Old Feb 26, 2011, 05:04 PM
bhcnomo is offline
Find More Posts by bhcnomo
James Stockton
bhcnomo's Avatar
United States, NY, Utica
Joined May 2010
Originally Posted by microDan View Post
Hey bhcnomo,
Does that motor fit the stock prop adapter (shaft size) so everything else remains the same?
Nice job on the install.
thanks microdan
ya shaft is the same size as the stock motor
the new motor sticks out about 1/4" more then the stock motor
so i moved the cowl out a 1/4"
and they used blue Threadlocker on the back of the stock motor mount
bolts
bhcnomo is offline Find More Posts by bhcnomo
Old Feb 26, 2011, 07:31 PM
sp3hybrid is offline
Find More Posts by sp3hybrid
Joined Jan 2009
Hi bhcnomo
How did the landing gear mod work out for you. I need to mod mine and like your mid since it keeps the same gear and doesn't add too much to the bottom of the wing.
sp3hybrid is offline Find More Posts by sp3hybrid
Old Feb 27, 2011, 12:29 AM
bhcnomo is offline
James Stockton
bhcnomo's Avatar
Joined May 2010
Originally Posted by sp3hybrid View Post
Hi bhcnomo
the gear mod feels real strong now and i think it will work well
let you know when i can go flying again here in new york
too cold too wet to fly
looks like it will be about a month before it nice again
got thee aircraft to madden
the mustang , a epp eagle and slow hawk RC ornithopter from Sean Kinkade
the last time i went flying was November 21, 2010
Old Feb 27, 2011, 07:40 PM
Mr Big Head is online now
Find More Posts by Mr Big Head
Mr Big Head's Avatar
United States, CA, Redding
Joined Feb 2011
Originally Posted by bhcnomo View Post
flying a Mustang in RealFlight
http://www.youtube.com/watch?v=ZVvwX6I9Dps
OK I want one of these. What is the going deal on them? Any free shipping or discount codes around? Also why does your Mustang in Real Flight sound so much better than mine? I have 5.5 and mine sounds nothing like yours.
Mr Big Head is online now Find More Posts by Mr Big Head
Old Feb 27, 2011, 07:45 PM
DanBo3D is offline
Find More Posts by DanBo3D
RC Keeps Me Sane
DanBo3D's Avatar
United States, NJ, Carlstadt
Joined Sep 2005
http://www.towerhobbies.com/ right on the front page free shipping.
Mustang is $115 use the coupon codes they send you as a Tower member for a discount.
If you're not a member a given code code won't work for you anyway.
DanBo3D is offline Find More Posts by DanBo3D
Old Feb 27, 2011, 08:24 PM
bhcnomo is offline
James Stockton
bhcnomo's Avatar
Joined May 2010
i change the motor sound
load the p-51 mustang
go to aircraft
then edit p-51 mustang
open up airframe
then fuselage
goto engine
change sound profile
i used O.S. 300 twin
then save your changes
Old Mar 01, 2011, 01:08 PM
bostomper is offline
Find More Posts by bostomper
Joined Aug 2010
would like to bend the tires forward a bit--not sure quite how to do that--any techniques you use would be appreciated. Thanks.
bostomper is offline Find More Posts by bostomper
Old Mar 01, 2011, 01:31 PM
DanBo3D is offline
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
Here's how I gid it, I took 2 small pieces of a hard wood and made 2 notches 1 in each side of the wood pieces to match the diameter of the wire.
I then clamped the u hook end of the wire between the wood strips and bent it so the front of the wheels center point were just visible when looking down on the wing. The way I bent them as close to the point where they slip into the wing gives you the forward tilt while keeping the maximum possible height clearance for the belly. I hope this helps...
Old Mar 01, 2011, 03:33 PM
Joined Aug 2010
thanks microdan
Old Mar 01, 2011, 05:46 PM
bhcnomo is offline
James Stockton
bhcnomo's Avatar
Joined May 2010
used two pair of pliers and bent then the same spot that microdan did his
Old Mar 01, 2011, 05:49 PM
Joined Aug 2010
thanks nomo--I now have options
Old Mar 06, 2011, 09:52 PM
Joined Feb 2011
go to aircraft
open up airframe
then fuselage
goto engine
OMG my mustang now sounds like yours! Thanks
Old Mar 17, 2011, 03:46 AM
wileyrc is offline
Find More Posts by wileyrc
wileyrc's Avatar
Joined May 2007
because I fly at a local park I took the landing gear off my mustang, when landing she slides across the grass about two feet before coming to an abrupt stop. this is a very cool plane, just wish the paint did'nt come off so easy.
wileyrc is offline Find More Posts by wileyrc
Old Mar 17, 2011, 04:13 AM
barnyardflyer is offline
Find More Posts by barnyardflyer
Experienced R/C Repairman
barnyardflyer's Avatar
Three Oaks, Michigan
Joined Sep 2003
So did you launch over hand or under hand?
I am still debating which I will try if the weather ever lets me try.
barnyardflyer is offline Find More Posts by barnyardflyer
Old Mar 17, 2011, 08:49 AM
shoeler is offline
Find More Posts by shoeler
United States, OK, Lawton
Joined Jun 2010
Underhand is the way to go! Overhand is awkward and there isn't a good spot to grab. I had never done underhand until I did this plane so I was a little anxious. Really it went pretty smooth, and I haven't had a problem.
shoeler is offline Find More Posts by shoeler
New Product Banana Hobby's P-51 Mustang 64" Wing Span SNEAK PEAK! Mikey 68 Electric Warbirds 321 Jan 25, 2011 11:02 AM
Discussion Tower P-51 Old Crow 40" Wingspan smrouss Electric Warbirds 6 Jan 17, 2011 09:04 AM
Sold Flying Legends P-51 Mustang $60.00 KenS999 Aircraft - Electric - Airplanes (FS/W) 0 Nov 05, 2010 10:51 AM
Discussion tower hobbies fun 51 kit stinger0518 3D / Fun Fly Fuel Planes 2 Nov 03, 2010 08:27 PM
Cool Dead - Now $99 - Ripmax P-51 Mustang and Spitfire ARF $60 at Tower Hobbies Mujiber Hot Online Deals 53 May 22, 2010 12:10 PM
