Old Nov 15, 2012, 09:39 PM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I have a 100A ESC, but unrestricted, it may hit 82A on the flight stand with a fully charged battery, but in the air, we never saw more than 70A with a 16x8 Xoar on 6S. I prefer headroom, but a good 80A ESC should be fine. I'd like to know more about Castle's new Talon 90. At $90, a 9A continuous output, and 3 oz, it seems like an option.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Nov 15, 2012, 09:49 PM
GravyRobber is offline
Find More Posts by GravyRobber
I fly. I'm pilot.
GravyRobber's Avatar
United States, TN, Memphis
Joined Oct 2012
Yea I was actually just looking at that. Anybody have experience with it?
http://www.castlecreations.com/products/talon.html
GravyRobber is offline Find More Posts by GravyRobber
Old Nov 16, 2012, 07:23 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I think Frankjp mentioned that he bought one for the 64 MXS his is finally assembling. I'll see him this weekend if he doesn't wander onto this thread today.
Old Nov 16, 2012, 10:36 AM
exeter_acres is offline
Find More Posts by exeter_acres
Extreme Flight Tech Support
exeter_acres's Avatar
Johns Creek, GA
Joined Jan 2005
Originally Posted by GravyRobber View Post
For a motor, I was thinking about this Hacker A40-12L
Probably be a bit too small......
alternate if going with Hacker is the Hacker A50-14XS v2
But.. Chris just walked in and let me know that the motors and ESC's have shipped...
and should be here mid to end of next week.
exeter_acres is offline Find More Posts by exeter_acres
Old Nov 16, 2012, 11:00 AM
m0dest is offline
Find More Posts by m0dest
aka ECAA3D
m0dest's Avatar
United States, WA, Olympia
Joined Apr 2012
That Hacker is anything but small. And it runs this setup cooler than my Motrolfly runs my Edge540.
You can't beat it on 5s.
That's my 2c
EDIT:
I would have gone with the power combo had it been in stock, especially after seeing the new mkII the other day on 6s 15x8 prop.
But I'm totally happy with the recommended Hacker.
m0dest is offline Find More Posts by m0dest
Old Nov 16, 2012, 11:15 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
That's my 2c
EDIT:
I haven't tried the hacker on 5s, I did try one on 6s and it was fine, but I wasn't blown away like I was with the motrofly on 6s with the 16x8... I haven't flown on the newer torque though.
I usually only use hackers if the other two aren't available at the time. Nothing wrong with them, just my 3rd favorite.
DaaBears is offline Find More Posts by DaaBears
Old Nov 16, 2012, 11:27 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
That Hacker is anything but small. And it runs this setup cooler than my Motrolfly runs my Edge540. You can't beat it on 5s.
Sure, and to put it into perspective...
The MKII is 500Kv, which means on 6S and 3.8v per cell, let’s say, and an 82% Kv efficiency, you’re swinging a 16 inch prop about 9350 RPMs.
The DM4315 is a 480Kv which means on the same 6S and 3.8v per cell, and an 82% Kv efficiency, you’re swinging a 16 inch prop about 8975 RPMs.
The A40-12L is a 410Kv which means on 6S and 3.8v per cell, let’s say, and an 85% Kv efficiency since I know these motors are a bit more efficient from experience, you’re swinging the same prop to only about 7950 RPMs. Use a 5S batter on the same setup and you’re down to 6620 RPMs.
The A50-14XS V2 is a 564Kv which means on the same 6S battery and an 85% Kv efficiency, you’re swinging a 16 inch prop about 10,930 RPMs.
Use a 5S battery on the same setup and you’re at 9110 RPMs, which means you’re generating about the same power (spinning the same prop to about the same RPMs) as the MkII and the DM4315 on 6S.
So good advice for only 2 cents.
m0dest is offline
aka ECAA3D
m0dest's Avatar
Joined Apr 2012
THis motor isn't rated for 6s. WHat setup was in the plane? I know I'm not pushing it on 5s 16x8 as it comes down a little over a 102 degrees f.
I have 4 brand new Haiyin 3s 3300 mah packs I could run in series. I may give it a shot.
Old Nov 16, 2012, 08:15 PM
I fly. I'm pilot.
Joined Oct 2012
Great news!
Looking forward to hearing the impressions.
Old Nov 16, 2012, 09:13 PM
WestColoFlyer is offline
Find More Posts by WestColoFlyer
Grand Junction , Co
Joined Sep 2010
I ran it on Align 550 running 4 full size digital servos and the FBL controller during beta testing it, never missed a beat,bec worked great etc. It's what I am putting on my MXS.
WestColoFlyer is offline Find More Posts by WestColoFlyer
Old Nov 17, 2012, 06:37 AM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
How do the motor wires hold up- aren't they plugged into this ESC? I think securing the motor wires was a concern of a few people....?
Luv3d is offline Find More Posts by Luv3d
Old Nov 17, 2012, 09:10 AM
Grand Junction , Co
Joined Sep 2010
Yes if your motor wires reach the ESC you can plug them right into the ESC by installing the connectors Castle sends with. From my experience I had no issues with the connectors trying to back out of the ESC, so I would think if your have your ESC and motor wires secured I dont see any issues.
Old Nov 17, 2012, 09:43 AM
I fly. I'm pilot.
Joined Oct 2012
Well awesome. Maybe I'll go with that setup. I see Tower is selling them for $77!
Old Nov 18, 2012, 08:43 AM
platnuim1 is offline
Find More Posts by platnuim1
United States, IN, Fishers
Joined Jan 2011
Axi motor
Originally Posted by JMProduction View Post
With my setup /AXi 4120/20, Phoenix Castle ICE 50HV, 3x HS-225MG, 1x HS-5245MG, ZIPPY Compact 2700mAh 6S 25C Lipo Pack/ is flying weight 2,45kg and with same baterry, but 35C is weight 2,5kg.
I have an Axi 4120/20 that I can get for cheap. Does anyone know about this motor? Are the mounting bolts the same as the Torque motors? Will this motors perform on 6s and will the 1 oz weight penalty make a difference?
Thanks!
platnuim1 is offline Find More Posts by platnuim1
Old Nov 18, 2012, 11:35 AM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Thanks!
Axis are great motors. I have a 4120/18 in a 59" Slick with an ICE 75, and it's awesome. Go with a 75 amp ESC and a 15x6 prop on a 6s3300 pack and I think you'll love it. Don't know about the mount, though. The bolt on prop adapter is the same as an Eflite Power 46 or 60, if you need one, and cheaper than the AXI mount.
AXI specs:
http://www.modelmotors.cz/index.php?...e=20&line=GOLD
Chuck
Chuck is offline Find More Posts by Chuck
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12483 May 26, 2016 09:07 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
