Old Mar 23, 2012, 08:04 PM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Originally Posted by Aeroplayin View Post
I have the Motrolfly 4315-480 with the G10 cross mount and the spacers are usually called white POM sleeves or long fiber nylon bolt sleeves. The main thing is to make sure they fit somewhat snug around the bolt shaft and provide a decent footprint for the motorbox. I think mine were about 8 to 10mm in diameter. The length needed from the cross mount to the firewall will be between 9mm and 10mm.
If you have the choice, get 10mm, but if you only have a Standard measurement option, use 3/8 inch.
You can also cut 3/8 or 1/2 diameter dowel to 3/8 of an inch long and drill a hole in them a little bigger than the bolt thickness.
You can also cut 1/2 inch square 3/8th thick plywood and drill a hole in them. None of these spacers need to be glued. Just slide them over the bolt and thread the bolt into the blind not..
G10? Guess I don't know what that mount is. My flying buddy just got the Edge and the 4315-480 without the fiberglass or lightened version. I am just trying to figure out the thickness of the spacer. Just wanted to confirm what the G10 cross mount.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Mar 23, 2012, 08:15 PM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
G10 is just a type of fiberglass sheet.
Pretty commonly used for printed circuit boards, or it used to be, at least.
Without the copper cladding, though, it comes in pretty handy for RC use.
Not as lightweight as CF but still pretty light, and strong.
C_Watkins is offline Find More Posts by C_Watkins
Old Mar 23, 2012, 08:26 PM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
The distance between my Edge's firewall and the back edge of the spinner's backplate is 2 and 3/8 inches, or 60mm, if that helps.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Mar 23, 2012, 08:50 PM
Joined Oct 2011
Thanks that helps
Old Mar 24, 2012, 08:11 AM
Elec 1800 is offline
Find More Posts by Elec 1800
Flying 2 Fight Cancer
Elec 1800's Avatar
corona, ca
Joined Feb 2011
I have the Hyperion DH16FMD High Voltage servos. When the servos are powered up with the linkage on, just by tapping on the rudder or the elevator they start to jitter bad. With the linkage off they are ok. When i connect 5v to them (off of esc) they dont do that as much. Also when i have the 7.4v connected directly and just by moving the sticks just a little bit (both rudder and elevator) they rock back and fourth fast. I went into the program software for them and and set the deadband width to the lowest setting and then to the highest setting and they continue doing the same. Here is the other thing. With the linkage on the servo but with out the nut on the bolt that holds the linkage to the servo arm it wont jitter no matter what voltage i apply but once i put the nut on and tightened it up it starts to jitter again
Elec 1800 is offline Find More Posts by Elec 1800
Old Mar 24, 2012, 08:39 AM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Sounds like you have a binding problem. Did you try a different servo to see if it does it too?
_OZ_ is offline Find More Posts by _OZ_
Old Mar 24, 2012, 08:54 AM
Elec 1800's Avatar
corona, ca
Joined Feb 2011
No I haven't tried a different servo. What happen is that I had ordered these servos but was sent the non High Voltage version of them so I was using power from esc and had no problems. I received these yesterday and just installed them and the rudder and elevator began doing it. I have problem with the ailerons
Old Mar 24, 2012, 09:04 AM
_OZ_ is offline
It's gone...
_OZ_'s Avatar
Joined Aug 2004
Based on this, it sounds like something is binding. Got pics or video of it?
Old Mar 24, 2012, 09:13 AM
Elec 1800's Avatar
corona, ca
Joined Feb 2011
I was about to put a video up but was running late for work. I will post some pics and vid later. On the rudder I installed a shorter servo arm than what was on there and it would jitter more. Just by picking the tail up a lil and letting it drop the rudder would go crazy. So u might think the linkage is binding.
Old Mar 24, 2012, 09:34 AM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Did you say you DO or DO NOT have problem with the Ailerons?
If no problem on Ailerons then it must be some sort of binding I THINK....
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Mar 24, 2012, 10:08 AM
Elec 1800's Avatar
corona, ca
Joined Feb 2011
No problem witht the ailerons only rudder and elevator.
Old Mar 24, 2012, 12:12 PM
Cabledawg1 is offline
Find More Posts by Cabledawg1
Cabledawg1's Avatar
USA, VA, Newport News
Joined Jan 2010
I had a similiar problem on the jittery servos. Ill bet it wont come down to a binding issue. Its the digital servo hunting for center.....can happen on less expensive servos. . You can either program the servo, or send them back. Swap out to an analog servo and Ill bet the problem goes away.
I had also read another solution about opening the servo case and cleaning something....but I dont remember what it was.
Cabledawg1 is offline Find More Posts by Cabledawg1
Old Mar 24, 2012, 12:16 PM
livinma1 is online now
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
Wow Ken is really really fast.. Already have my motrofly 4315 in my hands.. Talk about quick service.
Now I have to go get the 10MM standoffs. Anyone knows which metric screws I need ?
livinma1 is online now Find More Posts by livinma1
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Hmmm, intresting..... Then i guess when i get home i set the sub trims to zero on my TX and try to center the servos via program again and see what happens. I only have a spare HS85 for now that i will change out the rudder and then the elevator to see if it still jitters. Thanks
Old Mar 24, 2012, 05:21 PM
rod.d is offline
Find More Posts by rod.d
Account Closed
rod.d's Avatar
United States, OH, Groveport
Joined Feb 2009
I had a similar problem with their standard size ones:
Hyperion Atlas DH20-FTD flutter (0 min 45 sec)
There is a response video where someone put some foam in the gap of the surface, which dampens the effect. I discoevered that myself, but I didn't want to have to do that. I sent them back. It seems hv is the issue with them, even though they are rated for it. I think it is the length of the surface and the vibration that causes them to hunt for center.
rod.d is offline Find More Posts by rod.d
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12508 Jun 22, 2016 03:25 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
