Old Jan 31, 2012, 02:49 PM
Cabledawg1 is offline
Find More Posts by Cabledawg1
Cabledawg1's Avatar
USA, VA, Newport News
Joined Jan 2010
Im using the 225's on everything except the elevator. I have a TGY-390DMH on the elevator. The Turnigy is very smooth and centers perfectly. I dont have a problem with the 225's either...you really dont need digitals.
Cabledawg1 is offline Find More Posts by Cabledawg1
Old Jan 31, 2012, 03:24 PM
hidaven is offline
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
those turnegys look good! can i use those all around? and, will they fit all around?
hidaven is offline Find More Posts by hidaven
Old Jan 31, 2012, 05:42 PM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Can I glue to this?
I need to glue my Stab back into the fuse after removing. There is CA still on the stab as well as some covering. Can I just stick the stab back in and glue, or do I have to clean all of this out? If I have to clean it that is gonna be one arduous task I'm afraid
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Jan 31, 2012, 06:24 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Dremel will clean that up in seconds.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Jan 31, 2012, 09:29 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Yep. Just go SLOOOW.
Buzzed is offline Find More Posts by Buzzed
Old Feb 01, 2012, 08:17 PM
RCTyp is offline
Find More Posts by RCTyp
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
I have 225's from my donor plane and will use those. Once I get a few laps on it I may upgrade one or two.
After being out of this for a couple years I have had to get a new charger for my 5s, new CA, new Epoxy, and the connectors are different, and different extensions.... still have not flown.
RCTyp is offline Find More Posts by RCTyp
Old Feb 02, 2012, 10:48 AM
bigmoebbq is offline
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
couple of pics of the 60 a few days ago.
bigmoebbq is offline Find More Posts by bigmoebbq
Old Feb 02, 2012, 04:50 PM
hidaven is offline
Joined Apr 2009
Cabledawg1
ordered 4 of the tgy-390DMH servos. What servo arms do I need for all 4 servos? I want 3d range. Thanks Pal
Old Feb 02, 2012, 05:18 PM
Cabledawg1's Avatar
Joined Jan 2010
The arms are Futaba. Dubro makes some super strong arms for Futaba splines.
Old Feb 02, 2012, 06:24 PM
hidaven is offline
Joined Apr 2009
size?
Do I need long, extra long, HD? Thanks : )
Old Feb 03, 2012, 03:26 AM
Cabledawg1's Avatar
Joined Jan 2010
Im using a Hangar 9 Aluminum SX 1.5" Futaba arm on mine. Im hooked into the next to the last hole.
I believe the Dubro ones are these:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD668
The alum arms are $6.28 at wholesaletrains.com
http://www.wholesaletrains.com/Detail.asp?ID=200827661
So about $25 for a set vs $12 for the Dubro. When you go to a larger plane....the alum arms will go with you.
If you go the alum route...the ailerons are 1" ($5.52 ea) and the elev and rudder are 1.5"
They do come with the hardware for ball links , so you wont need to buy anything else.
Old Feb 03, 2012, 11:04 AM
mbritt is offline
Find More Posts by mbritt
mbritt's Avatar
USA, IN, Fishers
Joined Jul 2007
I have flown all the servos mentioned above.
Although I love Savox servos in general these will have blowback issues. At least on the stock BEC voltage. They center great and work well but blowback at speed kills them for me in this application.
The JRs center great, have more torque than the Hitec or Savox servos but also will suffer some blowback at very high speeds. This is a good option and if speed and centering are of utmost concern I think they are the best choice.
The Airtronics have the most torque and center as good or better than the JRs. They have zero blowback at at any speed but they are the slowest in speed. I can personally attest to the ATXs being bulletproof in this plane and I have been very happy with them.
Anyone know where I can get longer arms preferably aluminum for the Airtronics 94820? Is this a 23T spline? no one seems to say
mbritt is offline Find More Posts by mbritt
Old Feb 03, 2012, 11:26 AM
They Call him Dead!
Joined Jul 2003
Dubro sells A set of HD arms for the ATX. Tower has them. Have not seen aluminum but have not looked either
Old Feb 03, 2012, 12:53 PM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Futaba's fit on the Savox, for those who didn't know this already.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Feb 03, 2012, 02:57 PM
Columbia SC
Joined Feb 2005
Yep, Dubro makes a set specifically for ATX and the JR aluminum 1.5" arms with clamping splines should work too.
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12251 Yesterday 11:09 PM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 12:52 PM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 02:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 09:26 PM
