Old Nov 21, 2010, 08:41 AM
dstrout is offline
Find More Posts by dstrout
Proudly 2.4GHz free!
dstrout's Avatar
Alexandria, VA, USA
Joined Feb 2003
JR XP-783: Carrier but no servo movement?
I dug my RC gear out of storage after 4+ years, including my trusty JR XP-783. Of course the battery was dead (8-cell MiMH). I put it on the charger overnight, powered it on the next morning, and got the "backup battery dead" beep. I turned it off & back on, and it came up fine, though with all model memories reset of course.
What happens now is that it seems to be sending a carrier but no data. If I turn it on and set up a receiver with a servo on it, nothing happens when I move the sticks. If I turn it off, the servos chatter like they will when there is no signal, and they will stop chattering when i turn it on, but then won't move.
Likewise, the ESC won't arm as it should, either. I've tried with several rx's and servos (all of whom used to work with this tx), reseated the crystal and the module. The battery reads 11.1 V 11.8 on the screen.
I can send it back to Horizon if I need to, but I'd rather not if I don't have to. any advice appreciated.
thanks,
Dave.
dstrout is offline Find More Posts by dstrout
Old Nov 21, 2010, 08:45 AM
dmcquinn is online now
Find More Posts by dmcquinn
dmcquinn's Avatar
United States, MO, Chesterfield
Joined Jan 2004
Does ther 783 have a setting for pcM VS PPM? If so, check that it matches your receivers (probably ppm)
dmcquinn is online now Find More Posts by dmcquinn
Old Nov 21, 2010, 09:48 AM
dstrout is offline
dstrout's Avatar
Alexandria, VA, USA
Joined Feb 2003
Bingo - thanks!
Old Nov 21, 2010, 10:46 AM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Sounds as though you'll need to have a new lithium cell installed or the transmitter will lose its memory in 24 hours or so.
It's a great transmitter and worth sending to Horizon for a proper checkup. While mine was in last time, I had them upgrade the firmware to JR 388 standard. This provides CCPM helicopter mixing, activates the 8th channel, gives you stick mode selection and a couple of other things I can't remember. Mine works as well as new and serves as an excellent backup transmitter. I have a Spektrum 2.4 module for it (for BNF models), as well as an FrSky telemetry module and a Fly Dream module. The latter is the one I use most and has worked extremely well.
The only drawback of the transmitter is that it has analog trims, so you have to remember to go through the process of setting trims back to zero if you are to avoid surprises when changing models. But at least the Trim Offset feature makes this easy.
Daedalus66 is online now Find More Posts by Daedalus66
Jr Xp-783 Fm dumbthumbs Aircraft - General - Radio Equipment (FS/W) 8 Dec 19, 2004 10:28 PM
Yippee! Jr Xp-783 Fm dumbthumbs Aircraft - General - Radio Equipment (FS/W) 3 Sep 01, 2004 09:50 AM
JR XP 783 radio and Zoom 400 - How to setup?? CJKinney Mini Helis 1 Aug 31, 2004 09:45 PM
Alert Does JR X-347 (XP-783) come with CCPM Mixing? GTOVR4 Electric Heli Talk 6 May 18, 2004 05:48 PM
Jr Xp-783 Fm dumbthumbs Aircraft - Electric - Airplanes (FS/W) 0 Feb 03, 2002 12:54 PM
