This thread is privately moderated by The Don, who may elect to delete unwanted replies.
Old Nov 21, 2010, 08:59 AM
The Don is offline
Find More Posts by The Don
Trader Rating: 688
MA Indoor FreeFlight Columnist
Willoughby, Ohio
Joined Jan 2002
Trader Rating: 688
Sold
Jpower 50mm EDF power upgrade.
I have 5 of these 50mm EDF units. They have been fitted with a special 6000KV inrunner and on 3S produce about 320 watts (~31 amps). These will be a great power upgrade over the stock power system which is about 160 watts or so. NOTE: You will need a bigger ESC and ipo. This setup pulls about 31 amps so you need an ESC for that amp draw and a lipo that can supply the required amps. I have test run each one of these 5 units and they are all in the same power range.
Asking $30 each shipped for one, if you want more than one each additional will be $25 each.
I also have some extra 50mm fan units. These are NOT the stock Jpower 50mm fan units but are very close. The rotor is designed as a press fit for a 2mm shaft motor. So you may need to drill out the center hole depending on what motor you are using.
Fan units are $6.50 each plus $2.50 flat rate shipping if bought separate from the motor fan combo listed above. If you are buying a motor fan combo then no extra shipping to add a spare fan unit.
Don
The Don is offline Find More Posts by The Don
Old Nov 21, 2010, 09:21 AM
Mike_eee is online now
Find More Posts by Mike_eee
Trader Rating: 80
Quest for Speed!!!
Mike_eee's Avatar
Fremont,CA
Joined Aug 2005
Trader Rating: 80
pm sent!!
Mike_eee is online now Find More Posts by Mike_eee
Old Nov 21, 2010, 10:26 AM
Bajora is online now
Find More Posts by Bajora
Trader Rating: 361
KA6KHM
Bajora's Avatar
Joined Sep 2004
Trader Rating: 361
PM sent for one
Bajora is online now Find More Posts by Bajora
Old Nov 21, 2010, 10:41 AM
Trader Rating: 361
KA6KHM
Bajora's Avatar
Joined Sep 2004
Trader Rating: 361
Payment sent for one setup ... thanks Don
Old Nov 21, 2010, 10:50 AM
Trader Rating: 80
Quest for Speed!!!
Mike_eee's Avatar
Fremont,CA
Joined Aug 2005
Trader Rating: 80
Originally Posted by Mike_eee View Post
pm sent!!
payment sent for one!
Old Nov 21, 2010, 10:52 AM
Vasy is offline
Find More Posts by Vasy
Trader Rating: 28
Vancouver, Canada
Joined May 2007
Trader Rating: 28
pm.
Vasy is offline Find More Posts by Vasy
Old Nov 21, 2010, 11:29 AM
The Don is offline
Trader Rating: 688
Willoughby, Ohio
Joined Jan 2002
Trader Rating: 688
2 fan/motor combos left
Don
Old Nov 21, 2010, 12:46 PM
Tom Rouch is offline
Find More Posts by Tom Rouch
Trader Rating: 27
United States, CA, Los Banos
Joined Apr 2000
Trader Rating: 27
Put me in for one Pm'ed
Tom Rouch is offline Find More Posts by Tom Rouch
Old Nov 21, 2010, 01:06 PM
BlueSkyRiderX is offline
Find More Posts by BlueSkyRiderX
Trader Rating: 48
wine country wing nut
BlueSkyRiderX's Avatar
United States, CA, Sonoma
Joined Mar 2005
Trader Rating: 48
I will take the last EDF/motor combo please.
BlueSkyRiderX is offline Find More Posts by BlueSkyRiderX
Old Nov 21, 2010, 01:32 PM
Trader Rating: 48
Joined Mar 2005
Trader Rating: 48
Payment sent.
Old Nov 21, 2010, 01:33 PM
The Don is offline
Trader Rating: 688
Willoughby, Ohio
Joined Jan 2002
Trader Rating: 688
All systems sold
Sold Jpower 50mm EDF fan units with motor UPDATE: 1 left The Don Aircraft - Electric - Jets (FS/W) 11 Oct 23, 2010 11:53 AM
Sold 50mm EDF fan units from Jpower micro EDF ARFS The Don Aircraft - Electric - Jets (FS/W) 2 Mar 30, 2010 07:06 PM
Sold Jpower 50mm EDF Fan unit, motor, esc, lipo WRXronald Aircraft - Electric - Jets (FS/W) 4 Feb 24, 2010 06:41 AM
