Old Jun 17, 2012, 11:37 AM
mbritt is offline
Find More Posts by mbritt
mbritt's Avatar
USA, IN, Fishers
Joined Jul 2007
Originally Posted by Aeroplayin View Post
Tom seems to assess things better in flight than I do just because he's a much better pilot. I know he likes the 3300mAh 30C Skys because he gets the same punch at the end of his 6 minute flight as he gets in the first minute, which I agree with. They are also about the same price... maybe a few dollars more than the Zippy's.
On the other hand, a 3300mAh capacity peaking near 70A needs just over 21C, and a Turnigy or Flightmax reading of 25C is a bit close IMO. I would not go less than 30C with a 3300. The 4000 will need a 17.5C so 25C should be fine, but I also have a problem with batteries that have a high discharge rate, and a low charge rate. The bottom line for me is that we just don't buy Turnigy and Zippy batteries anymore because of how Tom beats up batteries. We're using 5 and 6 cell Skys (3C charge rate) and Gens (5C charge rate) in the planes pulling up to 120A.
We're also testing another brand name at the 50C discharge rate and a bit lighter than the Skys and Gens but only have a 1C charge rate, and we don't really have enough data to pass any judgments yet. They do come down a bit warmer than the Skys which goes back to my original question about high discharge and low charge rates.
I also am getting to the 6:45 mark and a friend of mine who is really hard core wide open extreme flying the whole time
is at 6 min and the batteries are quite hot. So going to higher C should help that but it really doesn't extend flight time any correct? that's all about capacity correct? So i need to get 30c and at least a 3300 - 3700
mbritt is offline Find More Posts by mbritt
Old Jun 17, 2012, 11:45 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
I have 40c sky lipo and 25c gens ace, both get around 7 minutes but temp isn't noticeably different... Both come down warm. I'm using the 480kv motrofly with airboss 80. Even 25's on 3300 should handle 82 continuous amps.. My airboss 80 gets warm well before my batteries!
DaaBears is offline Find More Posts by DaaBears
Old Jun 17, 2012, 01:54 PM
mbritt is offline
mbritt's Avatar
USA, IN, Fishers
Joined Jul 2007
Anyone used the Glacier packs from EPBuddy?
Glacier 30C 3300mAh 6 Cell 22.2V LiPo Battery
http://epbuddy.com/index.php?main_pa...roducts_id=366
Old Jun 17, 2012, 05:03 PM
StormJunkie is offline
Find More Posts by StormJunkie
Whoooo!
StormJunkie's Avatar
Summerville, SC
Joined Jan 2009
So I'm finally ready to drop the change on the rest of my electronics. Will be going with a Ice Lite 100...As fro motor and battery, what's the preferred Motrofly number again? And as far as lipos, I will run 6s, but i've heard some folks have had minor issues getting the CG far enough forward. What's the preferred pack size that will keep it light and yet balance it right?
Thanks y'all! Can't wait to maiden it.
StormJunkie is offline Find More Posts by StormJunkie
Old Jun 17, 2012, 05:20 PM
DaaBears is offline
Santi
DaaBears's Avatar
Joined Nov 2003
4315-480
6s 3300 are perfect for 6.5-7 minutes
Old Jun 17, 2012, 09:49 PM
Feliperc is offline
Find More Posts by Feliperc
Planes & Falconry my passions
Feliperc's Avatar
New York
Joined Mar 2010
Im using skylipo, 40C 4400mah. I fly 8 minutes and I land with plenty of juice left in the pack. I think that easyly I could fly for 10 min but I only have about 4 cycles per pack so I dont want to push too much the batteries!
Feliperc is offline Find More Posts by Feliperc
Old Jun 17, 2012, 09:54 PM
DaaBears is offline
Santi
DaaBears's Avatar
Joined Nov 2003
Are you using 4400 6s packs??
Old Jun 18, 2012, 03:21 AM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
I just got one of their smaller packs (3s 1800mAh 30C)... And am very impressed with it. Weight, looks and performance compare to the Gens Ace in its size.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Jun 18, 2012, 02:28 PM
hidaven is offline
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
Edge for sale!
http://www.rcgroups.com/forums/showt...7#post21930429
hidaven is offline Find More Posts by hidaven
Old Jun 18, 2012, 02:30 PM
Aeroplayin is offline
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Are my eyes failing me or is the Sky 4400 40C 6S only 3.4 oz heavier than the Sky 3300 30C 6S? Can anyone weigh the 4400 40C 6S and let us know?
Aeroplayin is offline Find More Posts by Aeroplayin
Old Jun 18, 2012, 02:42 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Regardless, lighter flies better IMO.
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Jun 18, 2012, 07:04 PM
Whoooo!
Summerville, SC
Joined Jan 2009
6208, HS5245's, Ice Lite 100, 4315-480 all on the way...Now to make a battery choice...
Typically have flown my 42" Slick on 2200's, but considering picking up some 1800's so I can use them for this plane...hmm...What to do... That 6s Hyperion is just steep.
Old Jun 18, 2012, 09:21 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Right everyone, last post for me today before bed People over at the Extra 60 forum have persuaded me to go with this instead as I prefer low/slow 3D !
I'd be really appreciative if you could go over my proposed setup and make sure all is okay in terms of power and performance, flight times, amps, weight, esc amp safety, etc. (bear in mind I will be adding Aurora RC Andromeda lights depending on whether they are right size which will add about 150g to the plane):
Motor: Hacker A40-10L V2 or should I go with the heavier A50-14XS? How much difference will there realistically be?
ESC: Castle ICE Lite 75 or ICE Lite 100 (is the weight penalty worth it for the bigger ESC?)
Battery: 5S Thunder Power 3350mAH 65C
Connectors: Deans or EC5
Prop: Xoar 16x8 (about 65A draw and 1100W) OR 16x10 (73A draw and 1300W) (what's better and won't draw too many amps?)
External BEC: Caslte 10A
Servos: HS-7245MH running at 7.2V via external Castle 10A BEC
Thanks!
EDIT: Should I use HD wires or light wires for servo extensions? Right, off to bed now, haha!
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Jun 18, 2012, 10:00 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I'm not touching this, other than to say that you won't go wrong with any Hacker, Castle, Xoar, setup IMO, and that for the Extra 300, I'd probably go for more RPMs, meaning more cells, with a smaller prop, because the Extra really shines in high-speed aerobatics as opposed to the low and slow setups we use and prefer in the Edge 540. I'm surprised they didn't recommend the Torque 500Kv setup with the 15x7 APC on a 6S 3300mAh 30C battery.
Personally, I would like to see a video of someone flying any setup they recommend to me so that I could see how they fly that setup, before I invest in anything beyond the recommended setup. Also ask them for pictures of the motor on the motor mount so you can see how they installed it, and then a picture of the clearance between the cowl and the spinner's back plate.
Old Jun 18, 2012, 11:30 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Yes, all ur products are quality. I don't know those particular motors though. My thought is if you want low and slow then the 16" prop is perfect as that is what I use.
I would definitely get larger esc. Weight is not an issue with this plane. I would also use set up that allowed a 16" prop with 6s as aero has already stated.
I use the motrofly 4315 on 6s and 16" and it is awesome!
Also, the castle bec is good idea and the servos should rock!
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12483 Yesterday 09:07 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
