| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Guest
Posts: n/a
Tree caught plane...
due to decreasing depth perception, on turn to final, i caught my venture 60
on a tree, and it fell to the ground in a bunch of shrubs..... damage to plane is minor, ego damage, major..... Something caught the leading edge a couple of inches in from the outboard wing tip and broke the leading edge (the plane turned into the tree and fell to the ground; brush broke the fall).. not too bad to repair..... the fuse, just in front to the hor. stab, twisted enough to wrinkle the covering... nothing appears to be out of whack, but am wondering how to go about being sure.... my first thought is to use the heat gun on the wrinkles and see how it looks afterwards, and cut the covering off between vertical stab and fuse to look for cracks..... other then doing some twisting and running my hand around the back end to feel for cracks, i don't want to remove all the rear covering unless i have to. Does this seem reasonable if nothing obvious is found? .. Arne, CT, USA ========================= |
#2 |
Guest
Posts: n/a
Re: Tree caught plane...
if you got trike gear, double check you nose arm. did the same last summer
and learned all about nosewheel arms on thunder tiger trainers -- Tater President of MARS Club www.treece.org/mars.htm NAR #79654 L1 AMA #747769 EAA #703312 remove spam spelled backwards to reply "Arne Reil" <thereilarne@cox.net> wrote in message news:EBXQa.15550$AD3.544@lakeread04... > due to decreasing depth perception, on turn to final, i caught my venture 60 > on a tree, and it fell to the ground in a bunch of shrubs..... damage to > plane is minor, ego damage, major..... > > Something caught the leading edge a couple of inches in from the outboard > wing tip and broke the leading edge (the plane turned into the tree and fell > to the ground; brush broke the fall).. not too bad to repair..... the fuse, > just in front to the hor. stab, twisted enough to wrinkle the covering... > nothing appears to be out of whack, but am wondering how to go about being > sure.... my first thought is to use the heat gun on the wrinkles and see how > it looks afterwards, and cut the covering off between vertical stab and fuse > to look for cracks..... other then doing some twisting and running my hand > around the back end to feel for cracks, i don't want to remove all the rear > covering unless i have to. > > Does this seem reasonable if nothing obvious is found? > . > Arne, CT, USA > ========================= > > |
#3 |
Guest
Posts: n/a
Ah, yes, i'm a bit familiar with nose wheels, myself..<g>..
Read about the previous crash mentioned above and all the answers.... looks like i have to do an 'annual' on my plane in addition to the obvious repairs.... will be checking all hinges, surfaces, servo control, etc... .. Arne, CT, USA ========================= "tater schuld" <taters1@maps.charter.net> wrote in message news:vh8u02atf3ih6f@corp.supernews.com... > if you got trike gear, double check you nose arm. did the same last summer > and learned all about nosewheel arms on thunder tiger trainers > > > -- > Tater > President of MARS Club > www.treece.org/mars.htm > NAR #79654 L1 > AMA #747769 > EAA #703312 > remove spam spelled backwards to reply > > > "Arne Reil" <thereilarne@cox.net> wrote in message > news:EBXQa.15550$AD3.544@lakeread04... > > due to decreasing depth perception, on turn to final, i caught my venture > 60 > > on a tree, and it fell to the ground in a bunch of shrubs..... damage to > > plane is minor, ego damage, major..... > > > > Something caught the leading edge a couple of inches in from the outboard > > wing tip and broke the leading edge (the plane turned into the tree and > fell > > to the ground; brush broke the fall).. not too bad to repair..... the > fuse, > > just in front to the hor. stab, twisted enough to wrinkle the covering... > > nothing appears to be out of whack, but am wondering how to go about being > > sure.... my first thought is to use the heat gun on the wrinkles and see > how > > it looks afterwards, and cut the covering off between vertical stab and > fuse > > to look for cracks..... other then doing some twisting and running my hand > > around the back end to feel for cracks, i don't want to remove all the > rear > > covering unless i have to. > > > > Does this seem reasonable if nothing obvious is found? > > . > > Arne, CT, USA > > ========================= > > > > > > |
#4 |
Guest
Posts: n/a
