Old May 21, 2011, 06:51 AM
Ducati Mechanic is online now
Find More Posts by Ducati Mechanic
Some.. call him Tim...
Ducati Mechanic's Avatar
United States, TX, Austin
Joined Oct 2008
Mlt,
So sorry... That is a bad day..
I'm of to DE Throwdown.. I should get some good video..
Ducati Mechanic is online now Find More Posts by Ducati Mechanic
Old May 21, 2011, 06:57 AM
powerlines is offline
Find More Posts by powerlines
I am ready for HHAEFI!!
powerlines's Avatar
United States, GA, Cochran
Joined Apr 2004
Have Fun Dude.. get lots of GOOOd pics!!!
and some GOOd flights!!!!
powerlines is offline Find More Posts by powerlines
Old May 21, 2011, 10:27 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Oh Mike!!So sorry bro.2In one day sucks esp them both being new..Sorry man..Ouch.Hope you get back on the horse soon.
Manta1 is offline Find More Posts by Manta1
Old May 21, 2011, 11:29 AM
wantoofly is offline
Find More Posts by wantoofly
wantoofly's Avatar
United States, TX, Navasota
Joined Apr 2009
MLT, sorry to hear. That sounds like my luck.
wantoofly is offline Find More Posts by wantoofly
Old May 21, 2011, 12:00 PM
nsg is offline
nsg
Find More Posts by nsg
nsg
Yardley, PA
Joined Sep 2006
Originally Posted by MLT67 View Post
Well I guess I have the honors of being the first one to crash their 60" Edge. ..
MLT
Sorry to hear that.. but then again, you now have equipment for two new planes.
Maidened mine today, finally. Very impressed.
nsg is offline Find More Posts by nsg
Old May 21, 2011, 12:25 PM
livinma1 is offline
Find More Posts by livinma1
livinma1's Avatar
United States, GA, Buford
Joined Jun 2003
[QUOTE=Tim Semeraro;18287008]Probably around then.. Are you guys coming?
I intended to but had a 18 hour work day yesterday which put a damper on everything I had planned.
livinma1 is offline Find More Posts by livinma1
Old May 21, 2011, 02:49 PM
MLT67 is offline
Find More Posts by MLT67
Joined Nov 2005
Thanks guys. I pulled all the electronics and the elevator servo was definitely bad - not only was it locked up, when I powered it up to test the servo got very hot and you could smell something burning. I went with the Hitec 5245's all around so I'll be calling Hitec on Monday to see about getting a replacement servo
I'll be picking up a new kit soon - the 60" Edge will be my go-to plane and I can't see myself NOT having one in my hangar.
MLT
MLT67 is offline Find More Posts by MLT67
Old May 21, 2011, 02:50 PM
Balsa Breaker is offline
Find More Posts by Balsa Breaker
Balsa Breaker's Avatar
United States, MI, Lambertville
Joined Feb 2011
Guys this is my first time buying Xoar props, and my question is the mounting hole is larger than the shaft on the Motro Fly and there are no spacer that come with the prop. The two spacers that came with the motor don't fit. What do you do?
Balsa Breaker is offline Find More Posts by Balsa Breaker
Old May 21, 2011, 03:05 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Use on of the APC spacers that come with every APC prop and drill out the XOAR to fit that spacer.
Fill hole and redrill. Fine some type of spacer to put on the shaft.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old May 21, 2011, 03:10 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Well I guess I have the honors of being the first one to crash their 60" Edge. It was my 11th flight, and I was doing some low harriers but the one time I decided to gain alititude, the elevator servo locked up on me. I had rudder, aileron and throttle control but no elevator. Needless to say she went in nose first from about 30' up at about a 60 deg angle.
The plane is a total loss - even the aluminum back of the spinner was bent. The Lipo seems fine but I'm concerned about the motor and ESC because the prop kept turning long enough to really twist the wires between the motor and esc and the esc and the battery. Also I checked the elevator servo and it is locked up at a slight down position and it won't move at all. I went with Hitec 5245's all around and this is the first time I've ever had an issue with a Hitec servo much less lose a plane over one.
What makes this worse is about an hour earlier I totaled my 48" Extra because the rudder servo locked at full right rudder. Not a good day
MLT
Too bad man, that sucks about as bad as it can.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old May 21, 2011, 05:34 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
Well my buddy maidened his edge today and crashed it on the 3rd flight due to orientation.
The motor was buried into the ground. That was about from 25 feet up nose first.
Well atleast the first flight required 2 clicks of up elevator and no aileron trim what so ever. KE was almost hands off. Checking now for a replacement airframe for him.
He was running it on 6s 5000 packs.
@ Extremeflight - Checked the site says all gone is that accurate. Or would you have a RWB hanging around. LMK
Old May 21, 2011, 05:53 PM
vipul is offline
Find More Posts by vipul
Copiague, NY, USA
Joined May 2000
ok guys, I just realized that I had the Torque 4014T-570 instead of the 4016T so question is whether any of you recommend this motor on 6S 3300 or not? Ltt me know, otherwise I will have to buy a new motor.
vipul is offline Find More Posts by vipul
Old May 21, 2011, 06:08 PM
livinma1 is offline
livinma1's Avatar
Joined Jun 2003
The 4014T is rated up to 5S spinning either a 14x7 or a 15x6 not sure if you can go 6s on it.
Old May 21, 2011, 06:14 PM
powerlines's Avatar
Joined Apr 2004
I would think it would be fine.. May not be balistic like 6S But I bet it would be good.. a touch lighter.. .. I would try it.. BUT.. I never go for the norn.. I like the light weight setups... I like just enough power to pull out of a hover or to get you out of trouble..
Old May 21, 2011, 06:36 PM
vipul is offline
Copiague, NY, USA
Joined May 2000
Oh no I just bought 3 6s batts and noticed I have the old airboss 80amp only rated for 5s ... Anyone looking for a motor and speedxontrol.
New Product Extreme Flight 48" Edge 540T EXP! hemituda 3D Flying 12483 May 26, 2016 09:07 AM
Wanted Extreme Flight 48" Edge 540T EXP FD Pilot Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2010 11:52 AM
Discussion Daniel Holman puts the new Extreme Flight EDGE 540T EXP through the wringer! EXTREME FLIGHT 3D Flying 21 May 30, 2010 01:17 AM
Discussion 42" AJ Slick or 48" Extreme Flight Edge 540T-EXP LeeJ 3D Flying 13 Mar 26, 2010 08:26 PM
