Old Nov 19, 2010, 08:50 AM
forrest225 is offline
Find More Posts by forrest225
Joined Aug 2008
Blade MSR Confirmed. FAQ + PICs Below + video and video review V2.0 + MSR HELP
Original is at http://www.rcgroups.com/forums/showthread.php?t=1084185
Video:
E-flite Blade MSR unboxing & REVIEW & first / maiden flight! (10 min 1 sec)
Pics:
Specs:
Type: Ultra Micro Single Rotor Helicopter
Main Rotor Diameter: 7.0 in (180mm)
Length: 7.5 in (190mm)
Motor Size: Coreless/Micro coreless
Kit/ARF/RTF: RTF
Experience Level: Intermediate
Recommended Environment: Indoor/Outdoor
Is Assembly Required: No
Link to manufacturer: http://www.e-fliterc.com/Default.aspx
Link to distributer: http://www.horizonhobby.com/RC/Default.aspx
Link to product page: http://www.horizonhobby.com/Products...rodID=EFLH3000
Review - E-flite's Ultra-micro Blade mSR RTF and BNF (8 min 58 sec)
FAQ:
Q- My msr will go into a tail spin to the right for no reason, why?
A- There are a few reasons this could happen. Sometimes the motor connections @ the 5n1 board become loose, check and make sure they are firmly plugged in and not bent. If that doesn't solve the problem the main motor might need to be replaced. You can diagnose the motor by taking the canopy off and removing motor from frame. Next unplug the tail motor and hold the main motor, the pinion should turn freely by hand, next run it full throttle and listen for noises and feel for heat build up. If it gets hot and or is noisy then it needs to be replaced, sometimes a motor won't show any signs of damage but might need to be replaced.
Q- My msr will go into a tail spin to the left for no reason, why?
A- First check the motor connections @ the 5n1 and make sure they are firmly plugged in and not bent. Next check the tail rotor and make sure it's not bent. If you crashed and developed this problem, the tail motor will get damaged very quickly if the shaft takes any impact from a crash, it will destroy the brushes and needs to be replaced. An easy way to prevent this from happening is to push the tail rotor all the way down on the shaft to prevent it from damaging the brushes on impact. If the tail cap popped off, chances are you will need to replace the tail motor.
Q- My msr drifts forward and to the left or right and can't be trimmed out
A- Usually there are 3 reasons why this happens, first check the swash and make sure the swash guide pin is between the guides on the frame, next check the swash and see if it has came undone, you use the red calibration tool to check and repair the swash without taking it apart. If that still didn't solve the problem check the main shaft and make sure there is no play up and down, usually you can hold the msr in your hand and when you hit the throttle watch the white main gear and see if it moves up or down, if so you need to push that main gear up on the shaft until it doesn't move up and down but not so tight that it puts friction on the shaft.
Q- My msr wants to do nose dive if I hold forward cyclic for too much or too long, is this normal? Any ways of preventing this?
A- This is normal and will happen more on high rates, AKA the death dive! You can prevent this by using less forward cyclic and or getting the microheli flybar. The MH flybar increases stability and reduces pendulum effect and tbe, read more about it here- http://www.microheli.com/product_inf...oducts_id=1707
Q- My msr started making some weird buzzing sound, what is it?
A- Most likely the tail rotor is bent. If the strange noise is coming from the servo it might be a bent or broken tooth on the servo gear.
Q- One of my servos is stuck and or barely moves, why?
A- Either a piece of dirt or a bent or broken tooth on the servo gear is binding up. Inspect by turning the servo gear with fingers and see where the gear gets caught. This could also be caused by dirt on the resistive track. To check for this remove the servos, if you see any dirt or smudges, remove it with a mild detergent.
Q- My msr goes around in a circle like it's hovering in a toilet bowl, why?
A- There are a few things that can cause this problem, could be bent blade grips, check and make sure the blades track good. Next check the flybar for any bends or a worn out center hole. Next check and make sure the flybar pivots freely with no resistance, if there is any resistance at all it will not fly correct. Next check the blades and make sure they are floppy in the blade grips, if the blades are too tight then you will have a problem. Next check the brass washers and o-rings in the head around the feathering shaft, there should be one o-ring in each side of the head and one brass washer on each side, the blade grips should teeter freely on the main hub and feathering shaft. If that still doesn't fix the problem you might want see if there is any play in the main hub and main shaft, you can do this by gently twisting the main gear while holding the main hub and check for any play or movement back and forth. The hole in the main shaft sometimes get to big and the main hub will get loose as the screw doesn't firmly hold it anymore, you will need to replace the main shaft if this occurs.
