Old Jun 07, 2012, 05:51 AM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
Lots of people fly'em and lov'em here....
Luv3d is offline Find More Posts by Luv3d
Old Jun 07, 2012, 07:34 AM
evalith8 is offline
Find More Posts by evalith8
Let the hating begin
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
They have lasted on my 59 Slick & 60 Extra 300 but the Edge requires a little more travel to get a full 45 degrees & it seems to be taking its toll on the servos,they are not maxed out but close.The elevator & rudder servos have been fine.Im wondering if the 5245's will work out better?
evalith8 is offline Find More Posts by evalith8
Old Jun 07, 2012, 07:53 AM
mbritt is offline
Find More Posts by mbritt
mbritt's Avatar
USA, IN, Fishers
Joined Jul 2007
Originally Posted by evalith8 View Post
Ive had 2 225mg aileron servos go bad & Im thinking about replacing them with
5245mgs.I need a servo that will hold up,any suggestions?
Well I would use anything other than the Hitec 5245 lol. At this point I would use the Futaba S9070SB, the ATX 94820 (a little slower but center very well) or the Savox that Tom and Aeroplayin use. I have used the savox on my 48" with np and I like them in that application. I have not had the ones for the 60" but would be willing to try them.
mbritt is offline Find More Posts by mbritt
Old Jun 07, 2012, 07:54 AM
mbritt is offline
mbritt's Avatar
USA, IN, Fishers
Joined Jul 2007
The 225 and the 5245 are basically the same servo only the 5245 is digital. You will see no diff in travel
Old Jun 07, 2012, 07:56 AM
evalith8 is offline
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
Thats what I thought,IMO the 255's center well & are fast enough.If they were more durable they would be perfect.
Old Jun 07, 2012, 07:58 AM
evalith8 is offline
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
Which Savox servos are they using?
Old Jun 07, 2012, 08:06 AM
Aeroplayin is offline
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
1250mg
Aeroplayin is offline Find More Posts by Aeroplayin
Old Jun 07, 2012, 08:09 AM
EXTREME FLIGHT is offline
Find More Posts by EXTREME FLIGHT
EXTREME FLIGHT CEO
EXTREME FLIGHT's Avatar
United States, GA, Cumming
Joined Feb 2004
The new 7245 HV servo has been working really well. It has a much more robust case and drive train than the 5245, but it is also a bit more expensive.
EXTREME FLIGHT is offline Find More Posts by EXTREME FLIGHT
Old Jun 07, 2012, 08:17 AM
evalith8 is offline
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
Wow,those Futabas aint cheap,the Savox are 62.99,not bad I guess.If I switch to the Savox I would swap them out of my 60 Extra too.
Old Jun 07, 2012, 08:19 AM
evalith8 is offline
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
Same price as the Futabas.
Hey Chris,will the 60 MXS be avaliable by months end?
Old Jun 07, 2012, 08:22 AM
mbritt is offline
mbritt's Avatar
USA, IN, Fishers
Joined Jul 2007
Ya but the Futaba would be good for other applications in the future as well. Also no chance for blow back on the Futaba or on the ATX as they both have 90oz of torque @6v
Old Jun 07, 2012, 08:25 AM
evalith8 is offline
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
Good point,the 225 will blow back at full throttle high speed 4 & 8 point rolls,not much but it does roll a bit slower than at 2/3 throttle.
Old Jun 07, 2012, 08:30 AM
mbritt is offline
mbritt's Avatar
USA, IN, Fishers
Joined Jul 2007
If price is your issue then you might try the Savox or the ATX. I have a set of the ATX right now and they are good servos just a little slow but perform well.
Old Jun 07, 2012, 08:32 AM
evalith8 is offline
evalith8's Avatar
HAMPTON VA
Joined Dec 2009
Id rather pay extra for a better servo,price is always an issue but 30.00 extra per servo for better performance I can live with.
Old Jun 07, 2012, 08:39 AM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I have seen enough amazing things from the 60 inch EXPs on HV servos to seriously consider them, specifically the JR 3711. The Hitec 7245 seem to match up well to the JR 3711 specs on paper as far as HV alternatives and are $20 cheaper -- Tower discount will make them even less expensive -- for those that still have a place in their heart for Hitec.
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12547 Jul 24, 2016 07:44 PM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
