it?)
it seems strange to see foam under turtledeck...
ooh! almost forgot! very nice touch is that everything except tail servo slots in covering is precut!
well... those was my unpacking-prebuild-preflight impressions!
rimaarts is offline Find More Posts by rimaarts
Old Dec 03, 2012, 02:13 PM
United States, PA, Philadelphia
Joined Dec 2011
No worry for the landing gear mount. It is super strong by design. You will break many CF LGs before the mount even gets a crack.
Vince_TT is offline Find More Posts by Vince_TT
Old Dec 03, 2012, 02:14 PM
Team Hillbilly (UK)
Space Bat's Avatar
United Kingdom, England, Cambs
Joined Oct 2011
Why are you worried about the LG area??
Don't you always say learn how to land he he
Anyway congrats on your purchase - a flying buddy bought one when we went to a show and he loves his....and it's so floaty it flies effortlessly
Space Bat is offline Find More Posts by Space Bat
Old Dec 03, 2012, 02:18 PM
Joined Jul 2011
well... let me put it this way... if on any of my 3dhs planes gear-lg plate outlives plane by far but on my 48 mxs im on my second repaired landing gear... is it me who needs to learn to land or is it plane needing stronger gear...
if you get one bad ESC (your first time buy on that particular company) and wrech your plane ,wont you think trice about buying esc again from them even if there is a lot of people with good reviews?
everything is in comparisons... and i said learn to land speaking about 3dhs planes, not EF...
Old Dec 03, 2012, 05:06 PM
I'm Ron Burgundy?
GravyRobber's Avatar
United States, MI, Kalamazoo
Joined Oct 2012
I finally maiden'ed mine today. Wind was right down the runway at 12G22. Not the best wx for a maiden flight, but I was sick of putting it off. Plane flew great, and only needed a couple clicks of trim. Definitely has rocket ship power with the 6S on the Torque/Airboss combo. I can't wait to have some better weather conditions so I can see how stable she really is.
GravyRobber is offline Find More Posts by GravyRobber
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 8693 May 18, 2013 12:35 PM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