Q- I think my 5n1 is bad, I get glitches and or power cuts out, why?
A- If you get the blue led light that goes out, try wiggling the battery cable with your fingers and see if the light stays on, if it doesn't, you need a new replacement 5n1 battery cable, the connecter goes bad after a while and replacing the cable will fix that problem. If you lose bind or won't bind @ all, then you might have a 5n1 problem, everything else is usually fixable.
Q- My msr feels very slow with my DX6i, is there something wrong?
A- If you fly in ACRO mode make sure the gear/fmode switch is in fmode. If flying in HELI mode check flap/gyro switch. There are low/high rates on these switches that most people are unaware of.
Thank you slo-fly & SoloPro!
forrest225 is offline Find More Posts by forrest225
Old Nov 19, 2010, 09:18 AM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
Here's a msr tune up guide that goes over common problems and troubleshooting.
BLADE Msr TUNE UP COMMON PROBLEMS AND HOW TO FIX GUIDE (6 min 29 sec)
Here's a flipping vid
Blade Msr getting tricky! (1 min 36 sec)
and another flipping vid (both are best to watch in 720p HD fullscreen)
Blade Msr flips and loops high performance flying crazy (0 min 51 sec)
slo-fly is offline Find More Posts by slo-fly
Old Nov 19, 2010, 10:26 AM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
Why start over? The other thread was lacking content? Isn't two enough already?
hydro_pyro is offline Find More Posts by hydro_pyro
Old Nov 19, 2010, 10:28 AM
BJ64 is offline
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
...hmmmm.... the paint still smells wet...
BJ
BJ64 is offline Find More Posts by BJ64
Old Nov 19, 2010, 11:23 AM
Bob_B is offline
Find More Posts by Bob_B
Flys Like A Brick
Bob_B's Avatar
Washington, MI
Joined Nov 2010
It is just like my old truck after my wife sprayed Fabreze on the seats to get rid of the smell she didn't like. For a while it just didn't seem comfortable anymore. Then the old smell came back and I was happy again.
Bob_B is offline Find More Posts by Bob_B
Old Nov 19, 2010, 01:16 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Where is the video review the title refers to?
SoloProFan is online now Find More Posts by SoloProFan
Old Nov 19, 2010, 01:47 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
hey guys
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 19, 2010, 02:26 PM
Chris_F is offline
Find More Posts by Chris_F
The new guy
Londonderry, NH
Joined Oct 2010
Mod said we broke the server with the old thread...
BTW, even though this is a BS, zero content post, I still feel proud to be in on the first page.
Chris_F is offline Find More Posts by Chris_F
Old Nov 19, 2010, 05:49 PM
stalyoni is offline
Find More Posts by stalyoni
high flyer
stalyoni's Avatar
Australia, WA, Geraldton
Joined May 2008
Originally Posted by Razors edge 29 View Post
hey guys
um hello?
asl? LOLS
stalyoni is offline Find More Posts by stalyoni
Old Nov 19, 2010, 06:52 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
Yeah, I see it's locked now.
Old Nov 19, 2010, 08:29 PM
Joined Aug 2008
It's there now
Old Nov 19, 2010, 11:19 PM
BJ64 is offline
BJ64's Avatar
Joined Jun 2009
Some of us just love to chit-chat and talk BS Hydro.. LoL
BJ
Old Nov 20, 2010, 12:26 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
My blinged-out mSR - like the thread - just keeps on going and going. Never would have thought that I'd put over 80 hours of flight-time on the little heli. Soon, she will be XP-powered...
Joel
turboparker is offline Find More Posts by turboparker
Old Nov 20, 2010, 12:35 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by forrest225 View Post
it's there now
ty!
Old Nov 20, 2010, 01:07 AM
VooDuuChild is offline
Find More Posts by VooDuuChild
smoking crack is cheaper
VooDuuChild's Avatar
North of Seattle
Joined Nov 2009
ummm,,,errrr
As a wise towel named Towelie once said..."I have no idea what's goin on"
VooDuuChild is offline Find More Posts by VooDuuChild
Question Blade MSR vs. Solo Pro V2 darmawaa Micro Helis 40 Jan 13, 2011 12:45 AM
New Product Blade MSR Confirmed. PICs Below + video and video review forrest225 Micro Helis 16363 Nov 19, 2010 08:52 AM
Sold E-Flite Blade MSR RTF **Pics Added, Price Dropped** SixDeuces Aircraft - Electric - Helis (FS/W) 7 Oct 26, 2010 03:59 PM
Cool Confirmed fit Blade MSR Darth MD500 Fuselage darthdrk Micro Helis 65 May 12, 2010 01:25 PM