"Arne Reil" <thereilarne@cox.net> wrote in message news:hO2Ra.16122$AD3.12986@lakeread04... > Ah, yes, i'm a bit familiar with nose wheels, myself..<g>.. > > Read about the previous crash mentioned above and all the answers.... looks > like i have to do an 'annual' on my plane in addition to the obvious > repairs.... will be checking all hinges, surfaces, servo control, etc... and the firewall. missed checking that 2 weeks ago. luckily we found it before starting the engine. -- Tater President of MARS Club www.treece.org/mars.htm NAR #79654 L1 AMA #747769 EAA #703312 remove spam spelled backwards to reply > . > Arne, CT, USA > ========================= > "tater schuld" <taters1@maps.charter.net> wrote in message > news:vh8u02atf3ih6f@corp.supernews.com... > > if you got trike gear, double check you nose arm. did the same last summer > > and learned all about nosewheel arms on thunder tiger trainers > > > > > > -- > > Tater > > President of MARS Club > > www.treece.org/mars.htm > > NAR #79654 L1 > > AMA #747769 > > EAA #703312 > > remove spam spelled backwards to reply > > > > > > "Arne Reil" <thereilarne@cox.net> wrote in message > > news:EBXQa.15550$AD3.544@lakeread04... > > > due to decreasing depth perception, on turn to final, i caught my > venture > > 60 > > > on a tree, and it fell to the ground in a bunch of shrubs..... damage to > > > plane is minor, ego damage, major..... > > > > > > Something caught the leading edge a couple of inches in from the > outboard > > > wing tip and broke the leading edge (the plane turned into the tree and > > fell > > > to the ground; brush broke the fall).. not too bad to repair..... the > > fuse, > > > just in front to the hor. stab, twisted enough to wrinkle the > covering... > > > nothing appears to be out of whack, but am wondering how to go about > being > > > sure.... my first thought is to use the heat gun on the wrinkles and see > > how > > > it looks afterwards, and cut the covering off between vertical stab and > > fuse > > > to look for cracks..... other then doing some twisting and running my > hand > > > around the back end to feel for cracks, i don't want to remove all the > > rear > > > covering unless i have to. > > > > > > Does this seem reasonable if nothing obvious is found? > > > . > > > Arne, CT, USA > > > ========================= > > > > > > > > > > > > |
#5 |
Guest
Posts: n/a
From experience, if the covering is wrinkled, there is a reason. I would
remove it and inspect the wood for cracks. Once it is exposed, twist it a little to show the cracks. Simply applying some CA normally takes care of any cracks. If you don't inspect it, and you lose the tail, you will spend a lot more time building a new one, not to mention the money and... most of all, the safety considerations can't be ignored. JR "Arne Reil" <thereilarne@cox.net> wrote in message news:EBXQa.15550$AD3.544@lakeread04... > due to decreasing depth perception, on turn to final, i caught my venture 60 > on a tree, and it fell to the ground in a bunch of shrubs..... damage to > plane is minor, ego damage, major..... > > Something caught the leading edge a couple of inches in from the outboard > wing tip and broke the leading edge (the plane turned into the tree and fell > to the ground; brush broke the fall).. not too bad to repair..... the fuse, > just in front to the hor. stab, twisted enough to wrinkle the covering... > nothing appears to be out of whack, but am wondering how to go about being > sure.... my first thought is to use the heat gun on the wrinkles and see how > it looks afterwards, and cut the covering off between vertical stab and fuse > to look for cracks..... other then doing some twisting and running my hand > around the back end to feel for cracks, i don't want to remove all the rear > covering unless i have to. > > Does this seem reasonable if nothing obvious is found? > . > Arne, CT, USA > ========================= > > |
#6 |
Guest
Posts: n/a
Oh, and the next time you tell the story, the standard line is that the tree
jumped up and grabbed the plane ![]() "JR" <jr-ama732@comcast.net> wrote in message news:2q5Ra.61328$OZ2.11421@rwcrnsc54... > From experience, if the covering is wrinkled, there is a reason. I would > remove it and inspect the wood for cracks. Once it is exposed, twist it a > little to show the cracks. Simply applying some CA normally takes care of > any cracks. If you don't inspect it, and you lose the tail, you will spend a > lot more time building a new one, not to mention the money and... most of > all, the safety considerations can't be ignored. > > JR > > "Arne Reil" <thereilarne@cox.net> wrote in message > news:EBXQa.15550$AD3.544@lakeread04... > > due to decreasing depth perception, on turn to final, i caught my venture > 60 > > on a tree, and it fell to the ground in a bunch of shrubs..... damage to > > plane is minor, ego damage, major..... > > > > Something caught the leading edge a couple of inches in from the outboard > > wing tip and broke the leading edge (the plane turned into the tree and > fell > > to the ground; brush broke the fall).. not too bad to repair..... the > fuse, > > just in front to the hor. stab, twisted enough to wrinkle the covering... > > nothing appears to be out of whack, but am wondering how to go about being > > sure.... my first thought is to use the heat gun on the wrinkles and see > how > > it looks afterwards, and cut the covering off between vertical stab and > fuse > > to look for cracks..... other then doing some twisting and running my hand > > around the back end to feel for cracks, i don't want to remove all the > rear > > covering unless i have to. > > > > Does this seem reasonable if nothing obvious is found? > > . > > Arne, CT, USA > > ========================= > > > > > > |
