Old Nov 19, 2010, 08:21 AM
GWSRobster is offline
Find More Posts by GWSRobster
Howdy Doody
GWSRobster's Avatar
Yorkshire, England, UK
Joined Sep 2004
I would like a charger that...
...allows me to charge individual cells within a lipo pack. For example, i have a 3S pack where two cells are resting marginally over 3V and one cell is borderline 3V. However, when i connect my Hobby Lobby balancer & guard, by the time the cells have balanced my basic Graupner Lipo Charger 4 won't allow charging to start as it detects the pack voltage as an error, ie below 9V on the 3S pack (like is said this is extremely marginal!!). I'd like the opportunity to charge this pack back up and see how it acts rather than just binning it.
I would also like said charger to have features such as built in balancer, individual cell monitoring, discharge function etc. Dual input (ac/dc) would also be useful.
As mentioned, upto now i've got by with a basic Graupner item and external balancer but i would like something a little better/more advanced now. Have had a good search but can't see anything that states individual cell charging function
Can anyone help?!
Rob
GWSRobster is offline Find More Posts by GWSRobster
Old Nov 19, 2010, 08:48 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Nio dischargfe and no AC power but a great true 4 channel Lipoly charger.
http://www.rcgroups.com/forums/showt...light=dn+power
If you do an Advanced Search using DN Power exact match in Title there are many threads on this charger.
It has been out of production for years now however. Common Sense RC use to sell ones which were clones of it and they perhaps still do.
Charles
Old Nov 19, 2010, 08:59 AM
Howdy Doody
GWSRobster's Avatar
Joined Sep 2004
Great reply, looks like the kind of thing i am looking for
Will do the search and see what i can find.
Again, i thank you.
Rob
Old Nov 19, 2010, 09:14 AM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Rob, what Charles said.
I have, well, too many of those in my shop as they are my second favorite chargers but they pop up from time to time in the for sale forum.
You would have to use a reverser ALL the time as they are backwards to the now common JST-XH pinouts. IMO, hot glue the reverser to the charger so it can never be removed easily.
I know of a local fb selling 2 of them for $60. Not a bad deal for something that used to sell for $99.
Here is his ad in our club forum: http://www.rcgroups.com/forums/showp...postcount=2323
Hint - But both; you can use two of these in parallel with a custom harness and charge at up to 4 amps constant.
Disclaimer - Do NOT try this with ANY other charger or they will be damaged. These DN/CSRC chargers will do this, I have put as many as 4 in parallel only to find out the pins can't handle more than 4A constant.
Rick
rampman is offline Find More Posts by rampman
Old Nov 19, 2010, 10:52 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
You are overdischarging your packs, as you are probably aware. Attaching a balancer to your discharged packs makes this situation worse. Lipolys should never be balanced in a discharged state as cell capacity within a pack can vary and balancing while discharged will create an imbalance when charged, where cell-to-cell balance is critical.
You can bring your overdischarged pack to a voltage that can be charged by your charger by connecting it to a charged pack of the same cell count for a short period of time. You can use a resistor to limit current flow like this:
http://www.rcgroups.com/forums/showthread.php?t=1255751
Nearly all decent quality balancing chargers will allow charging of individual cells through the balance tap. Simply fabricate an adapter (see below pics), connect to the balance tap, and proceed charging as a 1S pack. I recommend the iCharger family of chargers.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Nov 20, 2010, 05:40 AM
Howdy Doody
GWSRobster's Avatar
Joined Sep 2004
Nippy
Mark
Thanks Mark :-)
More sound advice. Yes I'm aware that particular pack has been subject to overuse! I do always fly to timers but on a couple of occasions have just gone on a bit long!
Cheers
Rob
Discussion I would think that even this would fall under the 1st Amendment logan5 Life, The Universe, and Politics 15 Nov 04, 2010 02:02 PM
For Sale FS or TRADE I have a LIKE NEW GP SIREN that I would like to trade for an EDF mechengineer03 Aircraft - Electric - Jets (FS/W) 1 Dec 25, 2008 09:23 AM
Now, who would like to live at a place like that? jschrader Aerial Photography 9 May 21, 2004 08:03 AM
Yippee! What if AXI made a prop hub that would drive GWS props? Maybe something like this. power Power Systems 19 Mar 11, 2004 07:10 AM
Anyone else out there that would like to try Online combat with Cockpitmaster???? kushal_22 Electric Plane Talk 10 Apr 13, 2002 12:23 PM
