Old Nov 22, 2010, 08:02 PM
sim_io is offline
Find More Posts by sim_io
Why is the Rum gone?
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
i had problems where it wont play keychain cam videos. Strange as that sounds its basically uncompressed avi files. But the compressed divx movies play just fine.
sim_io is offline Find More Posts by sim_io
Old Nov 22, 2010, 08:39 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by DayDream View Post
My mod to power the HP with a 3S lipo.
I tapped right to the board, this may void you warranty
1)Five screws hold the battery tray and everything else together, middle screw
is under the white seal.
2)It will all come apart at this point so don't lose any parts, and mind the
thermal grease.
3)Locate the power plug connections. (the two at the very back of the
connector.)
4)Use your expert soldering skills to connect red on the card slot side, and
the black on the battery pins side.
5)Using tin snips cut the square hole for the battery pins about 3mm longer
on the aluminum plate and bend it up to make room for your wires to go by.
6)At this point before you screw it together you going to want to check your
work by plugging in the a/c adapter, use a multimeter to check the voltage
and polarity 12.10v, red+, black- you know...
(WARNING: do not power up the board without it put together with the heat sink.)
Nice battery mod. I read somewhere (on another thread) the HP will shut down when the battery gets somewhere in the (lower?) 10v range...just something for us to be aware of. I take it if the Liberator is off there is NO residual drain on the LiPo. If this is correct, then you could leave the LiPo connected all the time and just charge it through the charge port? Any experience with that?
Vantasstic is online now Find More Posts by Vantasstic
Old Nov 22, 2010, 08:57 PM
kevinhines is offline
Find More Posts by kevinhines
Robot, RC Pilot & Builder :-)
kevinhines's Avatar
Roanoke, VA, USA
Joined Jul 2006
Originally Posted by hefest View Post
@kevinhines
if you could update first post with the potentially useful answers for each of the questions would be great.
Hefest,
Will do.
Kevin
kevinhines is offline Find More Posts by kevinhines
Old Nov 22, 2010, 09:00 PM
kevinhines's Avatar
Roanoke, VA, USA
Joined Jul 2006
Originally Posted by Art Newland View Post
I have about an hours worth of watching video on my Headplays, looks like I should be able to get a couple hours of use on a 2000. The balance plugs on the Thunderpowers have a clip that snaps them in place and has to be squeezed to be released. I think the wiring is plenty large enough to handle the HP's .4 amps. The balance plugs are polarized, make sure you have the polarity correct when you solder it up, I checked the four batteries I have with Thunderpower balance plugs... they were all the same. YMMV
Art,
Thanks for explaining... that all makes good sense.
Kevin
Old Nov 22, 2010, 09:04 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Will for sure be doing Daydreams mod. Could I fit a 2200 battery in there easily? And that'd last me how long? -Tyler
flyboy321 is offline Find More Posts by flyboy321
Old Nov 22, 2010, 09:09 PM
kevinhines's Avatar
Roanoke, VA, USA
Joined Jul 2006
DayDream,
Wow, Great Mod!
Thanks for sharing your work with the community!
Kevin
Old Nov 22, 2010, 09:15 PM
rc-mike is offline
Find More Posts by rc-mike
Stay airborne my friends
rc-mike's Avatar
USA, TN, Dickson
Joined Nov 2004
Has anyone just done away with the liberator by hooking the power and video/audio directly into the unit? I have a set I just got from Dell that just quit working and I am pretty sure it is in the liberator. I was planning on sending it back but if someone has done that I might try it instead.
rc-mike is offline Find More Posts by rc-mike
Old Nov 22, 2010, 09:16 PM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
Originally Posted by cliffkot View Post
According to the specifications, the HeadPlay goggles are supposed to play MP4 files. My goggles see the files, but will not play them. I get a "load error" prompt.
The HeadPlay support people said the problem was that I was trying to use the USB port and that I should get the compact flash card because it was faster. I tried that with the same result.
I think I might be getting the runaround. Any suggestions gentlemen?
Cliff K.
I've played a bit playing videos on mine too, lots it doesn't seem to want to play. I've re-rendered some files in the H.264 iPod codec, seems to play all of those OK.
Art Newland is offline Find More Posts by Art Newland
Old Nov 22, 2010, 09:20 PM
CD-ROM Junkie
Joined Apr 2001
I pulled mine apart thinking about tapping into the power plug like daydream, but the area where the battery fits is so narrow none of my batteries will fit inside.
Old Nov 22, 2010, 09:21 PM
CD-ROM Junkie
Joined Apr 2001
I had wondered about that same thing, if the goggles can accept A/V directly without the liberator.
Old Nov 22, 2010, 09:35 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I doubt that would work. To me, the Liberator looks essentially like a little PC, hence the menu structure, firmware, ability to us USB, etc. I'd be willing to bet they've made it such a proprietary unit that the goggles won't work without the Liberator. Bummer. For the price I got mine I can live with the Liberator...plus I have a Trimersion set as a back up. The Fatshark simplicity sure looks good...those are lower resolution, have (reported) blurring around the edges of the screen, and are 2x+ the price of what I paid for my HPs. Loosing the Liberator would be so, well, liberating!!!! Nothings perfect though, so we'll likely just have to live/work with the Liberator attached.
Old Nov 22, 2010, 10:35 PM
kevinhines's Avatar
Roanoke, VA, USA
Joined Jul 2006
Great Question... If it were possible, to simply cut open the cable to the HP goggles, and supply power and composite video signal to the wires inside the goggle cable... that would make everything so much easier!
(And I'd be happy to toss the liberator box in the trash).
Anyone know if this can be done?
Kevin
Old Nov 22, 2010, 11:51 PM
DayDream is offline
Find More Posts by DayDream
DayDream's Avatar
Brigham City, Utah
Joined Nov 2008
Vantasstic,
There is residual drain when the headplay is off so you don't want to leave
the battery connected for too long. I was planing on popping the battery in
before heading for the field and pulling it out to charge after.
HeadPlay amp draw
off: 4.32mA - 231.5 hours on 1000mAh battery
on: 360-400mA - 2.5-2.8 hours on 1000mAh battery
depending on activity (higher with USP's or card)
flyboy321,
The zippy 2200mAh is too wide to fit with the cover closed. You could
rubber-band it like below, otherwise use a battery with dimensions less then...
H = 21.6mm
W = 59.7mm
L = 135.6mm
like
http://www.hobbyking.com/hobbyking/s...idProduct=6790 ~3.25 hours of use
http://www.hobbyking.com/hobbyking/s...idProduct=6539 ~4 hours of use
Thanks for the comments
Cory
DayDream is offline Find More Posts by DayDream
Old Nov 23, 2010, 06:29 AM
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Since it drains when it's not on, I guess I'll just use velcro on the battery to hold it in, that way I don't forget about it. Seems like a pain to have to unscrew every time I want to use it.
Old Nov 23, 2010, 07:14 AM
sim_io is offline
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
You don't have to unscrew it... You push in the tip of a pen on the front hole and just take the lid off.
Discussion Headplay New software for FPV Talajouy FPV Talk 35 Feb 05, 2011 01:26 AM
Build Log Headplay mods ashdec87 FPV Talk 30 Dec 27, 2010 11:03 AM
Discussion Four reason not to buy a Headplay goggle for FPV Talajouy FPV Talk 26 Nov 14, 2010 10:08 PM
Discussion 8 Reasons for not to Buy a Headplay for FPV gogi FPV Talk 84 Apr 16, 2010 10:47 PM
Discussion Headplay Video Goggle Question shmo70 FPV Talk 21 Nov 19, 2009 09:21 AM