#7 |
Guest
Posts: n/a
I'm going to check that area today.... the fuse is plywood on 2 sides and
bottom... the wrinkles on on the top which is sticks..... should be interesting.... i'll take my time and do it right..... And thanks for the feedback...... hmm.. tree reached out and grabbed plane.. i like that one. damn tree.. .. Arne, CT, USA ========================= "JR" <jr-ama732@comcast.net> wrote in message news:2q5Ra.61328$OZ2.11421@rwcrnsc54... > From experience, if the covering is wrinkled, there is a reason. I would > remove it and inspect the wood for cracks. Once it is exposed, twist it a > little to show the cracks. Simply applying some CA normally takes care of > any cracks. If you don't inspect it, and you lose the tail, you will spend a > lot more time building a new one, not to mention the money and... most of > all, the safety considerations can't be ignored. > > JR > > "Arne Reil" <thereilarne@cox.net> wrote in message > news:EBXQa.15550$AD3.544@lakeread04... > > due to decreasing depth perception, on turn to final, i caught my venture > 60 > > on a tree, and it fell to the ground in a bunch of shrubs..... damage to > > plane is minor, ego damage, major..... > > > > Something caught the leading edge a couple of inches in from the outboard > > wing tip and broke the leading edge (the plane turned into the tree and > fell > > to the ground; brush broke the fall).. not too bad to repair..... the > fuse, > > just in front to the hor. stab, twisted enough to wrinkle the covering... > > nothing appears to be out of whack, but am wondering how to go about being > > sure.... my first thought is to use the heat gun on the wrinkles and see > how > > it looks afterwards, and cut the covering off between vertical stab and > fuse > > to look for cracks..... other then doing some twisting and running my hand > > around the back end to feel for cracks, i don't want to remove all the > rear > > covering unless i have to. > > > > Does this seem reasonable if nothing obvious is found? > > . > > Arne, CT, USA > > ========================= > > > > > > |
#8 |
Guest
Posts: n/a
>i like that one. damn tree.. A cousin of the ground that jumps up to grab the plane, too.... Andy We can make a box of wood.....FLY!! |
#9 |
Guest
Posts: n/a
Did that one last summer to a Hobbistar 60. I was demonstrating to my son,
the low, slow approach technique versus the carrier type landing. The east wind became a south wind and the tree played arresting gear. Similar damage to your venture 60 was visible. I used the damage as an excuse to peel all that shelf paper covering. I did not find concealed damage, but a lot poor workmanship found. The Hobbistar now sports strengthened construction and a sharp Monokote finish. Tom AMA 17839 Arne Reil <thereilarne@cox.net> wrote in message news:EBXQa.15550$AD3.544@lakeread04... > due to decreasing depth perception, on turn to final, i caught my venture 60 > on a tree, and it fell to the ground in a bunch of shrubs..... damage to > plane is minor, ego damage, major..... > > Something caught the leading edge a couple of inches in from the outboard > wing tip and broke the leading edge (the plane turned into the tree and fell > to the ground; brush broke the fall).. not too bad to repair..... the fuse, > just in front to the hor. stab, twisted enough to wrinkle the covering... > nothing appears to be out of whack, but am wondering how to go about being > sure.... my first thought is to use the heat gun on the wrinkles and see how > it looks afterwards, and cut the covering off between vertical stab and fuse > to look for cracks..... other then doing some twisting and running my hand > around the back end to feel for cracks, i don't want to remove all the rear > covering unless i have to. > > Does this seem reasonable if nothing obvious is found? > . > Arne, CT, USA > ========================= > > > |
| Thread Tools | |
| Discussion Plane stuck in tree - New plane at that! | GoldenSlopes | Australia | 17 | Apr 14, 2007 11:22 AM |
| Tree'd Plane | Ragemaster | Beginner Training Area (Aircraft-Electric) | 14 | Jul 12, 2004 12:05 AM |
| Balsa reuse - tree then plane then wall art | Bill Germanson | Parkflyers | 3 | Aug 03, 2002 05:39 PM |
