Old Nov 19, 2010, 08:07 AM
I'm a Registered User
Evansville, WI
Joined Dec 2006
What do head dampers do?
I know, dampen the head I've been flying FP for awhile, but I'm pretty new to the CP's. As such, I've never had to work with head dampers before. I understand they're necessary, but I'm uncleas as to what exactly they do. What are they for? What happens when they wear out? What effect do stiffer or softer dampers have? What if you eliminated them with shims? Thanks for the info.
Bugman Jeff is offline Find More Posts by Bugman Jeff
Old Nov 19, 2010, 08:51 AM
Scotland the Brave
Dusty1000's Avatar
United Kingdom, Scotland, Glasgow
Joined Mar 2008
Soft dampers make the cyclic feel soft, hard dampers make it feel hard
When they wear out, you just replace them.
Not sure what you mean by eliminating them with shims They're not only there for any side to side slop, but for the up and down slop too
Dusty
Dusty1000 is offline Find More Posts by Dusty1000
Old Nov 19, 2010, 09:13 AM
Toronto Canada
Joined Dec 2002
Dampers help isolate the head and heli from each other and average out any instantaneous mechanical effects that occur during head rotation.
In most FP helis, damping is accomplished by means of the flexible blades.
In a CP heli, if there is insufficient damping (shims, dampers too hard, cold weather) even the dysymmetry from the blades passing over the canopy can interact with the fuselage and cause the tail to bob up and down.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Nov 19, 2010, 11:27 AM
shastamike's Avatar
Mt. Shasta California
Joined Jun 2010
Do Walkera FP helis (V120D01 and V100D01) helis have head dampers?
shastamike is online now Find More Posts by shastamike
Old Nov 19, 2010, 02:54 PM
potato42's Avatar
Joined Dec 2007
The o rings installed on the feathering shaft act as a damper. I'm curious to try stiffer o rings or possibly a hard material to see what happens.
potato42 is offline Find More Posts by potato42
Discussion Head dampers... help Phil R Electric Heli Talk 4 Feb 04, 2007 12:27 PM
T-Rex align metal head dampers misskimo Mini Helis 4 Oct 30, 2005 08:01 PM
Secret T-Rex Head dampers JimT Mini Helis 1 Oct 29, 2005 01:49 AM
