Old Aug 20, 2012, 01:27 AM
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
Be careful with flaperon spoileron mix setup.
I had one on another plane and forgot it was on and did a down line into parachute at low height. Let's just say the wings don't fly too well with both ailerons pointing upward.
Slammed it into the ground wot, ripped out rudder and broke the prop .
I disabled that mix afterwards
bigroger is offline Find More Posts by bigroger
Latest blog entry: full scale
Old Aug 20, 2012, 07:44 AM
Team WMPF
TMAC4123's Avatar
United States, MI, Grand Rapids
Joined Jan 2011
I like the new tourqe motor. Probably will go with that
TMAC4123 is online now Find More Posts by TMAC4123
Old Aug 20, 2012, 07:52 AM
Cow flaps?? What cow????
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
I have had great luck with the torque. I tried one on my 60 edge while my motrolfly was getting redone. It was awesome!!
powerlines is offline Find More Posts by powerlines
Old Aug 20, 2012, 08:20 AM
United States, VA, Berryville
Joined May 2010
I need some help with keeping my horizontal stabilizer to stay glued in. On Saturday was doing some harrier landings and must have jarred it lose and when trying to take back off she went about 3 feet up and smacked down hard knocking and busting up the gear plate . I am going to try and fix but need some options why I can't keep the stablizer to stay attached. Thanks Kelly
kellyzo6 is offline Find More Posts by kellyzo6
Old Aug 20, 2012, 09:28 AM
United States, CA, Sunnyvale
Joined Mar 2011
Originally Posted by Feliperc View Post
Can you explain me how to do it using JR x9503)?
Do I have to connect one AIL to aux in the Rx??
Thank you so much!!!
You need to go into Wing Type and change it from Normal to Flapperons. Left aileron goes into ch6, Right into ch2. Then u need to inh the flap swtich in Device menu so u don't accidentally bump the switch and have your ailerons become full flaps or spoilers. Then u need to mix flaperons to Elevator.
Vincent
vhuang168 is offline Find More Posts by vhuang168
Old Aug 20, 2012, 10:44 AM
Planes & Falconry my passions
Feliperc's Avatar
New York
Joined Mar 2010
Thank you so much.
Other question:
when I do up elevator both AIL have to go up, what about when I apply down Elevator? both Ail have to go UP as well?
Thank you so much for your time!!
Vincent
Feliperc is offline Find More Posts by Feliperc
Old Aug 20, 2012, 01:44 PM
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
If it's not staying in place, you may not have a clean enough joint to use CA glue, so here is what I would do...
Go to the LHS and buy some music wire about 12 inches long.
From the back of the plane, move the rudder to one side.
I'd also take the servos out of the empannage to do this.
Mix some 30 minute epoxy.
Through the hole in the back of the stab, I would use the music wire to spread the epoxy on the inside seam between the fuse and the stab.
Doing the top is easier than the bottom, but with the servos out, the bottom will be easier.
Do't use too much epoxy because you will be adding weight in a sensitive spot with regard to the CG.
30 minute epoxy will have time to settle into the seam between the fuse and the stab.
Let it cure for at least 24 hours, but if done correctly, the stab will break before the glue joint will.
Aeroplayin is offline Find More Posts by Aeroplayin
Old Aug 20, 2012, 02:01 PM
Joined May 2010
Thanks for the advice with epoxying the stablizer. I can't stand that I banged up such a beautiful airframe I went ahead and ordered a new body and cowl.
Old Aug 20, 2012, 08:16 PM
Play Dead!
Dead's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
The new one? What prop?
Dead is offline Find More Posts by Dead
Old Aug 20, 2012, 08:22 PM
Play Dead!
Dead's Avatar
Joined Jul 2003
When I do the aileron mix, I put them on a slider switch. I can cause the aileron to move from level to any degree of up position I want. Of course the ailerons still move properly for steering but the rest position is raised. I do not like it to ever push the ailerons down....
Old Aug 21, 2012, 12:50 AM
Joined Mar 2011
Thank you so much.
Other question:
Yes. I would start with a 15-25% mix to start then go up or down as you like.
Old Aug 21, 2012, 06:01 AM
Where's my orange kool-aid?
xzuberance's Avatar
Australia, VIC, Boronia
Joined Apr 2010
Hi All,
I took the plunge and ordered one. Gonna run a DM4315-480 with a lightened x-mount on it. Do I need standoffs, and if so, how long?
Thanks in advance guys.
xzuberance is offline Find More Posts by xzuberance
Old Aug 21, 2012, 07:25 AM
booboo71's Avatar
United States, OH, Jefferson
Joined Jul 2010
Originally Posted by xzuberance View Post
Hi All,
Congrats! You will be very happy you did! I used .5 inch squares of plywood that I made up.
booboo71 is offline Find More Posts by booboo71
Old Aug 21, 2012, 07:35 AM
booboo71's Avatar
Joined Jul 2010
If you got the motrolfly 4315 480 and dont like the 16x8 prop you can switch to 15x8 and this thing is still a beast! I was overshooting on slow turnaround maneuvers when bliping the throttle and switched to the 15x8 and it smoothed things out.
Old Aug 21, 2012, 07:39 AM
powerlines's Avatar
Joined Apr 2004
Yep!! I have gotten a wooded dowel rod about 1/2" dia. The cut to the size u need and them drill a hole in the middle. I have used up to 3/4" stuff.
And the 16-8 is the best for me. I did dial down my end points to not pull but 60a.
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 8693 May 18, 2013 12:35 PM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
