Parkzone T28 / Corsair Aluminum Motor Adapter 3530/3536/3542
This is a custom machined aluminum motor mount for the Parkzone Corsair and T-28. It is designed to adapt a range of 3530, 3536 and 3542 size brushless motors to these Parkzone planes for an excellent upgrade in performance.
One of the key features to this mount is that it utilizes the stock plastic mount as a buffer zone in the event of a crash. The very inexpensive and easily replaceable stock plastic mount should take the impact instead of damaging the planes fuselage. No cowl modifications are necessary for the 3536 series of motors, simply bolt on and you are ready to fly. Three step installation (detailed pictures below): 1. Attach new motor to aluminum mount with the motors supplied screws 2. Attach Parkzone stock plastic mount using the original motor screws 3. Attach entire assembly to the planes fuselage with the original mounting screwsFor proper cowl to propeller clearance on the 3530 and 3536 motors that utilize the bolt on propeller shaft you will utilize the supplied prop spacer plus the flat washer that comes with the new motor as shown in the pictures below. If using a standard motor shaft, a standard collet adapter will work. The stock Corsair / T28 spinner nut will typically work to give you more of a scale look if desired. Compatible Motors (3530 Series): Turnigy 35-30C 1100KV (and other KV options) Heads Up RC 3530-11 RC Timer BC3530-14 1100KV and others in the 3530 series with the 19mm x 25mm bolt pattern Compatible Motors (3536 series): Turnigy 35-36C 1100KV (and other KV options) Heads Up RC 3536-10 Exceed RC Alpha 480 1020KV RC Timer BC3536-6 1250KV and others in the 3536 series with the 19mm x 25mm bolt patternFor those that want an extreme upgrade in performance, choose one of the 3542 series motors . The cowl will need to be modified to accommodate these larger motors by slightly enlarging the front opening. The included propeller spacer may or may not be needed depending on which propeller is chosen. Please note that these 3542 motors may exceed the capability of the planes airframe. Special care should be taken when flying at the extreme speeds these planes will be capable of. Compatible Motors (3542 series): Turnigy 35-42C 1100KV (and other KV options) Heads Up RC 3542-10 Exceed RC Monster Power 10 1100KV RC Timer BC3542-6 1000KV and others in the 3542 series with the 19mm x 25mm bolt pattern Propeller Compatibility: Stock 2 blade T28 / Corsair 9.5x7.5 Stock 3 blade T28 / Corsair 9x7.5 Stock 2 blade P51 9x6 MAS 10x7x3 There are quite a few other options and will continue updating the list as they are tested The fit and quality of these mounts are excellent. These are manufactured by smallpartsCNC which I own and operate. To reduce cost, these come in bare aluminum as shown in the photos. Included: 1 Parkzone Corsair / T-28 Aluminum Motor Mount. with propeller spacer. Weight: 7g (3530) and 5g (3536/42)I am asking $14.00 ea. with a fixed shipping of $2.00 in the US and $4.00 International. Send me a PM if you are interested or have any other questions. Thanks for looking! Terry |
| Thread Tools | |
| Sold Parkzone Gunfighter P-51 Mustang "Repair Kit" w/machined aluminum motor mount | craab | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 07, 2010 04:13 PM |
| Wanted Looking for Broken PZ T28 or Corsair Motor | norstaroption | Aircraft - Electric - Power Systems (FS/W) | 8 | Sep 01, 2010 04:45 PM |
| Sold Turnigy 3536 with aluminum motor mount ,& Neo 370 with speed control | Dennis Everett | Aircraft - Electric - Power Systems (FS/W) | 1 | Jul 31, 2010 02:23 PM |
| Discussion Parkzone T-28/Corsair Aluminum Motor Mount | EAST RC | Product Announcements | 0 | Aug 26, 2009 09:26 AM |
| Sold 2 new PZ T28 props & 1 New PZ Corsair prop adapter - $9.50 shipped | shawn595 | Aircraft - Electric - Power Systems (FS/W) | 2 | Mar 16, 2009 05:01 PM |
