Old Mar 17, 2011, 01:46 PM
wileyrc is offline
Find More Posts by wileyrc
wileyrc's Avatar
Joined May 2007
I have done both but shoeler is right there is no good spot to grab the plane if you launch it over hand I grab is sort of behind the scoop, which is difficult because the plane does'nt balance well when holding it at that point. either way you go once you launch it the fun begins this plane is extremely stable, even in some wind it does well. you might want to put some clear packing tape on the bottom if you going to belly land. to protect the fuse.
wileyrc is offline Find More Posts by wileyrc
Old Mar 24, 2011, 05:48 PM
ohsnap is offline
Find More Posts by ohsnap
United States, WA, Olympia
Joined Jan 2010
another power upgrade
swapped out the supertiger .10 with a turnigy c35-36 1100kv after some slight modifications. had to reverse the shaft and cut off 3mm then moved the cowl forward 16mm for a nice fit. waiting to get back my radio back so havent done any watt/prop combo measurements. hope to get in a flight this weekend if the weather clears.
flaps are still working well. may do some retracts soon. man i love this bird!
ohsnap is offline Find More Posts by ohsnap
Old Mar 27, 2011, 09:39 AM
bhcnomo is online now
Find More Posts by bhcnomo
Paradise R/C Flyers in NY
bhcnomo's Avatar
United States, NY, Utica
Joined May 2010
came out real nice
are you useing the stock esc
what size is it
have not even flown mine yet
cant want
so what happend to your radio
i see you have a Spektrum rx
what radio do you have
i have the DX6i and one of the trim tabs broke
got some Aluminum Trim Tabs
now good as new
http://www.eastrc.org/shop.cgi/page=...01235211.13983
bhcnomo is online now Find More Posts by bhcnomo
Old Mar 28, 2011, 11:57 AM
drypipe is offline
Find More Posts by drypipe
Joined Aug 2009
I have used this strut set up for one of the little EPO yellow Texans I got from BH. Although not really scale, it seems to work fine with not much extra weight and can get through grass. Just screw them onto two pieces of hardwood ply and glue on to where the original struts supports were located. They give slightly under 3" in height clearance starting from the base of the support, under the spring, to the center line of the wheel axle. What's the height of the Mustang's stock wire struts?
Maybe it can be a good replacement for the stock wire struts on the Tower P-51?
drypipe is offline Find More Posts by drypipe
Old Mar 28, 2011, 02:12 PM
ohsnap is offline
Joined Jan 2010
i replaced the stock esc with a plush 40a when i was trying the supertiger .10 setup so still using that for now.
i had a 9503 which i recently sold. ordered a dx8 last week which should be here today so have been grounded for a week which has been a real bummer to say the least.
i was actually going to sell this bird but realized its just too much fun. its a perfect plane for power upgrades as the wings are ridiculously strong. i have hammered on it pretty hard and have yet to see any flex. i hinged the rudder and replaced the stock servos with hxt900s which has helped.
Originally Posted by bhcnomo View Post
came out real nice
what size is it
cant want
Old Mar 28, 2011, 02:22 PM
ohsnap is offline
Joined Jan 2010
not sure if anyone's broken the fragile plastic tail wheel assembly. i broke it pretty early on and replaced it with a cheap 1.5mm allen wrench i had laying around.
just drilled a small hole in the plastic collar and trimmed the allen wrench to size and secured with some epoxy. really good mod for you non belly landers.
Old Mar 30, 2011, 06:53 PM
ohsnap is offline
Joined Jan 2010
finally got to do some bench testing with the tr3536c. results were pretty good. just need to test them in the air now and see real world performance.
turnigy 35-36c 1100kv
plush 40a
nanotech 45c 3s 2200mah
gp powerflow props:
9x4.5 (stock) - 30a / 354w
9x6 - 37a / 425w
10x4.5 - 39a / 449w
10x7 - 46a / 515w
Old Apr 01, 2011, 06:27 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
Just got mine yesterday. 1st thing I did was clip off the connector from the esc. I use sermos connectors to connect battery. Then, checked the motor and it works as well as servos. Generally, most manufacturers use el cheapo servos in these models to keep costs down.
The motor....hmmm....doesn't look like it will pull that much. Is this some sort of great planes motor thats oem'd? Doesn't look like you have all that much space lengthwise to use another motor without chopping something.
Lastly, whats up with the included prop? The tips are bent back 90 degrees.
May use an apc prop instead.
Lucky...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Apr 01, 2011, 06:48 PM
drypipe is offline
Joined Aug 2009
The motor in that P-51 is a Thunder Tiger 388w bell motor. Everything else is also the Thunder Tiger brand.
Old Apr 02, 2011, 07:53 AM
shoeler is offline
Find More Posts by shoeler
United States, OK, Lawton
Joined Jun 2010
I hand launch it grabbing it from the top, or "underhand". It was the first plane where I attempted that. Never had a problem except for anxiety the first few times.
shoeler is offline Find More Posts by shoeler
Old Apr 02, 2011, 05:40 PM
barnyardflyer is offline
Find More Posts by barnyardflyer
Experienced R/C Repairman
barnyardflyer's Avatar
Three Oaks, Michigan
Joined Sep 2003
Well, I couldn't resist. I started to dig out pockets for Hobby King electric retracts.
Progress so far.
barnyardflyer is offline Find More Posts by barnyardflyer
Old Apr 02, 2011, 07:19 PM
bhcnomo's Avatar
Joined May 2010
Progress so far.
what retracts did you get
Old Apr 02, 2011, 07:24 PM
Joined Sep 2003
http://www.hobbyking.com/hobbyking/s...dProduct=11301
I am boring the wing for the wire now. I have no idea how well this will come out.
Old Apr 02, 2011, 07:40 PM
drypipe is offline
Joined Aug 2009
I was hoping someone would do this! Can't wait to see the results.
Old Apr 02, 2011, 07:53 PM
Joined Sep 2003
Wish me luck!
I just got the servo extension through 1 wing.
New Product Banana Hobby's P-51 Mustang 64" Wing Span SNEAK PEAK! FieldofDreamsFlyer Electric Warbirds 321 Jan 25, 2011 11:02 AM
Discussion Tower P-51 Old Crow 40" Wingspan smrouss Electric Warbirds 6 Jan 17, 2011 09:04 AM
Sold Flying Legends P-51 Mustang $60.00 KenS999 Aircraft - Electric - Airplanes (FS/W) 0 Nov 05, 2010 10:51 AM
Discussion tower hobbies fun 51 kit stinger0518 3D / Fun Fly Fuel Planes 2 Nov 03, 2010 08:27 PM
Cool Dead - Now $99 - Ripmax P-51 Mustang and Spitfire ARF $60 at Tower Hobbies Mujiber Hot Online Deals 53 May 22, 2010 12:10 PM
