Old Dec 07, 2010, 01:19 PM
DanBo3D is offline
Find More Posts by DanBo3D
RC Keeps Me Sane
DanBo3D's Avatar
United States, NJ, Carlstadt
Joined Sep 2005
Originally Posted by jzpilot View Post
I maidened mine today! Great flying plane. I crashed on the first launch trying an overhand throw, much better under-hand! Great bird for the money. I think flaps for landing(no gear for me) would be great. Does anyone know if I can program flaps and still have aileron control for landing? I have a futaba 8fg. The manual does not indicate this type of mix available? thanks....
jz
I guess you would look for a "flaperon" setting in your radio.
DanBo3D is offline Find More Posts by DanBo3D
Old Dec 07, 2010, 02:32 PM
gouda is offline
Find More Posts by gouda
Is it summer yet?
gouda's Avatar
Flight Level 46 X 92
Joined Feb 2002
Finally got mine ordered. Waiting paid off with free shipping and a 10% off coupon. To cold to fly anyway.
gouda is offline Find More Posts by gouda
Old Dec 07, 2010, 03:54 PM
jzpilot is offline
Find More Posts by jzpilot
your focus needs more focus
jzpilot's Avatar
Gunnison, Co
Joined Oct 2010
I'll re-read that section and try it, thanks. I flew five times today. Wind blowing 15-20mph, temp in the mid-30's F according to the weather station at the FAA airport 10 miles away. This plane flies well in the wind, I fly on a hill side at 8,000' asl. The last landing, well, not so good. Broke the cowl, plywood motor mount, etc. I'm surprised the prop has not broken yet. The plane is very easily repaired.
Does anyone know the original motor thrust angle(s)? Need to verify an acceptable repair. Thanks again!
jz
jzpilot is offline Find More Posts by jzpilot
Old Dec 07, 2010, 04:21 PM
DanBo3D is offline
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
I did a quick measurement of the thrust angles. I got approx 1mm down and .5mm to the right.
I used a digital caliper to take measurements from the back of the spinner to the cowl, at 12 - 6 - 3- 9 o'clock.
It comes out to be about 20/1000 right and 40/1000 down.
Hope this helps.
Old Dec 07, 2010, 05:53 PM
jzpilot is offline
jzpilot's Avatar
Gunnison, Co
Joined Oct 2010
Hope this helps.
Bingo! thank you so much!! My cowl is busted, but I will transfer the info to the motormount. Test flight went well...
jz
Old Dec 07, 2010, 09:10 PM
marketvending is offline
Find More Posts by marketvending
Joined May 2005
When i first saw this plane last month, I knew I had to have it. what a deal. Free shipping until Dec 8th and 10.00 off as well. Go to hobbypeople.net they have there 2200 11.1 volt 20c lipos for 11.99 not sure for how long. Couldn't wait to be able to finally download the manual from Tower. I know one thing the motor shaft looks to be a 1/4 shaft as the instructions say to drill out a slow fly prop. So, its not the cheap thin shaft motors that are on the market. Another post said that tower support said it also had a 30 amp speed control. Its sounding better and better. Already have two from several months ago and I like them. for the output they are great and a bit smaller than some of the other cheaper packs out there on Ebay and such.
marketvending is offline Find More Posts by marketvending
Old Dec 08, 2010, 03:24 PM
kaging is offline
Find More Posts by kaging
The ground is approaching fast
Lewisville, TX
Joined Feb 2009
well i've been out of the hobby for a few months and this plane is my ticket back in the game. Can't wait till it shows up at my doorstep.
kaging is offline Find More Posts by kaging
Old Dec 08, 2010, 06:20 PM
shoeler is offline
Find More Posts by shoeler
United States, OK, Lawton
Joined Jun 2010
You will enjoy this plane, its a well built fun flyer. I am hoping that I can get another flight out of it this weekend. I am going to have to removed the landing gear and do a belly landing because we got some snow last weekend and our field it covered... But I am assuming a hand launch won't be difficult.
shoeler is offline Find More Posts by shoeler
Old Dec 08, 2010, 08:27 PM
Joined May 2005
No snow in Phx, AZ Now's some of the best flying weather around. Tower now has a parts list online for this plane.
Old Dec 09, 2010, 03:20 AM
w5kfg is offline
Find More Posts by w5kfg
w5kfg
w5kfg's Avatar
Hattiesburg,MS
Joined Jun 2003
Where is the parts list as all I saw was 2 propellers
w5kfg is offline Find More Posts by w5kfg
Old Dec 09, 2010, 07:19 AM
gouda is offline
Is it summer yet?
gouda's Avatar
Joined Feb 2002
Would skis work on this plane? Or would they upset the aerodynamic balance to much? I'm concerned about belly landings because of the scoop.
Old Dec 10, 2010, 02:30 AM
wileyrc is offline
Find More Posts by wileyrc
wileyrc's Avatar
Joined May 2007
I fly my mustang at a park where the grass so tall it will not allow me to ROG. I hand launch the p-51 all time. climbs out nice with 3/4 to full throttle.
wileyrc is offline Find More Posts by wileyrc
Old Dec 10, 2010, 09:35 AM
kaging is offline
Lewisville, TX
Joined Feb 2009
What method of hand launching are you using (over or under handed)? Also do you do belly landings? If so did you have to put masking tape on the underside?
Thanks in advance....
Old Dec 10, 2010, 10:47 AM
wileyrc is offline
wileyrc's Avatar
Joined May 2007
I use a over handed toss. works great, only small problem is there is really on place to hold the plane from the bottom. I sort of hold it at the back end of the fuse and balance it between the fuse and the scoop before I toss it. Belly landings really mess up the paint on the bottom of the plane so tape to protect it would be a good idea. Just know that once you apply the tape the paint will come off with the tape if you ever attempt to remove it. I hand toss mine with the landing gear on it so I wont destroy the paint with belly landings.
Old Dec 10, 2010, 02:58 PM
kaging is offline
Lewisville, TX
Joined Feb 2009
Thanks wiley... good to know.
New Product Banana Hobby's P-51 Mustang 64" Wing Span SNEAK PEAK! FieldofDreamsFlyer Electric Warbirds 321 Jan 25, 2011 11:02 AM
Discussion Tower P-51 Old Crow 40" Wingspan smrouss Electric Warbirds 6 Jan 17, 2011 09:04 AM
Sold Flying Legends P-51 Mustang $60.00 KenS999 Aircraft - Electric - Airplanes (FS/W) 0 Nov 05, 2010 10:51 AM
Discussion tower hobbies fun 51 kit stinger0518 3D / Fun Fly Fuel Planes 2 Nov 03, 2010 08:27 PM
Cool Dead - Now $99 - Ripmax P-51 Mustang and Spitfire ARF $60 at Tower Hobbies Mujiber Hot Online Deals 53 May 22, 2010 12:10 PM
