Old Feb 08, 2011, 03:34 PM
DanBo3D is offline
Find More Posts by DanBo3D
RC Keeps Me Sane
DanBo3D's Avatar
United States, NJ, Carlstadt
Joined Sep 2005
Here is a landing gear fix in this thread,
http://www.rcgroups.com/forums/showt...1342189&page=6
DanBo3D is offline Find More Posts by DanBo3D
Old Feb 10, 2011, 05:10 PM
bhcnomo is offline
Find More Posts by bhcnomo
Paradise R/C Flyers in NY
bhcnomo's Avatar
United States, NY, Utica
Joined May 2010
all right my mustang came in today
put it together and its good to go
good for the mod shop that is
now where did i leave them markers
bhcnomo is offline Find More Posts by bhcnomo
Old Feb 11, 2011, 12:08 AM
bhcnomo is offline
bhcnomo's Avatar
Joined May 2010
flying a Mustang in RealFlight
P-51 Mustang (3 min 6 sec)
Old Feb 14, 2011, 09:10 PM
bhcnomo is offline
bhcnomo's Avatar
Joined May 2010
mods
clear tape down the undercarriage from fount of the cowl to the vent hole in the tail to protect it from scrapes when landing
and holds down the wing bolt cover
bent the landing gear to get more of the plane behind the wheels
that should help with takeoffs and landing in grass
got to the mod the hole slot thing where the gear go into the wing
to make it stronger
Old Feb 15, 2011, 07:56 AM
Nitrotek.Se is offline
Find More Posts by Nitrotek.Se
Nitrotek.Se's Avatar
Joined Feb 2011
P51 are one of a few good looking models in my opinion.
Here is an extract about the design of the plane
The design, known as the NA-73X, followed the best conventional practice of the era, but included two new features. One was a new NACA-designed laminar flow wing, which was associated with very low drag at high speeds.[7][8] The other was a new radiator design that exploited the "Meredith Effect", in which heated air exited the radiator as a form of jet thrust.
Nitrotek.Se is offline Find More Posts by Nitrotek.Se
Old Feb 17, 2011, 07:26 PM
bhcnomo is offline
bhcnomo's Avatar
Joined May 2010
field battery charger 12v supply and battery volt tester
made from a Husky 10 in. All-Purpose Tote
Home Depot $16.97
Old Feb 19, 2011, 08:25 PM
bhcnomo is offline
bhcnomo's Avatar
Joined May 2010
this is my fix for the weak landing gear mount
1/8 plywood 1 3/4" x 1"
with two cf rods
glued down with epoxy
now only got a month before i can go flying and test it
Old Feb 20, 2011, 12:36 AM
sp3hybrid is offline
Find More Posts by sp3hybrid
Joined Jan 2009
I got five flights in on mine today. The weather warmed up to 75 F with practically no wind. Perfect conditions. I have about 15 flights on this plane now. On my last flight I used an older (pretty heavy) 2800mAh 30C lipo pack. It was the last pack I had which was still charged. The plane flew fine, but I could tell it was heavy. Came in pretty fast on approach. Landing was fine, but I noticed that the gear is now slowly loosening up. I guess I will have to try some of these gear fixes myself now.
sp3hybrid is offline Find More Posts by sp3hybrid
Old Feb 20, 2011, 01:33 AM
bhcnomo is offline
bhcnomo's Avatar
Joined May 2010
its been months ago i had weather like that hear in new york
when it gets nice iam going to ware my thumbs down to a nub flying
Old Feb 20, 2011, 02:41 PM
KenS999 is offline
Find More Posts by KenS999
KenS999's Avatar
United States, IL, Huntley
Joined Oct 2008
Belly Lander ?
Hi,
I want to pick one of these up. Anyone here fly this P-51 as a dedicated hand launched belly lander? I usually fly on grass, and this plane appears to be far less money then the PKZ P-51. Just wondering if this plane will survive the rigors of being a dedicated belly lander?
Ken
KenS999 is offline Find More Posts by KenS999
Old Feb 20, 2011, 04:34 PM
shoeler is offline
Find More Posts by shoeler
United States, OK, Lawton
Joined Jun 2010
Originally Posted by KenS999 View Post
Hi,
Ken
I started out with the wheels on it... Now its a belly lander for me. No problems
shoeler is offline Find More Posts by shoeler
Old Feb 21, 2011, 08:42 PM
bhcnomo is offline
bhcnomo's Avatar
Joined May 2010
ok heres something to look out for
i drop my plane from two feet onto a hardwood floor
hit on the spinner and the shaft on the motor snapped off
the metal was made to hard
Old Feb 22, 2011, 04:42 PM
ohsnap is offline
Find More Posts by ohsnap
Renton, WA
Joined Jan 2010
ouch thats to bad about the shaft. i recently replaced the stock esc/motor with a tp40a/supertiger.10 on an apc 9x6 sf. i was expecting a lot more punch over stock so will play around with some more prop combos.
was planning on doing retracts but like it as a belly lander for now. probably will do it anyways when i get some more time.
ohsnap is offline Find More Posts by ohsnap
Old Feb 24, 2011, 09:09 PM
bhcnomo is offline
bhcnomo's Avatar
Joined May 2010
i put a new motor on my mustang
its a Park 480 Brushless Outrunner Motor, 910Kv by E-flite
a little longer then the stock motor
move the cowl out a 1/4" worked good
also added a 1/16 cf rod to the bottom of the Elevator
and two 1/16 cf rods up inside the rudder
the Elevator and rudder are weak and bend easy
but not anymore
and put hinge tape on all the hinges
Old Feb 25, 2011, 05:12 PM
DanBo3D is offline
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
Hey bhcnomo,
Does that motor fit the stock prop adapter (shaft size) so everything else remains the same?
Nice job on the install.
New Product Banana Hobby's P-51 Mustang 64" Wing Span SNEAK PEAK! FieldofDreamsFlyer Electric Warbirds 321 Jan 25, 2011 12:02 PM
Discussion Tower P-51 Old Crow 40" Wingspan smrouss Electric Warbirds 6 Jan 17, 2011 10:04 AM
Sold Flying Legends P-51 Mustang $60.00 KenS999 Aircraft - Electric - Airplanes (FS/W) 0 Nov 05, 2010 11:51 AM
Discussion tower hobbies fun 51 kit stinger0518 3D / Fun Fly Fuel Planes 2 Nov 03, 2010 09:27 PM
Cool Dead - Now $99 - Ripmax P-51 Mustang and Spitfire ARF $60 at Tower Hobbies Mujiber Hot Online Deals 53 May 22, 2010 01:10 PM
